电子发烧友论坛|
服务器:R730(BIOS:2.5.5)
GPU:M60 管理程序:VMware vSphere 6.0 Update 2 首先,我将GPU模式更改为“Graphics”,并将驱动程序367.43安装到vSphere 6.0 Update 2。 并将GPU“grid_m60-1q”添加到虚拟机(Windows 7)并启动。 但是无法将驱动程序369.17安装到Windows 7(x64)。 以上来自于谷歌翻译 以下为原文 Server: R730 (BIOS: 2.5.5) GPU: M60 Hypervisor: VMware vSphere 6.0 Update 2 First I change the GPU mode to "Graphics" and install the driver 367.43 to vSphere 6.0 Update 2. And Add the GPU "grid_m60-1q" to virtual machine (Windows 7) and powered-on. But just couldn't install the driver 369.17 to Windows 7 (x64). |
10个回答
嗨史蒂文
我的中文不是很好,所以我无法在Windows中阅读Nvidia错误信息:-)其他一切看起来都不错。 在Windows中安装Nvidia驱动程序时,它会在安装之前扫描以查看系统中是否存在适当的GPU。 您可以查看设备管理器以确保系统已检测到vGPU。 如果没有适当的GPU存在或未检测到,则驱动程序安装将出错并失败。 如果您可以“显示隐藏的设备”并截取您可以看到的内容的屏幕截图,那就太棒了。 问候 本 以上来自于谷歌翻译 以下为原文 Hi Steven My Chinese isn't very good, so I'm not able to read the Nvidia error message within Windows :-) Everything else looks fine though. When you install the Nvidia driver in Windows, it scans to see if there is an appropriate GPU present in the system before installing. Can you have a look in Device Manager to make sure the system has detected the vGPU. If there is no appropriate GPU present or it isn't detected, the driver install will error and fail. If you can "Show Hidden Devices" and take a screenshot of what you can see, that would be great. Regards Ben |
有(至少)2个版本的“369.17” - 用于Grid1(kepler K *)和Grid2-4(maxwell M *)设备。
我没有vSphere驱动程序包,但是对于XenServer驱动程序包(vSphere和XenServer的guest虚拟机驱动程序应该相同): K *的369.17_grid_win8_win7_server2012R2_server2008R2_64bit_international.exe(大小260596682)(来自标准驱动程序下载页面) M *的369.17_grid_win8_win7_server2012R2_server2008R2_64bit_international.exe(大小260609110)(来自grid2-4 eval / license页面) 我想K *版本不支持M *设备。 也许你使用错误的安装文件。 以上来自于谷歌翻译 以下为原文 There are (at least) 2 versions of "369.17" - for Grid1 (kepler K*) and for Grid2-4 (maxwell M*) devices. I do not have vSphere driver package but for XenServer driver packages (the guest drivers should be the same for vSphere and XenServer): 369.17_grid_win8_win7_server2012R2_server2008R2_64bit_international.exe (size 260596682) for K* (from standard drivers download page) 369.17_grid_win8_win7_server2012R2_server2008R2_64bit_international.exe (size 260609110) for M* (from grid2-4 eval/license page) I suppose that K* version does not support M* devices. Maybe you use bad setup file. |
你在哪里下载驱动程序包(包括特斯拉卡的vGPU Manger)?
请注意,这是一个需要许可的软件包,因此必须从GRID软件门户下载: http://www.nvidia.com/object/grid-evaluation.html#utm_source=shorturl&utm_medium=referrer&utm_campaign=grideval 你能否从主机shell运行nvidia-smi来查看vGPU管理器是否安装正确? 问候 西蒙 以上来自于谷歌翻译 以下为原文 Where did you download the driver package (including vGPU Manger for the Tesla card)? Be aware that this is a software package that needs licensing and therefore must be downloaded from the GRID software portal: http://www.nvidia.com/object/grid-evaluation.html#utm_source=shorturl&utm_medium=referrer&utm_campaign=grideval Can you please run nvidia-smi from a host shell to see if the vGPU manager is installed properly? Regards Simon |
嗨史蒂文
感谢更新。 只是为了完整性和可能遇到同样问题的其他人的利益,您是如何解决的? 问候 本 以上来自于谷歌翻译 以下为原文 Hi Steven Thanks for the update. Just for completeness and the benefit of others who may encounter the same issue, how did you resolve it? Regards Ben |
实际上,问题是我使用UltraISO,让驱动程序(* .exe)创建一个新的iso文件并挂载到虚拟机并将文件复制到桌面...我的坏:P
史蒂芬 以上来自于谷歌翻译 以下为原文 Actually, the promble was I use the UltraISO, let the driver(*.exe) make a new iso file and mount to Virtual Machine and copy the file to the desktop...My bad :P Steven |
史蒂文,你是怎么解决的?
我刚刚在vSphere 6.5上为vGPU安装了vib,在最终找出Share Direct问题并且无法启动VM之后,我似乎无法在Wins 7 64位VM上加载驱动程序。 当Setup.exe运行时,它无法检测到vGPU? 任何帮助,将不胜感激。 我已经尝试了esxi6.5下载附带的v369.49,并尝试了v378.49无济于事。 我在设备管理器中注意到未检测到vGPU。 以上来自于谷歌翻译 以下为原文 Steven, how did you solve this? I've just installed the vib for vGPU on vSphere 6.5 and after eventually figuring out the Share Direct issue and not able to power on the VM, I can't seem to load the Driver on a Wins 7 64 bit VM. When Setup.exe is ran it can't detect the vGPU? Any help would be appreciated. I've tried v369.49 that came with the esxi6.5 download and also tried v378.49 to no avail. I have noticed in Device Manager that the vGPU is not detected. |
嗨jc296,
不确定你引用的是什么,但上面提到的两个驱动程序都是错误的。 您需要从https://nvidia.flexnetoperations.com下载GRID包,并为您的虚拟机管理程序安装正确的vGPU管理器/驱动程序包。 当前的GRID包应该有vGPU管理器:367.92和驱动程序:369.95 只有给定的组合才有效!!! 问候 西蒙 以上来自于谷歌翻译 以下为原文 Hi jc296, not sure what you referencing to but both drivers stated above are wrong. You need to download the GRID package from https://nvidia.flexnetoperations.com and install the correct vGPU manager/driver bundle for your hypervisor. Current GRID package should have vGPU manager: 367.92 and driver: 369.95 Only the given combinations will work!!! Regards Simon |
西蒙,我认为我的混乱是由NVidia horizon 7部署指南引起的,该指南讨论了一个应该在标题中有vGPU的VIB。
在NVIDIA网站上搜索了vsphere 6.5驱动程序后,唯一可用的是NVIDIA-Keplar-VMware_ESXi主机驱动程序367.64-1OEM.650.0.0.424-417。 我在K2 ESXi主机上安装了这个,并配置了VM以使用Shared PCie vGPU。 它启动ok,接受本机vgPU驱动程序并打开电源; 查看代理和直流插头安装正常,但当我使用零客户端连接到pcoip时,它连接到虚拟机桌面,但在大约1Hz闪烁到黑屏。 有任何想法吗? 以上来自于谷歌翻译 以下为原文 Simon, I think the confusion for me was brought about by the NVidia horizon 7 deployment guide talking about a VIB that should have vGPU in the title. Having searched for vsphere 6.5 drivers on the NVIDIA site, the only vib avail is NVIDIA-Keplar-VMware_ESXi Host Driver 367.64-1OEM.650.0.0.424-417. I've installed this on my K2 ESXi host and configured a VM to use Shared PCie vGPU. It powers on ok, takes the native vgPU drivers and powers on; view agent and dc plug installed ok but when I connect over pcoip using zero client it connects to the VMs desktop but blinks to black screen at approx1Hz. Any ideas? |
只是为了验证:我们是在谈论特斯拉M60还是GRID K2卡?
你现在带哪些司机? 黑屏听起来像VMWare问题。 问候 西蒙 以上来自于谷歌翻译 以下为原文 Just to verify: Are we talking about Tesla M60 or GRID K2 card? Which drivers did you take now? Black screen sounds like VMWare issue. Regards Simon |
只有小组成员才能发言,加入小组>>
使用Vsphere 6.5在Compute模式下使用2个M60卡遇到VM问题
3396 浏览 5 评论
是否有可能获得XenServer 7.1的GRID K2驱动程序?
3819 浏览 4 评论
/9
GMT+8, 2025-12-2 07:45 , Processed in 1.002256 second(s), Total 92, Slave 75 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2880
