电子发烧友论坛|
大家好,
我目前正在寻找安全关键的HW选项在PSoC5LP。 NMI似乎只能通过软件来挂起,但是PSoC5LP寄存器TRM指出,当PANTHEL WAITSITER寄存器的NMIZ-SRCSEL位设置为1时,NMI线被馈送DSI001OUTXPY11信号。这个信号是什么?它是通过UDB/DATAPATH块进行路由的吗? 我还阅读了Joseph Yiu的《ARCORTEX-M3》的权威指南,并想知道如何在PSOC5LP中使用锁定信号(第12.5节)。是否触发系统重置? 当做, 卡德里克 以上来自于百度翻译 以下为原文 Hi everyone, I'm currently looking into safety-critical related HW options in the PSoC5lp. NMI seems to be only pendable by software, however the PSoC5lp Registers TRM states that when the NMI_SRCSEL bit of the PANTHER_WAITPIPE register is set to 1, the NMI line is fed with DSI_01_OUT_P_11 signal. What is this signal ? Is it routable through UDB/datapath blocks ? I also read the "Definitive Guide to the ARM Cortex-M3" book by Joseph Yiu and was wondering how the LOCKUP signal (section 12.5) is used in the PSoC5lp. Does it trigger a SystemReset ? Regards, Cédric |
2个回答
DSI001OUTXPY11是DSI位置。
DSI位置用以下信息编码: 1)DSI数(00—09,12, 13) 2)“in”或“OUT”信号(所有信号方向相对于UDB阵列描述),因此“in”信号是从外部进入UDB阵列的信号,并且“OUT”信号是离开UDB阵列的信号)。 3)连接类型“P”或“T”,表示DSI上连接的数量。一个“P”代表对,这意味着DSI上的相关信号有两个连接。A“T”表示一个三元组,这意味着DSI上的相关信号有三个连接。 4)连接数(p为0~24,出p为0~15,出t为0~15)。 Dsia01IOUTXP1111(CM3O-DSIIN NMI),/ /非可屏蔽中断到皮质M3 NMI中断可以在启用NMIZ-SRCSEL比特之后由该引脚触发。 以上来自于百度翻译 以下为原文 DSI_01_OUT_P_11 is a DSI location. The DSI location is encoded with the following information: 1.) The DSI number (00-09, 12, 13) 2.) “in” or “out” signal (all signal directions are described with respect to the UDB array, so an “in” signal is a signal that is entering the UDB array from outside, and an “out” signal is a signal leaving the UDB array) 3.) The connection type “p” or “t” which represents the number of connections on the DSI. A “p” stands for pair, meaning there are two connections on the DSI for the associated signal. A “t” represents a triplet, meaning there are three connections on the DSI for the associated signal. 4.) The connection number (in p # 0 – 24, out p # 0 – 15, out t # 0 – 15) .dsi_01_out_p_11( cm3_dsi_nmi ), // non-maskable interrupt to the Cortex M3 the NMI interrupt can be triggered by this pin after enabling the NMI_SRCSEL bit |
PSoC Creator不直接暴露NMI。PSoC Creator没有正式记录/支持的过程。
谢谢 Jobin燃气轮机 以上来自于百度翻译 以下为原文 PSoC Creator does not expose the NMI directly. And there is no process officially documented/supported by PSoC Creator. Thanks Jobin GT |
只有小组成员才能发言,加入小组>>
786个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7088 浏览 0 评论
2474 浏览 1 评论
2166 浏览 1 评论
4031 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2073 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7566浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6114浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
742浏览 2评论
710浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
7962浏览 2评论
/9
GMT+8, 2025-12-2 04:31 , Processed in 0.639973 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2140
