电子发烧友论坛|
我有34970a。
我用它来监控夜间随机和未知的冷冻机故障。 如果我打开扫描仪,数据将在早上覆盖。 冰箱很遥远,可能几天都看不到它。 每小时收集大约10,800点。 接下来,我将34970a的功率与冷冻功率联系起来。 当冷冻机停机时扫描仪也是如此。 那很好。 问题是当我连接到笔记本电脑上传时,34970a认为上电时有新的扫描,它会删除之前的夜晚数据。 如何让扫描停止并保持数据直到早上? 需要简单的解决方案,我不是程序员。 以上来自于谷歌翻译 以下为原文 I have a 34970a. I am using it to monitor a random and unknown freezer failure at nighttime. If I leave scanner on, the data overwrites by morning. Freezer is remote and may not see it for days. Roughly 10,800 points per hour collected. Next I tied power of 34970a into freezer power. When freezer shutdown so did scanner. That was good. Problem is when I connect to laptop for upload and 34970a thinks there is a new scan upon power up, it deletes the previous nights data. How can I get scan to stop and hold data till the morning? Need simple solution, I am not a programmer person. |
1个回答
34970A的默认存储器模式是复位状态。
将状态更改为“上次上电”,以便在电源中断时保存读数和设置。 您可以通过按Shift> Utility> Utility> Utilty> Utility直接从前面板执行此操作,直到显示PWR ON RESET。 旋转旋钮将RESET更改为LAST,然后再次按Utility键。 您必须牢牢按下Utility,并确保显示TIME以确保您在右侧菜单中。 以上来自于谷歌翻译 以下为原文 The default memory mode for the 34970A is the reset state. Change the state to "power on last" to have readings and setup saved on power interruption. You do this from the front panel by pressing Shift > Utility > Utility > Utilty > Utility until PWR ON RESET is displayed. Rotate the knob to change RESET to LAST, and then press the Utility key once more. You have to press the Utility firmly and make sure the TIME is displayed to be sure you are in the right menu. |
只有小组成员才能发言,加入小组>>
1844 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2449 浏览 5 评论
3458 浏览 3 评论
1844浏览 0评论
416浏览 0评论
/9
GMT+8, 2025-12-2 01:47 , Processed in 0.811118 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1298
