电子发烧友论坛|
我希望在设定的扫描上下时间以对数步长从开始扫描到停止频率。
我怎么能够? 以上来自于谷歌翻译 以下为原文 I wish to sweep from a start to a stop frequency with logarithmic steps in a set sweep up and down time. How can I? |
2个回答
实际上,我希望33521能够以对数方式向上和向下扫描,但是因为它是扫描路径日志而另一种方式是线性的。
现在我们在A秒内将日志从X扫描到Y频率,并在A秒内将线性Y返回到X. 然后我们在A秒内将X扫描到Y线性,并将Y返回到X log。 我们更喜欢只扫描和返回日志,但我没见过arb /函数生成器。 我想如果我需要公式来创建频率列表(使用日志步骤)我会这样做。 你有什么建议吗。 谢谢你回复迈克 以上来自于谷歌翻译 以下为原文 Actually, both I wish the 33521 would sweep up and down logarithmically, but as it is it sweep on way log and the other way linear. Right now we sweep up log from X to Y frequency in A seconds, and return linear Y to X in A seconds. We then sweep up X to Y linear in A seconds, and return Y to X log. We prefer just to sweep up and back log, but no arb/function generator I've seen does that. I suppose if I need the formula to create frequency list (with log steps) I would do that. Do you have any suggestions. Thanks for replying Mike |
selinali0112 发表于 2019-7-3 16:21 嗨迈克,你可以随时使用FM,而不是扫描功能。 这允许您将所需的任何波形用作调制形状。 你拥有比扫描更多的自由,因为你有能力创建自己的控制频率调制的arb。 以上来自于谷歌翻译 以下为原文 Hi Mike, You could always use FM, instead of the sweep function. This allows you to use any waveform you want as the modulating shape. You have a lot more freedom than you do with sweep, since you have the ability to create your own arb that controls the frequency modulation. |
只有小组成员才能发言,加入小组>>
1844 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2449 浏览 5 评论
3458 浏览 3 评论
1845浏览 0评论
417浏览 0评论
/9
GMT+8, 2025-12-2 07:08 , Processed in 0.476078 second(s), Total 44, Slave 37 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2138
