电子发烧友论坛|
1。偏爱
WORDOWS10 - PSoc Creator 4.1~4.2 单片机:cy8c4247lqi-bl473,cy8c4248lqi-bl583(cy8ckit-042-ble-a创业板) (选择正确的设备选择根据单片机在PSoC Creator) 示例源:BLYFIDFME(PSoC示例源) 蓝牙Android应用程序:CyScript 2。问题:“cy8c4247lqi-bl473”车载蓝牙不工作(我是做psoc4单片机PCB板>;cy8c4247lqi-bl473组装) “cy8c4248lqi-bl583“蓝牙工作好(cy8ckit-143a板) 三。PCB蓝牙天线测试:蓝牙天线工作正常 4。示意图 5。cy8c4247lqi-bl473”委员会的工作除了蓝牙(IO,定时器,UART,输入中断) -------------------------------------------------------------------------------------- 谢谢 以上来自于百度翻译 以下为原文 1. Preference - Windows10 - PSoc Creator 4.1 ~ 4.2 - MCU : CY8C4247LQI-BL473, CY8C4248LQI-BL583 (CY8CKit-042-BLE-A Pioneer board) ( Selected correctly in Device Selector depending on MCU at PSoc Creator) - Example Source : BLE_FindMe (PSoc Example source) - bluetooth Android APP : CySmart 2. Problem : "CY8C4247LQI-BL473" board Bluetooth not working ( I make pcb board for PSoc4 MCU -> CY8C4247LQI-BL473 assembled ) - "CY8C4248LQI-BL583" bluetooth working good (CY8CKit-143A Board) 3. PCB Bluetooth antenna test : Bluetooth antenna works well 4. Schematic 5. "CY8C4247LQI-BL473" board's function working well except bluetooth (IO, Timer, UART, Input Interrupt ) -------------------------------------------------------------------------------------- thanks |
5个回答
你能解释一下蓝牙不工作吗?它不是发送/接收吗?操作是否不正常?FIDME配置文件不允许连接吗?
以上来自于百度翻译 以下为原文 Can you explain how the Bluetooth isn't working? Is it just not transmitting/receiving? Is it behaving erratically for operation? Is the FindMe profile not allowing connection? |
CyScript无法找到“FunMe”。 我认为在“CY8C4247LQI-BL73单片机”中,“FUNME”示例应该正常工作。 但我认为程序有问题。 我对天线有很多疑虑,但是射频工程师说天线没有问题。 所以我做了这个测试 1。删除CY8CKIT-143A的天线电容器(C14) 2。将C14电容器连接到新创建的空白PCB的天线上 三。将CY8CKIT-143A的天线输出引脚(引脚12)连接到空白PCB天线 4。连接两个板的GND CY8CKIT-143A的PAN12(ANT)-CAP(1.5 PF)——新板天线 结果:CyScript找到了“芬迪”和“芬迪”的好工作。 以上来自于百度翻译 以下为原文 CySmart can not found "FindMe". I think the "FindMe" example should work normally in "CY8C4247LQI-BL473 MCU" but i think the programs problem. I had a lot of doubts about the antenna, but the rf engineer says there is no problem with the antenna. So I did this test 1. Remove the antenna capacitor (C14) of CY8CKit-143A 2. Attach the C14 capacitor to the antenna of the newly created blank pcb 3. Connect the antenna output pin (pin 12) of the CY8CKit-143A to the antenna of the blank pcb 4. Connect the GND of both boards -- CY8CKit-143A 's pin12 (ANT) -- cap (1.5pF) -- new board 's Antenna result: CySmart find the "FindMe" and "FindMe" good working |
yuhe82 发表于 2018-9-26 12:34 FiffEMe示例项目应该在项目运行时闪烁LED,当您用示例项目编程时:PSOC-4-BLU/MID.PDF在Master·CyPress半导体ToCo/PSOC-4-BLE·GITHUB上编程 如果您没有看到LED闪烁/闪烁,那么它可能是IO没有被配置为与您拥有的硬件板相匹配(示例项目并不总是与演示板的IO端口正确匹配)。 以上来自于百度翻译 以下为原文 The FindeMe example project should be blinking the LED as the project runs when you program it with the example project: PSoC-4-BLE/Find Me.pdf at master · cypresssemiconductorco/PSoC-4-BLE · GitHub If you are not seeing the LED flashing/blinking, then it could potentially be that the IO is not configured to match the hardware board you have (the example projects don't always match correctly with the demo board's IO ports). |
yuhe82 发表于 2018-9-26 12:47 我发现了这个问题。 问题是谐振器(CSTCW24M0X53-R0) 我改变谐振器(CSTCW24M0X53-R0)到晶体(CY8CKIT-143A板的24MHz晶体) 结果:蓝牙工作 我不知道晶体和谐振器的区别。 我可以用PSOC4中的谐振器吗? 数据表 谐振器:CSTCW24M0X53-R0-以及CSTCW24M0X53-R0陶瓷谐振器(Celalok®)定时器件Mura制造有限公司 科瑞斯特尔:ecs-240-8-36ckm-tr——>;http://www.mouser.com/ds/2/122/ecx-2236-15751.pdf 以上来自于百度翻译 以下为原文 I found the problem. the problem is resonator ( CSTCW24M0X53-R0 ) i change the resonator (CSTCW24M0X53-R0) to Crystal ( CY8CKit-143A Board's 24MHz Crystal) Result : bluetooth working I don't know the difference between crystal and resonator. Can I use a resonator in PSoc4? Datasheet Resonator : CSTCW24M0X53-R0 --> CSTCW24M0X53-R0|Ceramic Resonators (CERALOCK®)|Timing Devices|Murata Manufacturing Co., Ltd. Crystal : ECS-240-8-36CKM-TR --> http://www.mouser.com/ds/2/122/ECX-2236-15751.pdf |
yuhe82 发表于 2018-9-26 13:06 振荡器和谐振器在操作和功能上是相似的。我认为主要的区别是在振荡的实施? 不管怎么说,我认为你应该罚款使用谐振器代替振荡器开关/。这听起来像振荡器损坏/功能如果切换到谐振器的固定的问题。 以上来自于百度翻译 以下为原文 Oscillators and resonators are similar in operation and function. I think the main difference is in the implementation of the oscillations? Anyways, I think you should be fine switching/using the resonator instead of the oscillator. It sounds like the oscillator is broken/nonfunctional if switching to the resonator fixed the issue. |
只有小组成员才能发言,加入小组>>
786个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7088 浏览 0 评论
2474 浏览 1 评论
2166 浏览 1 评论
4031 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2073 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7566浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6114浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
742浏览 2评论
710浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
7962浏览 2评论
/9
GMT+8, 2025-12-1 21:27 , Processed in 0.605794 second(s), Total 49, Slave 42 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1872
