电子发烧友论坛|
你好,
我们尝试使用PSoC Creator程序上使用5针连接器自定义PCB cypd212-24lqxit,得到了一个错误:“dbg.m0039有运行端口错误获得。可能没有设备连接,或一个设备可以被其他应用程序使用,而编程的装置,请附上你的参考文件。 谢谢, 纳加拉杰 以上来自于百度翻译 以下为原文 Hi, We try to program the CYPD212-24LQXITusing PSoC creator on a custom PCB using 5 pin connector, got a error “dbg.M0039: There was an error running port acquire. There may be no devices attached, or a device may be in use by another application” while programming the device, Please find attached file for your reference . Thanks, Nagaraj |
6个回答
这主要是因为硬件设计问题,检查XRE引脚连接和电源线,探测VTAG、XRES、SDA、SCL并查看是否有任何问题,或者在这里贴出自定义板的示意图,让社区专家检查和帮助您。
以上来自于百度翻译 以下为原文 This is mostly because of hardware design issue, check the XRES pin connection and power supply lines, probe the Vtag,XRES, SDA, SCL and see if any issue, or post the schematic of your custom board here to let the community experts to check and help you. |
dlkmad 发表于 2018-9-25 09:50 嗨,刘 SCL,SDA,ccg2_int连接到微控制器,请附上截图供您参考。 谢谢, 纳加拉杰 以上来自于百度翻译 以下为原文 Hi yliu, SDA,SCL,CCG2_INT connected to micro-controller, please find the attached screen shot for your reference. Thanks, Nagaraj |
嗨,Nagaraj, 您的PSoC程序员窗口具有以下状态: 正如你的示意图显示的电源是3.3V,PSoC程序员也显示3.4V是匹配的。 此外,我观察到PSoC程序员能够连接到MimePrim3设备。 在所有的硬件板上都观察到了吗? 你有没有柏柏尔的参考板,如果你可以尝试使用MixPro 3读取命令? 可以降低时钟速度旁边的列表框中可以配置的时钟速度吗? 谢谢和问候, 苏德希尔 以上来自于百度翻译 以下为原文 Hi Nagaraj, Your PSoC Programmer window has below status: As your schematic shows the power supply is 3.3V and the PSoC Programmer also shows 3.4V which is matching. Also, I observed that the PSoC Programmer is able to connect to the Miniprog3 device. Is it observed across all the hardware boards that you have? Do you have any reference boards from Cypress, if so can you try read command using the Miniprog3? Can you reduce the clock speed which can be configured in the list box next to the Clock Speed Thank You & Regards, Sudheer |
你好, 感谢回答,问题解决,复位引脚在板上发行,现在能够成功地编程CGG2设备。 谢谢, 纳加拉杰 以上来自于百度翻译 以下为原文 Hi, Thanks for reply, issue is solved, reset pin issue in board, Now able to program the CCG2 device successfully. Thanks, Nagaraj |
嗨,Nagaraj, 你能告诉我们到底是什么问题吗? 谢谢和问候, 苏德希尔 以上来自于百度翻译 以下为原文 Hi Nagaraj, Would you let us know what exactly is the issue? Thank you & Regards, Sudheer |
只有小组成员才能发言,加入小组>>
786个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7088 浏览 0 评论
2474 浏览 1 评论
2166 浏览 1 评论
4031 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2073 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7567浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6114浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
742浏览 2评论
710浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
7962浏览 2评论
/9
GMT+8, 2025-12-2 08:42 , Processed in 1.423631 second(s), Total 105, Slave 87 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1682
