电子发烧友论坛|
管理程序 - vSphere 6
VM OS - Windows 7 x64(仅安装了VNC和NVIDIA驱动程序以及VMware Tools的新安装)。 我可以在设备管理器中看到NVIDIA GRID K120Q和标准VGA,没有任何问题。 但当VM启动它时,它使用的是标准VGA。 我查看事件日志并出现此错误。 来源 - NVWMI 等级 - 警告 实例和方法提供程序注册失败 - (null)hr = 0xFFFFFFFA(-6) 任何帮助将提前感谢。 以上来自于谷歌翻译 以下为原文 Hypervisor - vSphere 6 VM OS - Windows 7 x64 (new install with only VNC and NVIDIA Driver and VMware Tools Installed). I can see both the NVIDIA GRID K120Q and Standard VGA in Device manager with no issues. But when the VM boots it's using the Standard VGA. I look at event logs and have this error. Source - NVWMI Level - Warning Instance and Method provider registration failed - (null) hr=0xFFFFFFFA (-6) Any help will be appreciated thanks in advance. |
13个回答
我也看到了这个问题。
VM将在登录时使用标准VGA,但是如果会话断开连接并再次重新连接,则使用VGPU。 任何帮助将不胜感激! 以上来自于谷歌翻译 以下为原文 I'm also seeing this issue. The VM will use the standard VGA on log in, however if the session is disconnected and reconnect again the VGPU is used instead. Any help would be greatly appreciated! |
我也看到了这个问题。
嗨伙计们 - 这是在View或XenDesktop下 - 以及哪些版本?
win7 + vSPhere + XenDesktop存在一个已知的MS问题:http://support.citrix.com/article/CTX201804 我将与开发人员核实是否已知NVWMI错误... 雷切尔 以上来自于谷歌翻译 以下为原文 Hi guys - is this under View or XenDesktop - and which versions? There's a known MS issue with win7+vSPhere+XenDesktop: http://support.citrix.com/article/CTX201804 I'll check with dev as to whether the NVWMI error is known... Rachel |
支持和开发回到我身边:
预计会出现NVWMI错误。 NVWMI要求正确安装NVIDIA Graphics驱动程序才能使用。 NVWMI在启动时加载,因此它不知道图形驱动程序是否安装正确, 它被升级为PM和文档,看看是否更好的文档。 或者长期的产品变更可以避免你达到这个目的。 听起来不错吗? 雷切尔 以上来自于谷歌翻译 以下为原文 support and dev have got back to me: The NVWMI error is expected. NVWMI requires the NVIDIA Graphics driver to be correctly installed in order to be used. NVWMI loads at start up so it does not know the difference whether the graphics driver is installed correctly or not, It's been escalated to PM and documentation to see if better doc. or long term product change could avoid you hitting this. Does that sound good? Rachel |
嗨雷切尔,
我的观点是6.2。 我从Vmware支持部门回复,并获悉他们的其他支持案例是通过NVIDIA解决的。 他们唯一的注意事项是NVIDIA提供了另一个不公开的驱动程序。 顺便说一句,如果我断开会话并重新连接一切正常工作。 以上来自于谷歌翻译 以下为原文 Hi Rachel, Mine is with View 6.2. I heard back from Vmware Support and was informed that the other support case they had was resolved through NVIDIA. Their only note was that NVIDIA provided another driver that is not publicly available. By the way, if I disconnect from the session and reconnect everything works as it should. |
支持已发布此协助:
http://nvidia.custhelp.com/app/answers/detail/a_id/4103/related/1 你能评论一下它是否有用吗? 雷切尔 以上来自于谷歌翻译 以下为原文 Support have issued this to assist: http://nvidia.custhelp.com/app/answers/detail/a_id/4103/related/1 Could you comment on whether it is helpful? Rachel |
这可能与大约6个月前的驱动程序版本中遇到的问题有关。
您能否具体询问VMware提供哪些驱动程序版本来解决此问题,以及任何案例参考。 以上来自于谷歌翻译 以下为原文 This possibly relates to an issue addressed in a driver release about 6 months ago. Can you ask VMware specifically what driver version was provided to fix this, and any case reference. |
嗨雷切尔和杰森,
VMware支持和我已经完成了安装以及日志,我们没有发现任何问题。 VMware支持没有更正此问题的驱动程序版本。 他们的客户关于VMware支持请求的最后一个注释是该问题已由NVIDIA提供的驱动程序解决。 K1 GRID卡和vGPU解决方案可以满足我的需求。 但是,我遇到的问题使我无法将其部署到生产环境中。 顺便说一句,我正在使用的驱动程序是2016年4月4日发布的版本362.13。 主机上安装的vGPU Manager版本为361.40。 以上来自于谷歌翻译 以下为原文 Hi Rachel and Jason, VMware Support and I have gone through the installation, as well as logs, and we did not find any issues. VMware Support did not have the driver version that corrected the problem. Their client's last note on the VMware Support Request was that the issue was resolved by a driver provided by NVIDIA. The K1 GRID card and vGPU solution performs pretty well for what I need. However, the issue I'm running into prevents me from deploying it into production. By the way, the drivers I'm using are version 362.13 released on 4/4/2016. The vGPU Manager version installed on the host is 361.40. |
尝试强制VIEW代理使用NvFBC。
下面链接的过程中的第5步。 https://kb.vmware.com/selfservice/microsites/search.do?language=en_US&cmd=displayKC&externalId=2125291 以上来自于谷歌翻译 以下为原文 Try forcing the VIEW Agent to use NvFBC. Step 5 in the process linked below. https://kb.vmware.com/selfservice/microsites/search.do?language=en_US&cmd=displayKC&externalId=2125291 |
我认为这与我遇到的问题完全相同:
https://communities.vmware.com/thread/540464 上述症状肯定是一个匹配。 有关KB 2125291的建议尚未解决此问题。 此问题目前阻止我部署到生产中。 VMware已经提出了一个支持案例。 有没有人有解决这个问题的方法? 谢谢 以上来自于谷歌翻译 以下为原文 I think this is exactly the same problem I am encountering as described here: https://communities.vmware.com/thread/540464 The symptoms described above are certainly a match. The suggestion referring to KB 2125291 has not resolved this for me. This issue is currently preventing me from deploying into production. A support case has been raised with VMware. Does anyone have a resolution to this issue? Thanks |
你好
如果您可以访问上面'vdi-guy'提到的驱动程序,请您联系我。 我需要掌握这些驱动程序来解决我们遇到此线程中描述的症状的问题。 如果您能提供这些“固定”驱动程序,请直接与PM联系,或发送电子邮件至:robertellisuk gmail com 非常感谢 罗伯特 以上来自于谷歌翻译 以下为原文 Hello If you have access to the drivers mentioned by 'vdi-guy' above, would you please contact me urgently. I need to get hold of these drivers to resolve an issue where we are experiencing exactly the symptoms described in this thread. If you can provide these 'fixed' drivers, PLEASE contact me urgently by PM or by email at: robertellisuk Many thanks Robert |
你好rellis12345678
我们的Poweredge 730和Nvidia GRID K1卡存在完全相同的问题。 你知道我能得到这些明确的司机吗? 我们的VM使用SVGA卡而不是Nvidia卡启动。 你能为我提供这些驱动程序的下载链接吗? 阿尔伯特 以上来自于谷歌翻译 以下为原文 Hello rellis12345678 We have the exact same problem with our Poweredge 730 and Nvidia GRID K1 card. Do you know were i can get these explicit drivers?. Our VM's boot up with the SVGA card and not the Nvidia card. Could you provide me a download link for these drivers?. Albert |
嗨艾伯特
不,我一直无法获得司机。 [注意 - 我也没有确切的证据证明它们存在。 我强烈怀疑他们这样做,但这是现阶段的传闻 NVIDIA目前坚持要求我们回到我们的服务器供应商。 在我们的情况下,这是惠普,所以我怀疑你会被引导回戴尔。 我还对VMWare社区网站中的NVIDIA驱动程序提出了一个观点,因为发布日期和版本编号存在一些问题,我想知道我正在寻找的驱动程序修复是否可能隐藏在视线之内。 请参阅此链接,第22项,并注意标记为6月2日发布的驱动程序: https://communities.vmware.com/thread/540464?start=15&tstart=0 我已经下载了这个,但还没有尝试过,因为我有一个待处理的VMWare支持案例,并且不希望云计算这个问题。 到目前为止,还没有人能够澄清版本号和发布日期之间的不匹配。 还只是为了澄清我们的症状可能与您的症状不完全相同 - 在我们的情况下,情况是NVIDIA驱动程序在会话重新连接时工作正常但在登录时未检测到(在注销或重新启动后)。 如果您无法让驱动程序在桌面内工作,则可能会遇到其他问题。 在您的情况下,断开并重新连接会话时会发生什么? 也就是说,考虑到我已经忍受的痛苦,试图解决这个问题,我肯定会告诉你我的进展情况,如果我们掌握了NVIDIA驱动程序修复程序,我将非常乐意与之分享 您。 请关注VMware社区网站,因为这是我将发布更新的地方(假设确实如此!) https://communities.vmware.com/thread/540464?start=15&tstart=0 祝你好运 最好 罗伯特 以上来自于谷歌翻译 以下为原文 Hi Albert No, I have been unable to obtain the drivers. [note - I also have no definitive evidence that they exist. I strongly suspect that they do but It's hearsay at this stage] NVIDIA are currently insisting we go back to our server vendor. In our case that is HP and so I suspect that you'd be directed back to Dell. I have also raised a point regarding the NVIDIA drivers in the VMWare communities site, because there is something awry with the release dates and version numbering, and I wondered if the driver fix I'm looking for might be hiding in plain sight. Please see this link, item 22, and note the driver marked as released 2nd June: https://communities.vmware.com/thread/540464?start=15&tstart=0 I've downloaded this already, but have yet to try it because I have a VMWare support case pending and don't want to cloud the issue. As yet no one has been able to clarify the mismatch between version numbers and release dates. Also just to clarify that our symptoms may not be exactly the same as yours - in our case the situation is that the NVIDIA driver works fine on a Session reconnect but is not detected on a Login (after logoff or reboot). If you can't get the driver to work at all inside the desktop, you may have a different issue. In your case, what happens when you disconnect and reconnect a session? That said, given the amount of pain I've already endured trying to get this resolved, I'll definitely keep you updated on my progress, and if we get hold of the NVIDIA driver fix I will be more than happy to share it with you. Please keep an eye on the VMware communities site as that is where I'll be posting updates as this moves forward (assuming it does!) https://communities.vmware.com/thread/540464?start=15&tstart=0 Good luck Best Robert |
只有小组成员才能发言,加入小组>>
使用Vsphere 6.5在Compute模式下使用2个M60卡遇到VM问题
3396 浏览 5 评论
是否有可能获得XenServer 7.1的GRID K2驱动程序?
3819 浏览 4 评论
/9
GMT+8, 2025-12-2 07:38 , Processed in 0.916941 second(s), Total 96, Slave 79 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2152
