我有点困惑 - 我们目前有几台2012 R2服务器,每台服务器都有一个网格k2。
驱动程序外部安装在物理服务器上,是否需要做其他事情以确保我的虚拟机正在使用网格卡? 在vm中我自己所见的设备管理器>图形适配器> citrix仅显示适配器和Microsoft RemoteFX图形设备= WDDM 还有一个额外的问题...在服务器本身应该禁用Microsoft基本显示适配器,因为我也看到显示适配器中列出的k2? 以上来自于谷歌翻译 以下为原文 Im a bit confused- we currently have a few 2012 R2 servers with a grid k2 in each server. outside of the driver installs on the physical server, is their anything else i need to do to make sure my vm's are utilizing the grid cards? within the vm's themselves all i see under device manager > graphics adapters> citrix display only adapter and Microsoft RemoteFX Graphics Device = WDDM also a bonus quuestion... on the server itself should i disable Microsoft basic display adapter since i also see the k2's listed in display adapters? |
4个回答
嗨奥兰,
首先,了解用例是什么有用? RDSH与XenApp? 问候 西蒙 以上来自于谷歌翻译 以下为原文 Hi Olan, first of all it would be helpful to know what is the use case? RDSH with XenApp? Regards Simon |
很抱歉,它是通过Xendesktop 7.13的MCS。
以上来自于谷歌翻译 以下为原文 Sorry about that- it is MCS via Xendesktop 7.13. |
None
以上来自于谷歌翻译 以下为原文 Hi Olan, unfortunately I still don't understand the full picture. Are you going to use client OS VDIs with RemoteFX and XenDesktop ? If yes which OS? With Hyper-V 2012 there is no GPU Passthrough or Nvidia GRID vGPU possibility available. The only possible option would therefore be RemoteFX which is only supported for client OS VMs. I've already had several cases where people tried to run RDSH VMs with RemoteFX.... There shouldn't be a need to disable the basic display adapter. Regards Simon |
Simon基本上回答了我的问题 - 是的,我们正在使用remotefx做客户端vm
我想我需要先考虑vgpu的优点,然后再考虑微软服务器2012之外的其他东西 以上来自于谷歌翻译 以下为原文 Simon that basically answers my question- yes we are doing client vm's with remotefx i guess i need to look into the advantages of vgpu before i consider something else besides microsoft server 2012 |
只有小组成员才能发言,加入小组>>
使用Vsphere 6.5在Compute模式下使用2个M60卡遇到VM问题
3396 浏览 5 评论
是否有可能获得XenServer 7.1的GRID K2驱动程序?
3818 浏览 4 评论
/9
GMT+8, 2025-12-1 11:12 , Processed in 0.909413 second(s), Total 78, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2686
