我用SPI协议将RFID RC522与PSoC 4套件进行接口。我经历了一些SPI主代码试图读取RFID,但混淆就像在SPI中使用SS引脚,但RC522没有SS引脚,其他事情是什么关于IRQ和RFID的复位引脚。如何连接这些引脚和代码是什么。我想把这个标签打印到串口监视器中,请帮我或提供例子来实现这个。
以上来自于百度翻译 以下为原文 I am interfacing RFID RC522 with psoc 4 kit using SPI protocol. I gone through some SPI master code an try to read RFID but confusion is like that In spi it uses SS pin but RC522 does not have SS pin and other thing is what about IRQ and Reset pins of RFID. How to connect this pins and what would be the code for that. I want ti print that Tag into Serial Monitor Please help me or provide example to implement this. |
7个回答
SS是一种使用几个引脚来指定SPI发送数据的多个芯片的芯片的方法。如果你的RFID芯片总是基于时钟线进行通信/读/写,那么SS线就不需要了。
您可以手动控制GPIO引脚上的RESET PIN,然后只需编程代码就可以用它做您想要的。 这听起来像阿杜诺示范课程:阿杜诺游乐场-MFRC522 将有你正在寻找的信息。试着阅读那里的信息,看看你是否能成功。 以上来自于百度翻译 以下为原文 SS is a method of using a few pins to designate which chip of multiple chips that the SPI is sending data to. If your RFID chip is always communicating/reading/writing based on the clock line, then the SS line is not needed. You can manually control the Reset pin on a GPIO pin, and then just program the code to do what you want with it. It sounds like this arduino example course: Arduino Playground - MFRC522 will have the information you are looking for. Try reading the information there, and see if you can't get it going |
如果您使用PSOC4 SCB SPI作为主机,您可以选择SS的数量为“0”。
以上来自于百度翻译 以下为原文 If you are using PSoC4 SCB SPI as a master, you could select '0' for number of SS. |
我已经尝试过,让奴隶数量0。但它对我们不起作用。 以上来自于百度翻译 以下为原文 I have tried it by making number of slaves 0. but It did not work for us. |
yuhe82 发表于 2018-9-17 12:48 我读过这个。并尝试实现这一点。但是读复位引脚的状态是什么? 以上来自于百度翻译 以下为原文 I have read this. And try to implement this. But what is state of reset pin when it is reading? |
许多芯片使用复位为低电平;当复位引脚被拉低时,芯片复位。我怀疑重置引脚是高的,除非你遇到错误/麻烦,然后你可以重置芯片,试图解决这个问题。 以上来自于百度翻译 以下为原文 A lot of chips use the reset as active-low; When the reset pin is pulled low, the chip resets. I suspect the reset pin is HIGH unless you run into errors/trouble, and then you can reset the chip to try to fix the issue. |
yuhe82 发表于 2018-9-17 13:47 我已经尝试了I2C和SPI…但没有一个为我工作…I2C,我使用的代码是在http://www. elmTun.14.com .com /社区/线程/ 26606 / L/PSoC - 4先锋- KIT-CultoType项目08-1近场通信-NFC… 以上来自于百度翻译 以下为原文 I have tried for both I2C and SPI..but none of them work for me.....For i2c i am using the code that is given in https://www.element14.com/community/thread/26606/l/psoc-4-pioneer-kit-community-project081-near-field-communication-nfc-… |
khgsf 发表于 2018-9-17 14:03 I2C或SPI得到任何ACK吗? I2C/SPI通信引起的问题失败了,还是有些配置不合适? 谢谢, 赖安 以上来自于百度翻译 以下为原文 Did I2C or SPI get any ACK? Is the issue caused by I2C/SPI communication failed, or some configurations are not suitable? Thanks, Ryan |
只有小组成员才能发言,加入小组>>
719个成员聚集在这个小组
加入小组1913 浏览 1 评论
1667 浏览 1 评论
3419 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
1584 浏览 6 评论
1389 浏览 1 评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
210浏览 2评论
195浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
343浏览 2评论
368浏览 1评论
76浏览 1评论
GMT+8, 2024-5-15 11:09 , Processed in 0.868085 second(s), Total 89, Slave 72 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
