你好,
我的设备不需要在某个时间打开蓝牙,比如每天从00点到8点,但是它应该唤醒传感器来记录这个值。蓝牙协议栈能单独关闭以节省电力吗?如何? 谢谢。 以上来自于百度翻译 以下为原文 Hi , My device has no need to open bluetooth at some time like from 00:00 - 8:00 everyday, but it should be awake for sensor to record the value. Can the bluetooth stack be closed alone to save the power? How to? thanks. |
6个回答
你的意思是,你需要一直运行应用程序,但只是关闭RF部分的时间?
以上来自于百度翻译 以下为原文 Do you mean you need to run the application all the time but just shut down the RF part some time? |
嗨,ZHXH。 对。 是否可以降低RF关闭时的MCU速度? 在S15模式下,J15应该测量多少电流? 以上来自于百度翻译 以下为原文 Hi zhxh. Yes. And is it possible to lower down the MCU speed when RF closed? And How many current should be measured at J15 while SDS mode? |
HCLK将不会在睡眠模式下运行。对于低功耗模式,您可以参考低功耗模式的文档,以及如何使用它。 HTTP://www. CyPress .COM/FIL/415986/下载 电流约为1.5 UA地板电流,3通道ADV在100毫秒间隔约为30 UA。您可以在自己的板上测试应用程序。 以上来自于百度翻译 以下为原文 The HCLK will not run in the sleep mode. For the low power mode, you may refer to this document for the low power mode and how to use it. http://www.cypress.com/file/415986/download The current is about 1.5 uA floor current and 3 channel adv at 100 ms interval is about 30 uA. You can test on your own board for your application. |
surezc 发表于 2018-9-17 09:16 你好,ZHXH, 对不起,我无法理解PMU低功耗模式文档。我不知道如何在这些电源模式之间切换。 你的意思是我应该把WICEDED SLIPEPAREDEDY关闭,而不是在SIPEPHIMPITEL处理程序中关机?然后MCU将运行我自己的应用程序,RF将被关闭?当关闭时间结束时,如何重新启动蓝牙堆栈?绑定一个GPIO作为唤醒源并使其水平改变? 谢谢 以上来自于百度翻译 以下为原文 Hi zhxh, Sorry I can't understand the PMU low_power mode document. I dont know how to switch between these power modes. Do you mean I should return WICED_SLEEP_ALLOWED_WITHOUT_SHUTDOWN not WICED_SLEEP_ALLOWED_WITH_SHUTDOWN in the sleep_permit_handler ? Then the mcu will running my own application and the RF will be closed? When the closing time is ended, How to restart the bluetooth stack? Bond a GPIO as wakeup source and give it a level changing? Thanks |
otinn 发表于 2018-9-17 09:28 WiDeDeSeLePyPaldEdOutOutExp-该模式将关闭外围设备,包括与G-传感器通信所需的SPI。 以上来自于百度翻译 以下为原文 WICED_SLEEP_ALLOWED_WITHOUT_SHUTDOWN - this mode will close the peripherals including SPI what I need to communicat with g-sensor. |
你需要在你的应用程序中使用WieDeSeLePyPosidEx。在WSDE SDK中不能选择电源模式。该设备将自动选择。 你只需要停止ADV并扫描关闭RF部分。你可以在需要的时候开始做广告。 以上来自于百度翻译 以下为原文 You need to use WICED_SLEEP_ALLOWED_WITHOUT_SHUTDOWN in your application. The power modes can't be selected in the Wiced SDK. The device will choose it automatically. You just need to stop the adv and scan to shut down the RF part. You can start advertising when you need. |
只有小组成员才能发言,加入小组>>
752个成员聚集在这个小组
加入小组2081 浏览 1 评论
1833 浏览 1 评论
3648 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
1773 浏览 6 评论
1520 浏览 1 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
531浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
385浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
421浏览 2评论
367浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
879浏览 2评论
GMT+8, 2024-12-2 23:11 , Processed in 0.814013 second(s), Total 59, Slave 52 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
