晚上好!
我在FX3S 4线MICROSD PCB设计中,将FX3S连接到MICROSD插座上????虽然在这个线程中考虑了低电压(1.8V),但是使用3.3V与图像一致。 SD卡被初始化为尽可能简单,没有错误,LA。 CYU3PSIbTNFPARAMSART国际标准化组织; EnfPARAM.RESETGPIO=0xFF; ItfPARAMS.rStasthy= Cytru; CytDeType=CyuU3PysibDebug; 电压分布; ILFPARAMS.LVGPIOSTATOR= CyFLUE; 书面陈述; 低电压=CyFalm; IsDR=CyFrE; MnFrQq=CyuU3pSi-BiFRQ2626MHz; CtdiiTrime= 0; ErnO1= CYU3PSIBSEtiN FPARAMS(0,&; Ern11=CYU3PSIBSTART() 但是,尝试查询设备总是会产生错误0x68。 静态CYU3PSIBDEVIN FILT GLDVENFION//*结构来保存设备信息*/ errno3 = cyu3psibquerydevice(0,&;gldevinfo); 我忽视了一些简单的东西吗? 蒂亚 以上来自于百度翻译 以下为原文 Good evening! I have wired FX3S to a microSD socket consistent with the diagram in FX3S 4-Wire microSD PCB Design ??? . Though low voltage (1.8v) was considered in this thread, 3.3v was used consistent with the image. The SD card is initialized as simply as possible, and without error, a la CyU3PSibIntfParams_t intfParams; intfParams.resetGpio = 0xFF; intfParams.rstActHigh = CyTrue; intfParams.cardDetType = CY_U3P_SIB_DETECT_NONE; intfParams.voltageSwGpio = 0xFF; intfParams.lvGpioState = CyFalse; intfParams.writeProtEnable = CyFalse; intfParams.lowVoltage = CyFalse; intfParams.useDdr = CyFalse; intfParams.maxFreq = CY_U3P_SIB_FREQ_26MHZ; intfParams.cardInitDelay = 0; errno1 = CyU3PSibSetIntfParams (0, &intfParams); errno1 |= CyU3PSibStart () However, attempting to query the device always yields error 0x68 static CyU3PSibDevInfo_t glDevInfo; /* Structure to hold device info */ errno3 = CyU3PSibQueryDevice (0, &glDevInfo); Am I overlooking something simple? TIA |
4个回答
你好,合成器,
代码片段看起来很好。 我会尝试复制它并回到你身边。 当做, 斯里达尔 以上来自于百度翻译 以下为原文 Hello Synths, The code snippet looks fine. I will try to reproduce it and get back to you. Regards, Sridhar |
我怀疑uhs-1卡,我用的是不能够被连接在固定的3.3V。我会尝试与3.3V microSD标准今天。 编辑:不,同样的问题。 以上来自于百度翻译 以下为原文 I suspect that the UHS-1 card which I am using is not able to be interfaced at fixed 3.3V. I will try with a 3.3V microSD standard today. Edit: No, same problem. |
合成器, 我已经修改了有你提到的在FX3S FPGA开发板测试参数的FX3海量存储的例子(点击这个http://www.cypress.com/products/ez-u***-fx3s选择组件”选项卡)。 我可以看到它正在正常工作。 请在你的站台上查一下。简要介绍一下你的硬件和软件,用于测试。 让我知道你是检查以下你的API的返回值吗?是否通过JTAG调试或UART调试打印? A.CuU3PSIbStItIn FPARAMS CYU3PSIBSTART CYU3PSI器件 这里是debugprints显示参数查询通过cyu3psibquerydevice API。 ---------------------------------------------------------------------------------- 在端口0找到了一个设备 类型=2,NUBLKS=1006592,EraseSe==32768,CKRATER=24000000 BLKLEN=512可移除=1,可写=1,锁定=0 DDRMODE=0,OpValk=0,总线宽度=1,NUMNATE=2 CARCCMDCH类=1525 开发0、0单元:位置= 0 = 503296 ---------------------------------- numblocks 在端口0找到了一个设备 类型=2,NUBLKS=1006592,EraseSe==32768,CKRATER DEV 0:发现用户分区 DEV 0,单元1:位置=0个数字块=503232 DEV 0:发现用户分区 DEV 0,第0单元:BLKSIZE=512 NUBBASIC=503296 DEV 0,第1单元:BLKSIZE=512 NUBBASIC=503232 在端口1找到了一个设备 类型= 2,numblks = 124735488,erasesize = 16777216,clkrate = 24000000 BLKLEN=512可移除=1,可写=1,锁定=0 DDRMODE=0,OpValk=0,总线宽度=1,NUMNATE=2 CARCCMDCH类=1461 DEV 1,单元0:位置=0个数字块=62367744 DEV 1:发现用户分区 DEV 1,单元1:位置=0个数字块=62367680 DEV 1:发现用户分区 DEV 1,第0单元:BLKSIZE=512 NUBBASIC=62367744 DEV 1,第1单元:BLKSIZE=512 NUBBASIC=62367680 调用USB连接 接收USB事件0 完成USB设置配置 ----------------------------------------------------------------------------------------------------------------------------------------- FX3SMASTSTARG.RAR 511.3 K 以上来自于百度翻译 以下为原文 Synths, I have modified the FX3 Mass Storage example provided with the parameters you mentioned above and tested on the FX3S FPGA Development board (Click this http://www.cypress.com/products/ez-u***-fx3s and select Kits Tab). I can see that it is working as expected. Please check this on your platform. Brief us about your hardware and software that are using for testing. Let me know how you are checking the return values of the following APIs in your case? is it through JTAG Debugging or UART Debug Prints? a. CyU3PSibSetIntfParams b. CyU3PSibStart c. CyU3PSibQueryDevice Here is the debugprints shows the parameters queried through CyU3PSibQueryDevice API. ---------------------------------------------------------------------------------- Found a device on port 0 Type=2, numBlks=1006592, eraseSize=32768, clkRate=24000000 blkLen=512 removable=1, writeable=1, locked=0 ddrMode=0, opVoltage=0, busWidth=1, numUnits=2 cardCmdClass=1525 Dev 0, Unit 0: location=0 numBlocks=503296---------------------------------- Found a device on port 0 Type=2, numBlks=1006592, eraseSize=32768, clkRate Dev 0: Found user partition Dev 0, Unit 1: location=0 numBlocks=503232 Dev 0: Found user partition Dev 0, Unit 0: blkSize=512 numBlocks=503296 Dev 0, Unit 1: blkSize=512 numBlocks=503232 Found a device on port 1 Type=2, numBlks=124735488, eraseSize=16777216, clkRate=24000000 blkLen=512 removable=1, writeable=1, locked=0 ddrMode=0, opVoltage=0, busWidth=1, numUnits=2 cardCmdClass=1461 Dev 1, Unit 0: location=0 numBlocks=62367744 Dev 1: Found user partition Dev 1, Unit 1: location=0 numBlocks=62367680 Dev 1: Found user partition Dev 1, Unit 0: blkSize=512 numBlocks=62367744 Dev 1, Unit 1: blkSize=512 numBlocks=62367680 Calling USB Connect USB event 0 received USB Set Config completed -----------------------------------------------------------------------------------------------------------------------------------------
yahan52 发表于 2018-9-6 07:26 感谢您在FX3S SDK上验证此代码。 在将初始化和查询代码从AppnIIT初始化函数移动到我的循环线程之后,我才能够成功地查询设备。我有三个理论来解释为什么这能奏效: 初始化和查询依赖于init码幂竞争的其他方面的时间要求 而且,既然你问了,我乐于分享,我有一个在FPGA触摸屏的驱动,我用调试(下)。 以上来自于百度翻译 以下为原文 Thank you for verifying this code on the FX3S SDK. I was able to successfully query the device only after moving the initialization and query code from ApplnInit initialization function to my looping thread. I have three theories as to why this could have worked:
And, since you asked, I am happy to share that I have an onboard FPGA-driven touchscreen, which I am using for debug (below). |
只有小组成员才能发言,加入小组>>
745个成员聚集在这个小组
加入小组2033 浏览 1 评论
1788 浏览 1 评论
3595 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
1718 浏览 6 评论
1485 浏览 1 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
439浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
307浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
382浏览 2评论
323浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
540浏览 2评论
GMT+8, 2024-10-19 22:01 , Processed in 0.778161 second(s), Total 52, Slave 46 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
