我用s29gl512m NOR闪存,这是工作好的开始但我现在不能抹去它,它是示值误差消除。
以上来自于百度翻译 以下为原文 i am using S29GL512M nor flash, it was working ok initially but now im not able to erase it ,it is showing error in erasing. |
5个回答
你好
感谢您联系柏树社区论坛。请把失败的屏幕截图和你发出的所有步骤发送给我们。 谢谢你 当做, 布沙拉 以上来自于百度翻译 以下为原文 Hello Thank you for contacting Cypress Community Forum. Please send us the screen shot of the failure and all the steps you are issuing for the erase. Thank you Regards, Bushra |
你好 我附上了失败的屏幕截图,亲切地回复。 NOR闪存 106 K 以上来自于百度翻译 以下为原文 Hello I have attached the screen shot of failure , kindly revert.
你好, 谢谢屏幕截图。日志说“擦除64个扇区”,所以擦除是有效的。 我有一些问题和要求如下。 1)闪光灯S29 GL512N11FFI010的完整部件号 2)你说:“开始工作还行。”这是否意味着你可以擦除/编程几次或仅仅一次? 3)你能运行“MD”命令检查闪存是否真正擦除后擦除命令(Flash内容应全部0xFF) 4)你能运行“CMP”来检查“CP.B”命令停在何处吗? 最好的问候, 尊礼 以上来自于百度翻译 以下为原文 Hi, Thanks for the screenshot. The log says that "Erased 64 sectors" so erase is working. I have some questions and requests below. 1) Full part number of the Flash like S29GL512N11FFI010 2) You said "it was working ok initially...". Does it mean you could erase/program several times or just one time? 3) Could you run the "md" command to check if the Flash is really erased after erase command (Flash content should be all 0xFF) 4) Could you run the "cmp" to check where the "cp.b" command stopped Best Regards, Takahiro |
你好 零件号s29gl512t11tfiv10。问题即将来临。 编程/擦除首次请查收附件。 运行MD CMD时的截图 当做 周三,Jun 27,2018在上午11点53分,tkuw <;社区经理@柏。COM & gt; MD JPG 71.8 K Eras.jPG 74.6 K 以上来自于百度翻译 以下为原文 Hello The part number is S29GL512T11TFIV10. The issue is coming in programming/erasing for the first time.Please find attachments of screenshots when we run md cmd Regards On Wed, Jun 27, 2018 at 11:53 AM, tkuw <community-manager@cypress.com> |
你好, 谢谢你提供的信息。您的MD命令结果显示该设备处于ID-CFI读取模式,而不是主闪存阵列读取模式。我认为U-BooD发出ID/CFI入口命令,然后读取设备ID来识别Flash。要返回主闪存阵列,需要重置或退出命令。请确保在U-BooD中的闪存驱动程序在读取设备ID后发出重置/退出。 最好的问候, 尊礼 以上来自于百度翻译 以下为原文 Hello, Thanks for the info. Your md command result shows that the device is in ID-CFI read mode instead of main Flash array read mode. I think U-Boot issues ID/ CFI entry command and then read device IDs to identify the Flash. To return to the main Flash array, Reset or Exit command is required. Please make sure your Flash driver in U-Boot issues Reset/Exit after reading device IDs. Best Regards, Takahiro |
只有小组成员才能发言,加入小组>>
751个成员聚集在这个小组
加入小组2064 浏览 1 评论
1824 浏览 1 评论
3632 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
1760 浏览 6 评论
1508 浏览 1 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
502浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
354浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
409浏览 2评论
354浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
851浏览 2评论
GMT+8, 2024-11-20 01:35 , Processed in 0.974213 second(s), Total 86, Slave 70 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
