电子发烧友论坛|
下面是epwm的设置,我画了一个图,麻烦看看是不是这样,我自己感觉不是很正确
//time Base SubModule Register (*ePWM[n+1]).TBCTL.bit.PRDLD = TB_SHADOW; //Load from its Shadow Register (*ePWM[n+1]).TBPRD = period-1; (*ePWM[n+1]).TBPHS.half.TBPHS = 0; (*ePWM[n+1]).TBCTR = 0; (*ePWM[n+1]).TBCTL.bit.CTRMODE = TB_COUNT_UP; (*ePWM[n+1]).TBCTL.bit.PHSEN = TB_ENABLE; (*ePWM[n+1]).TBCTL.bit.SYNCOSEL = TB_SYNC_IN; // Sync "flow through" mode (*ePWM[n+1]).TBCTL.bit.HSPCLKDIV = TB_DIV1; (*ePWM[n+1]).TBCTL.bit.CLKDIV = TB_DIV1; // Counter compare submodule registers (*ePWM[n+1]).CMPA.half.CMPA = period + 10; // Initial value (*ePWM[n+1]).CMPB = 20; // Initial value (*ePWM[n+1]).CMPCTL.bit.LOADAMODE = CC_CTR_ZERO; // Load on CTR = Zero:TBCTR = Ox0000 (*ePWM[n+1]).CMPCTL.bit.SHDWAMODE = CC_SHADOW; // Shadow mode (*ePWM[n+1]).CMPCTL.bit.LOADBMODE = CC_CTR_ZERO; (*ePWM[n+1]).CMPCTL.bit.SHDWBMODE = CC_SHADOW; // Action Qualifier SubModule Registers (*ePWM[n+1]).AQCTLA.bit.CAU = AQ_SET; (*ePWM[n+1]).AQCTLA.bit.CBU = AQ_CLEAR; (*ePWM[n+1]).AQCTLA.bit.ZRO = AQ_CLEAR; (*ePWM[n+1]).AQCTLA.bit.PRD = AQ_CLEAR; (*ePWM[n+1]).AQCTLB.bit.CBU = AQ_SET; (*ePWM[n+1]).AQCTLB.bit.CAU = AQ_CLEAR; (*ePWM[n+1]).AQCTLB.bit.ZRO = AQ_CLEAR; (*ePWM[n+1]).AQCTLB.bit.PRD = AQ_CLEAR; keep on studying |
7 个讨论
只有小组成员才能发言,加入小组>>
590 浏览 0 评论
1645 浏览 0 评论
2084 浏览 0 评论
为啥BQ7693003DBTR芯片在和BQ769X0盒子通讯时收不到信号?
1537 浏览 0 评论
DSP 28027F 开发板 XDS100v2调试探针诊断日志显示了 Error -150 (SC_ERR_FTDI_FAIL)如何解决
1376 浏览 0 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
1788浏览 29评论
2816浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
1746浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
1662浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
1676浏览 13评论
/9
GMT+8, 2025-12-12 04:09 , Processed in 0.981935 second(s), Total 73, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3144
