你好,
我使用的是USP3开发工具包的格子(格子UB3视频桥开发工具包-格子半导体)。我计划把它最后连接到树莓PI,以便流HDMI输入。 而我能够运行没有任何问题在Windows设备的视频输入,它不会与任何Linux设备我试过。 我配置的电极输出640x480p @ 60Hz。可以使用Windows的USB 2端口。 首先我想让它与rapberry PI图3b +运行Raspbian直接工作(Debian伸展),它列出了视频输入($ ls / dev /视频)但不可能使用任何进一步的。 第二我试图连接开发工具在PC上运行Ubuntu 16.04,这里甚至没有认识到作为一个视频输入。我错过司机了吗? 我总是认为,与CX3什么应该运行“开箱”如果它被配置为UVC设备吗? 就像我说的,我真的很想把它与Raspberry Pi合作,但也许更容易从PC? 最好的问候, 维图斯 以上来自于百度翻译 以下为原文 Hello, I am using the USB3 Development Kit by Lattice (Lattice USB3 Video Bridge Development Kit - Lattice Semiconductor ). I plan to connect it ultimatly to a raspberry Pi in order to Stream the HDMI Input. While I am able to run it without any Problems as a videoinput on a Windows Device, it wont work with any Linux Device I tried. I configured the CX3 output to 640x480p@60Hz. It was possible to use the Windows USB 2.0 Port with. First I tried to get it work directly with the Rapberry Pi 3b+ running Raspbian (debian stretch), where it lists as video input ( $ ls /dev/video* ) but is not possible to use any further. Second I tried to connect the Development Kit on PC running Ubuntu 16.04, here it is not even recognized as a video Input. Am I missing drivers? I always though, anything with the cx3 should run "out of the box" if it is configured as a UVC-Device? As I said, I would really like to get it working with the Raspberry Pi, but maybe its easier to start with the PC? Best Regards, Vitus |
8个回答
你好,Vitus,
如果它工作正常,请尝试在一个USB2.0端口一个Ubuntu的PC和检查。 另外,请确认您是否是,如果任何应用程序注意固件使用例子使用FX3和CX3装置。 最好的问候, 斯里纳斯 以上来自于百度翻译 以下为原文 Hello Vitus, - Please try on a Ubuntu PC on a USB 2.0 port and check if it is working fine. - Also, kindly, confirm if you are using FX3 or the CX3 device and if any app note firmware example is being used. Best regards, Srinath S |
wangcong12138 发表于 2018-8-18 00:40 你好,Srinath, 关于混乱,对不起,我使用的是FX3装置。我使用的是格式化软件(HTTP://www. LaTeleSeM.COM/En/FielExver)?Media= {9B5BD0C2-27 B1-4FBB-BF93-8249968 DE1D2}和DooptTrnId=50810) 我也只能在Ubuntu PC上试用3个端口,因为我的可用PC没有任何USB 2端口。 最好的问候, 维图斯 以上来自于百度翻译 以下为原文 Hello Srinath, Sorry about the confusion, I am using an FX3 Device. I am using software supplied by Lattice (http://www.latticesemi.com/en/FileExplorer?media={9B5BD0C2-27B1-4FBB-BF93-8729968DE1D2}&document_id=50810) Also I can only try it on an Ubuntu PC with 3.0 Ports at the moment, because my available PC does not have any USB 2.0 Ports Best Regards, Vitus |
燕子湖畔 发表于 2018-8-18 00:50 你好,Vitus, -我想知道您是否使用了来自CyPress提供的例子中的固件。对于您的信息,AN75 79APP Note为UVC应用提供了一个示例固件。 此外,请使用CYU3PUBICONTCONSTATE()API禁用设备中的USB 3模式。这将导致设备在USB2.0模式下运行。请在这种情况下检查设备是否在Ubuntu PC上被识别。 最好的问候, 斯里纳斯 以上来自于百度翻译 以下为原文 Hello Vitus, - I wanted to know if you are using the firmware from any of the Cypress provided examples. For your information, AN75779 App Note provides an example firmware for UVC application. - Also, can you please disable the USB 3.0 mode in your device using the CyU3PU***ConnectState() API. This would cause the device to function in USB2.0 mode. Kindly, check if the device is recognized on the Ubuntu PC under this condition. Best regards, Srinath S |
wangcong12138 发表于 2018-8-18 01:09 你好,Srinath, 为了建立USB 2连接,我使用了USB 2电缆。在Ubuntu设备上,它现在被恢复为/DEV/VIDO0,但与树莓相同,我不能打开流。 使用的固件是由第三方开发的。 最好的问候, 维图斯 以上来自于百度翻译 以下为原文 Hello Srinath, I used an USB 2.0 Cable in order to establish an USB 2.0 connection. On the Ubuntu Device it is now recoginized as /dev/video0 but same as with the Raspberry I cant open the Stream. The used Firmware was developed by a third party. Best Regards, Vitus |
燕子湖畔 发表于 2018-8-18 01:18 嗨,Vitus, 你可以在Ubuntu系统流16.0.4 USB 2电缆的视频吗? 你能描述一下你的申请吗? 我以为你是流从第三方视频源的视频流到Raspberry Pi的格子板。请参考附图,证实我的假设。 感谢和问候 阿比纳夫 应用PNG 13 K 以上来自于百度翻译 以下为原文 Hi Vitus, Are you able to stream the Video on Ubuntu 16.0.4 system with USB 2.0 cable? Could you please delineate about your application. I assume that you are streaming OUT video from third party video source and streaming it to Raspberry Pi via Lattice board. Please refer to the attached figure and confirm my assumption. Thanks & Regards Abhinav
嗨,Abhinav, 我的设置是: 路视频源——HDMI & gt;latticeboard --- USB & gt;Raspberry Pi(运行Raspbian伸展) 和 路视频源——HDMI & gt;latticeboard --- USB & gt;PC(运行Ubuntu 16.04.4) 我的意图是流传入的视频然后在我的网络媒体流。 我没能流视频在Ubuntu系统的USB2.0电缆。 最好的问候, 维图斯 以上来自于百度翻译 以下为原文 Hi Abhinav, Excactly, My Setup is: Videosource ---HDMI-> LatticeBoard ---USB-> Raspberry Pi (Running Raspbian Stretch) and Videosource ---HDMI-> LatticeBoard ---USB-> PC (Running Ubuntu 16.04.4) My intention is to stream the incoming video then as a media stream in my network. I was not able to stream the Video with a USB2.0 cable on the Ubuntu system. Best Regards, Vitus |
燕子湖畔 发表于 2018-8-18 01:36 嗨,Vitus, 请检查视频带宽,你想流通过USB 2。它必须小于USB2.0即480 MB/s最大带宽,如果可能的话,尽量降低视频的FPS,你流。 感谢和问候 阿比纳夫 以上来自于百度翻译 以下为原文 Hi Vitus, Please check the bandwidth of video that you are trying to stream via USB 2.0. It has to be less than the maximum bandwidth of USB 2.0 i.e 480 MB/S. If possible, try to decrease the FPS of the video that you are streaming. Thanks & Regards Abhinav |
ldliu 发表于 2018-8-18 01:44 你好,Abhinav, 降低带宽不改变结局(我使用800x600 25FPS)。 我得到以下错误代码: V4L2:无法打开“/ dev / video0”:无法分配请求的地址 有什么建议吗? 最好的问候, 维图斯 以上来自于百度翻译 以下为原文 Hello Abhinav, decreasing the bandwidth does not change the outcome (I use 800x600 25fps). I get the following Errorcode: v4l2: unable to open '/dev/video0': Cannot assign requested address Any suggestions about that? Best Regards, Vitus |
只有小组成员才能发言,加入小组>>
754个成员聚集在这个小组
加入小组2101 浏览 1 评论
1848 浏览 1 评论
3666 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
1783 浏览 6 评论
1533 浏览 1 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
564浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
418浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
434浏览 2评论
380浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
909浏览 2评论
GMT+8, 2024-12-21 11:54 , Processed in 1.173011 second(s), Total 90, Slave 74 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
