电子发烧友论坛|
大家好,
我想创建一个项目,我需要的声音以及从GPIF的视频,我使用EZ-USB FX3板 你能提供一个例子,结合UVC和UAC和输入从GPIF? 谢谢 以上来自于百度翻译 以下为原文 Hello Everyone, I want to create a project in which i need sound as well as video from the gpif, i am using EZ-USB FX3 board Can you please provide an example for combine UVC and UAC and input taken from GPIF? Thanks |
12个回答
你好,Sagar Lakhani,
我们没有任何实例工程,UVC和UAC功能相结合。 在我们的SDK中,我们有独立的UVC和UAC例子。客户可以参考这些并开始。 建议: 如果你在设计一个FPGA,FPGA可以设置两个通道(一个用于视频和音频)和使用GPIF Slave FIFO接口传输视频和音频数据。 例如,我们可以设置两管FX3,一个音频和视频,而FPGA可以发送视频数据的一个框架,并在框架的一端可以发送音频数据对应于另一管架(通道)。 所以,对于UVC + UAC设备最好的选择是使用FPGA和从属FIFO接口,使用双通道视频流和音频数据对GPIF接口本身。在这里,两个通道可以自动通道,可以实现高吞吐量。 如果这是不可能的,我们可以使用标准的图像传感器接口(Fv /低压/ PCLK)把视频数据通过GPIF。并使用SPI进行音频数据的处理。但我们必须小心不要介绍音频数据通道处理的延迟,使它不影响视频数据通道。 当做, Anil Srinivas。 以上来自于百度翻译 以下为原文 Hello Sagar Lakhani, We do not have any example project where UVC and UAC functionalities are combined. We have separate UVC and UAC examples in our SDK. The customer can refer to these and get started. suggestion: If you have an FPGA in your design, the FPGA can setup two channels (one for video and one for audio) and use the GPIF slave fifo interface to transfer both video and audio data. For example, we can setup two pipes in FX3, one for audio and one for video, and the FPGA can send out one frame of video data, and at the end of the frame it can send out the audio data corresponding to that frame on the other pipe (channel). So, the best option for a UVC+UAC device would be to use a FPGA and a slave fifo interface and use two channels to stream video and audio data on the GPIF interface itself. Here, both channels could be auto channels and we can achieve high throughput. If that is not possible, we can use the standard image sensor interface (FV/LV/PCLK) and take in video data through GPIF. And use SPI for audio data. But we should be careful not to introduce processing delays in the audio data channel, so that it does not affect the video data channel. Regards, Anil Srinivas. |
Emily1225 发表于 2018-8-20 05:23 嗨,阿尼, 谢谢你的建议,我想问一下,如果我的32位GPIF输入包含视频以及音频和视频和音频数据是分不开的。我怎样才能让我的设备像UVC和UAC? 以上来自于百度翻译 以下为原文 Hi aani, Thanks for your suggestion, i want to ask that what if my 32 bit gpif input contain video as well as audio and video and audio data are inseperable. How can i make my device act like UVC and UAC? |
su56789 发表于 2018-8-20 05:40 嗨,Sagar Lakhani, 您使用的主机应用程序是什么? 你用的是哪个司机? 当做, Anil Sirnivas。 以上来自于百度翻译 以下为原文 Hi Sagar Lakhani, Which host application are you using? which driver are you using? Regards, Anil Sirnivas. |
嗨,阿尼, 我想用VLC对我的申请,根据主机的UVC驱动。 我有多个查询.. 如果我的32位数据,音频和视频,我让我的FX3器件作为紫外线装置,将我的VLC可以播放音频和视频使用单一UVC设备不需要UAC? 谢谢 以上来自于百度翻译 以下为原文 hi aani, i want to use vlc for my application and i am depending on the uvc driver on the host machine. and i have one more query that.. if my 32 bit data has both audio and video and i have made my FX3 device as a UVC device, will my vlc be able to play both audio and video using a single uvc device and not needing UAC? thanks |
你好, 如果你想要VLC能够播放音频和视频,你需要的是UVC和UAC设备。 当做, Anil Srinivas。 以上来自于百度翻译 以下为原文 Hi, If you want vlc be able to play both audio and video, you need both uvc and uac devices. Regards, Anil Srinivas. |
乐施会,请参考Cypress提供设备驱动程序的例子。我是一个设备驱动程序领域的初学者。 以上来自于百度翻译 以下为原文 ohk, can you please provide references and examples of cypress device driver. i am a total beginner in device driver field. |
你好, 1、请参考此路径中SDK提供的UVC示例:C:程序文件(x86) CyPress EZ-USB FX3 SDK 1.3 固件UVC3示例。 2、请参考此路径中SDK提供的UAC示例:C:程序文件(x86) CyPress EZ-USB FX3 SDK 1.3 固件UACX示例。 当做, Anil Srinivas。 以上来自于百度翻译 以下为原文 Hi, 1.Please refer the UVC examples provided with the SDK in this path: C:Program Files (x86)CypressEZ-USB FX3 SDK1.3firmwareuvc_examples. 2.Please refer the UAC examples provided with the SDK in this path: C:Program Files (x86)CypressEZ-USB FX3 SDK1.3firmwareuac_examples. Regards, Anil Srinivas. |
Emily1225 发表于 2018-8-20 06:37 你好,阿尼, 我问如何写柏树装置主机设备驱动程序。你已经提供了固件的例子。我想写我自己的设备驱动程序得到的音频和视频播放,并用VLC或自定义应用程序。请参考它的设备驱动程序和提供的例子。 谢谢 以上来自于百度翻译 以下为原文 hello aani, I have asked how to write device driver for host pc for cypress device. you have provided examples of firmware. i want to write my own device driver to get audio and video combined and then playing that with vlc or some custom application. Please provide any reference of device driver and example of it. thanks |
su56789 发表于 2018-8-20 06:43 你好, 请通过下面的链接,其中包含CyPress设备驱动文件。 “C: Program Files(x86) Cypress公司EZ-USB FX3 SDK 1.3 驱动程序” 当做, 阿尼尔斯里尼瓦斯 以上来自于百度翻译 以下为原文 Hi, Please go through the below link which contain cypress device driver file. "C:Program Files (x86)CypressEZ-USB FX3 SDK1.3driver" Regards, Anil Srinivas |
您只对Windows设备驱动程序有参考吗?我的工作是在Linux上,可以请你的Linux设备驱动程序提供参考?
谢谢 以上来自于百度翻译 以下为原文 Do you only have reference for windows device driver? i am working on linux and can you please provide linux device driver reference? thanks |
你好, 有没有单独的驱动程序,Linux。它的工作原理与默认libu***驱动。 安装Linux可以在以下链接:http://www.cypress.com/documentation/software-and-drivers/ez-u***-fx3-software-development-kit FX3 SDK 赛普拉斯开发包装使用libu***驱动程序,它可以用来开发在Linux环境下的主机应用程序。 当做, Anil Srinivas。 以上来自于百度翻译 以下为原文 Hi, There is no separate driver for Linux. It works with default Libu*** driver. Install the FX3 SDK for Linux available at the following link: http://www.cypress.com/documentation/software-and-drivers/ez-u***-fx3-software-development-kit Cypress has developed a wrapper using the LibUSB driver, which can be used to develop host applications in a Linux environment. Regards, Anil Srinivas. |
只有小组成员才能发言,加入小组>>
786个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7088 浏览 0 评论
2474 浏览 1 评论
2166 浏览 1 评论
4031 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2073 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7566浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6114浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
742浏览 2评论
710浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
7962浏览 2评论
/9
GMT+8, 2025-12-2 04:23 , Processed in 0.934934 second(s), Total 64, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
451
