我试过两OSX和Windows 10使用说明。我还安装了每个知识库平台的文件。在这两种情况下,WICE都无法下载或查看棋盘。我也试着让他们恢复健康。我怀疑这两板坏。
我错过了什么? 以上来自于百度翻译 以下为原文 I have tried both OSX and Windows 10 using the notes and instructions. I have also installed the platform files per the knowledge base. In both instances WICED can't download or see the boards. I have also tried putting them into recovery. I doubt that both boards are bad. What am I missing here? |
14个回答
你指的是这个KBA的下载编程的一个ez-bt WICED模块–kba223428
你可以附上截图你的SDK在Windows 10吗? 以上来自于百度翻译 以下为原文 Did you refer to this KBA for the download Programming an EZ-BT WICED Module – KBA223428 Can you attach a screenshot of your SDK in the windows 10 for us? |
是的,我提到了这一点,完全做到了。它似乎没有看到WestStudio中的模块。我没有问题,打开串口,所以我知道USB串口芯片似乎是工作。出于某种原因,Westice工作室不起作用。当设置波特率时,它不会得到回应。 你想要什么样的屏幕快照? 以上来自于百度翻译 以下为原文 Yes, I referred to that and did exactly all of that. It doesn't seem to see the module in wiced studio. I have no problem opening the serial ports so I know the u*** serial chip seems to be working. For some reason wiced studio doesn't work. It gets no response back when it sets the baud rate. What screen shot do you want? |
再次,我想这在Windows 10和Mac OS X具有相同的结果。我想知道如果它是迷你驱动相关的,也许这会是永远正确的安装在工厂。我有2个板,所以结果是一致的。 以上来自于百度翻译 以下为原文 Again, I have tried this on both windows 10 and Mac OS X with the same results. I am wondering if it is related to the mini driver and maybe this board was never setup right at the factory. I have 2 boards so the results are consistent with both. |
阿南科院 发表于 2018-8-15 07:23 请关闭PUART(SW5)并打开HCI UART(SW4)。 我只是尝试编程模块,我可以成功编程。由于我的手上没有EVE板,所以我使用了一个模块板并用USB到UART工具编程。 你能告诉我一个截图包含目标名称、平台文件和控制台信息如下: 以上来自于百度翻译 以下为原文 Please turn off the PUART(SW5) and turn on the HCI UART(SW4) when you program the board. I just tried to program the module and I can program it successfully. As I don't have the EVAL board on my hand, I use a module board and program it with a USB to UART tool. Could you show me a screenshot contains the make target name, the platform files and the console information as follows: |
surezc 发表于 2018-8-15 07:29 同样的结果。也试着把它放在恢复模式中。我知道司机似乎是安装正确的串行工具看到芯片。我还附加了检测日志。 detect.log.zip 932字节 以上来自于百度翻译 以下为原文 Same Results. Also tried putting it in recovery mode. I know the driver seems to be installed right as the serial tool sees the chip. I also attached the detect.log
你可以在设备管理器找到UART端口? 以上来自于百度翻译 以下为原文 Could you find the UART port in the device manager? |
是的,两端口应该有。我已经完成了所有的步骤。有什么不工作的权利。我认为USB串行芯片可能配置不正确。我用了一个终端程序来打开Coprts,我没有看到任何东西在一个示波器上出现在HCI UART RX TX或PUART RX TX上。这是可能的,他们从来没有在工厂里这样做过吗? 以上来自于百度翻译 以下为原文 Yes, 2 ports as there are supposed to be. I have done all the steps. There is something not working right. I am thinking the u***-serial chip may not be configured right. I used a terminal program to open the comports and I don't see anything coming through on an oscilloscope on either the hci uart rx tx or the puart rx tx. Is it possible, they never did that at the factory? |
阿南科院 发表于 2018-8-15 08:11 另一条信息是CY7C6215的RX和TX发光二极管在我的终端程序中使用CopRoT时没有点亮。 以上来自于百度翻译 以下为原文 One other piece of information is that the RX and TX leds of the CY7C65215 don't light up when I am using the comport in my terminal program with either port open. |
阿南科院 发表于 2018-8-15 08:11 我只是再次尝试了范围,并在终端程序打开和我打字,我看到数据通过罚款,所以它似乎是相关的WICE。 以上来自于百度翻译 以下为原文 I just tried again with the scope, and with the terminal program open and me typing, I see data come through fine, so it appears to be related to wiced. |
这里是一个逻辑分析仪跟踪从HCI UART当WICE Studio试图下载程序。它发送0x01 0x03 0x0c0x00,并且什么也得不到。它也似乎是映射COM11到HCI UART和COM8到PUART。我可以通过指定UART来绕过这个问题。 以上来自于百度翻译 以下为原文 Here is a logic analyzer trace from the hci uart when wiced studio tries to download the program. It sends 0x01 0x03 0x0C 0x00 and gets nothing back. It also seems to be mapping com11 to the hci uart and com8 to the puart. i can get around that, by specifying the uart. |
阿南科院 发表于 2018-8-15 08:46 你从哪里弄到演示板的?如果从分配你得到它们,请联系他们解决问题。如果你买他们从柏店,请创建的情况下系统的RMA请求获得一个新的董事会。 以上来自于百度翻译 以下为原文 Where did you get the demo board? If you get them from the distribute, please contact them to solve the problem. If you buy them from the Cypress Store, please create a RMA Request in the case system to get a new board. |
阿南科院 发表于 2018-8-15 08:46 约书亚 我们能够重现你的状态和找到工作来开启你的系统和力恢复模式。 回收CYBT-353027—EVE板的工艺: 注(您可能需要注意在步骤9中的路径开始之前)。 删除EVE板上的USB电源。将跳线从UART CTS(J1引脚5)和GND的Arduino头标识(我们用J3引脚7)。连接USB电源eval boardpress按住恢复按钮(SW2)按下复位按钮(SW1)1中血红蛋白的释放情况复位按钮(SW1)释放恢复按钮(SW2)后不久,在windowsnavigate释放复位buttonopen CMD终端到20706-a2_bluetooth文件夹你安装WICE: 例如路径= C: 20706-a2_bluetooth wiced-studio-6.2 WICED SDK 注意:你的路径可能会有所不同。 你可以通过右键单击文件夹并选择“属性”20706-a2_bluetooth WICED查看位置找到位置。 光盘进入这个目录。 一旦在这个目录在终端执行以下命令:.. wiced_tools chipload Win32 chipload.exe - bluetoolmode - launchaddress 0x00000000端口COM5 -波特率自动驱动平台/ cybt_353027_eval / uart.hex - BTP平台/ cybt_353027_eval / cybt_353027_eval_sflash.btp - nodlminidr艾弗-配置建立/ hello_sensor-cybt_353027_eval-rom-ram-wiced-release / hello_sensor-cybt_353027_eval-rom-ram-wiced-release.hex 注意:您的COM端口号可能不同,黄色的“5”以上。 注意:你的项目文件夹和文件名可能不同。六比什么是显示在绿色突出显示的文本。这是您指定.HEX文件的路径的地方。 这为我们工作后迫使评估板为损坏状态。我们将更新程序的文章表达得更清楚谢谢你的反馈。 如果解决了你的问题,请让我知道。 谢谢,戴夫 以上来自于百度翻译 以下为原文 Joshua, We were able to reproduce the state you are in and found a work around to unblock your system and force recovery mode. The process to recover the CYBT-353027-EVAL board: NOTE (you may want to note the paths in step 9 before starting).
Example Path = C:WICED SDKWICED-Studio-6.220706-A2_Bluetooth NOTE: Your Path may differ. You can find the location by right clicking the 20706-A2_Bluetooth folder in WICED and selecting properties to view the location. Cd into this directory.
NOTE: Your COM port number may be different that the Yellow highlighted “5” above. NOTE: Your project folder and .hex file name may be different than what is shown in the Green highlighted text. This is where you specify the path to your .hex file. This has worked for us after forcing the Eval board into a corrupted state. We will be updating the Programming Article to articulate this more clearly thanks to your feedback. Please let me know if this solves your issue. Thanks, Dave |
效果不错!那么,首先是董事会被锁定的情况是什么呢? 谢谢 乔希 以上来自于百度翻译 以下为原文 That worked! So what was the situation that got the boards locked up in the first place? Thanks Josh |
看守所是由应用程序不能从外部Flash引导造成的。这可以通过许多不同的情况引起的:1)有缺陷的闪光(罕见),2)图像编程超过设备可用的RAM空间,三)编程过程停止中期周期(并不总是导致恢复的情况,但往往会)。 戴夫 以上来自于百度翻译 以下为原文 The lockup is caused by the application not being able to boot from the external flash. This can be caused by a number of different circumstances: 1) defective flash (rare), 2) image programmed exceeds the RAM space available in the device, 3) programming process stopped mid cycle (doesn't always result in a recovery situation, but often will). Dave |
只有小组成员才能发言,加入小组>>
752个成员聚集在这个小组
加入小组2069 浏览 1 评论
1824 浏览 1 评论
3633 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
1760 浏览 6 评论
1509 浏览 1 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
507浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
357浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
410浏览 2评论
357浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
854浏览 2评论
GMT+8, 2024-11-22 11:20 , Processed in 1.329139 second(s), Total 104, Slave 87 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
