我正在开发一个带有CYBT-33026-EVAL的应用程序。从两天开始,就不可能在控制台上编程模块和WICE Studio打印。
下载应用程序… ***下载失败*** +----------------------------------------------+ 遵循以下建议并重试。γ 1。验证UB-UART驱动程序是否正确安装 2。验证SW4开关处于接通位置(CTS、RTS、RXD、TXD) 3。功率循环CYBT-34 3026-EVE和重试。γ γ 如果这个问题仍然存在,板上的串行闪存可能会损坏。γ 跟随下面的步骤重置CYBT-34 3026-EVE板到工厂默认状态。γ 注:这将删除任何用户在内存中的应用和重置板到达弗拉特状态 1。按压恢复按钮(SW2) 2。按住复位按钮(SW1)1秒 3。释放SW1 4。释放SW2 5。重新编程板 +----------------------------------------------+ 下载失败。SDK的这个WORD平台只支持下载到20706A2设备。 10:57∶27建造完毕(取1m:27秒。577毫秒) 我已经遵守了指南和论坛帖子中的所有记录和所有的内容,但没有任何变化。尝试改变J8,但没有效果。 只有一次,我能够编程它,但再也没有。 我注意到,RTS和CTS信号(J1连接器)对于所有的通信都是AWAIS低,直到它失败为止。对吗? 司机似乎安装正确,我可以看到两个共同的“USB串行端口”,但我不确定他们是正确的,因为如果我没有错,它应该是WICE HCI UART。我已经尝试在WICE Studio路径中安装驱动程序,但是Windows没有正确安装它。我的操作系统是Windows 10。 问题何在? 以上来自于百度翻译 以下为原文 I'm developing an application with CYBT-343026-EVAL. Since two days it's impossible to program the module and the WICED Studio print in console the following message: Downloading application... ********* Download Failure ************* +-----------------------------------------------------------------------------------------------+ | Follow below suggestions and retry. | | 1. Verify USB-UART driver is correctly installed | | 2. Verify SW4 switches are in ON position (CTS, RTS, RXD, TXD) | | 3. Power cycle CYBT-343026-EVAL and retry. | | | | If this problem persists, the serial flash on the board may be corrupted. | | Follow below steps to reset CYBT-343026-EVAL board to factory default state. | | Note: This will erase any user applicaiton in the memory and reset the board to dafulat state | | 1. Press and hold RECOVER button (SW2) | | 2. Press and hold RESET button (SW1) for 1 second | | 3. Release SW1 | | 4. Release SW2 | | 5. Re-program the board | +-----------------------------------------------------------------------------------------------+ Download failed. This WICED platform of the SDK only supports download to 20706A2 device. 10:57:27 Build Finished (took 1m:27s.577ms) I have followed all the seggestions and all the indeications in the guides and in the forum posts but nothing change. tried also to change J8 but without effect. Only one time I was able to program it but then never again. I have noticed that the RTS and CTS signal (by J1 connector) are alwais low for all the comunication until it fails. Is it right? The drivers seem installed correctly, I can see two common "USB Serial Port" but I'm not sure they are correct because, if I'm not mistaken, it should be WICED HCI UART. I have tried to install the driver inside WICED Studio path but windows do not install it correctly. My OS is Windows 10. Where could be the problem? |
13个回答
只是大声思考,但你使用正确的平台文件吗?
CYBT-33026-EVAL-KBA221025平台文件 以上来自于百度翻译 以下为原文 Just thinking out loud but did you use the right platform file? Platform Files for CYBT-343026-EVAL – KBA221025 |
可以检查生成文件夹内生成的Logto.Log文件。这应该让我们知道它出了什么问题。
关于COM端口,如果您没有看到HCI UART,请不要担心。CYBT-3302626EVE使用CyPress USB串行芯片,它具有不同于FTYI的驱动程序,您可以在CYW20706WCDEVALL上看到。 以上来自于百度翻译 以下为原文 Can you check the logto.log file that is generated inside the build folder. That should give us an idea about where it went wrong. Regarding the COM ports, don't worry if you don't see HCI UART. The CYBT-343026_EVAL uses Cypress USB-Serial chip which has different drivers from the FTDI ones that you would've seen on the CYW20706WCDEVAL. |
谢谢你的回复。 是的,我用的是你建议我的相同的平台文件。 以上来自于百度翻译 以下为原文 Thanks for your reply. Yes, I'm using the same platform file that you suggest me. |
烈阳异丙醇 发表于 2018-10-12 19:01 我已经联系了当地的支持,我们对问题和日志进行了分析。似乎问题是板的硬件,它似乎不是第一种情况。 我已经开始更换它的程序了。 谢谢 以上来自于百度翻译 以下为原文 I have contacted a local support and we have analized the problem and the log. It seems that the problem is with the board hardware and it would seem not to be the first case. I have already started the procedure for replacing it. Thanks |
对于cybt-343026-eval下载,请使用WICED工作室6.1或更新的版本。 如果下载失败,请遵循以下步骤: 1。确保使用cybt-343026的平台:为cybt-343026-eval–kba221025平台文件 2。尝试恢复步骤 1。按压恢复按钮(SW2) 2。按住复位按钮(SW1)1秒 3。释放SW1 4。释放SW2 )和重新编程。 三。如果组件的下载缓缓地,最后失败,Flash验证(logto.log文件记录的下载失败的原因),创造出这种问题的技术或与当地经销商联系。 以上来自于百度翻译 以下为原文 For CYBT-343026-EVAL downloading, please use the WICED Studio 6.1 or newer version. If downloading failed, please follow the steps: 1. Make sure to use the CYBT-343026's platform: Platform Files for CYBT-343026-EVAL – KBA221025 2. Try to do the recover steps( 1. Press and hold RECOVER button (SW2) | | 2. Press and hold RESET button (SW1) for 1 second | | 3. Release SW1 | | 4. Release SW2 | ) and reprogramming. 3. If the kit's downloading slowly and slowly and finally failed with flash verification( logto.log file records the downloading failed reason), create the technical case or contact local distributor for such issue. |
huazhe 发表于 2018-10-12 19:43 这个行为是你在第3点描述的。点1和2被验证,但没有改变。 我刚刚打开了一个技术案例,我已经提供了一个新的更换板。 这是一种奇怪的行为,你知道会有什么问题吗?问题是闪光灯损坏吗? 谢谢。 以上来自于百度翻译 以下为原文 The behavior was the one described by you in point 3. The points 1 and 2 was verified but nothing changed. I have just opened a technical case and I have provide to replace the board with a new one. Its' a strange behavior, do you know what could be the problem? Is the problem due to flash damage? Thanks. |
Xc_Y 发表于 2018-10-12 19:53 可能是由于闪光灯损坏,你以前使用过哪个版本的WICE Studio? 当做 詹森 以上来自于百度翻译 以下为原文 Probably due to the flash damage, which version of WICED Studio do you used before? Regards Jenson |
现在我正在使用Wice Studio 6.1,但上周我尝试卸载和重新安装它,两个月前我开始使用Wice工作室,我认为以前的版本和当前版本没有太大的不同。 如果问题是Flash可以使用此模块用于工业生产的危险。对于同等的柏树模块,你有什么建议吗?我需要音频流和BLE(用于数据传输)。 然而柏树的支持者回答了我的情况: 嗨,卢卡, 我怀疑这个问题可能是因为使用的串口驱动程序。 我将检查应用程序和明天我将为您提供的驱动程序,还发布了一个更新版本。 当做, -马杜 以上来自于百度翻译 以下为原文 Now I'm using WICED Studio 6.1 but last week I have tried to uninstall and reinstall it; I started to use wiced studio two month ago and I think the previous version wasn't very different from current one. If the problem is the flash could be dangerous to use this module for a industrial production. Have you some suggestions for equivalent cypress modules? I need audio streaming and BLE (for data transfer). However Cypress support have replied to my case: Hi Luca, I suspect this issue could be because of the driver used for the serial port. I will check with the apps and tomorrow I will provide you an updated version of driver which is yet be released. Regards, -Madhu |
Xc_Y 发表于 2018-10-12 20:22 工业生产不会损坏模块,因此CYBT34 3026仍然是建议。当你正在开发项目时,由于多下载导致Sflash损坏。WICE 6.1应该有固定多下载损坏Sflash的问题。 你能把这个电话号码告诉我吗? 以上来自于百度翻译 以下为原文 The industrial production will not damage the module, so the CYBT343026 is still the suggestion. The sflash damage due to the multi-downloading while your are develop the project. The WICED 6.1 should have fixed the multi downloading damage the sflash issue. Could you please share the case number to me? |
huazhe 发表于 2018-10-12 20:34 我的意思是,如果Flash停止工作,这是一个问题,如果我在产品中使用这个模块。 问题是多下载?但我已经下载了最多100次固件,没有更多。是闪光极限吗? 我的电话号码是00421887 以上来自于百度翻译 以下为原文 I meant that if flash stop to work it's a problem if I use this module in the product. The problem is multi-downloading? But I have downloaded at most 100 times the firmware, no more. Is it the flash limit? My case number is 00421887 |
Xc_Y 发表于 2018-10-12 20:42 是的,我知道你的意思,没有担心,多下载问题将损坏Sflash的问题已经固定在WICE Studio 6.1。 让我们讨论你的问题(我需要Logto.file文件来找出根案例)在case系统中。 以上来自于百度翻译 以下为原文 Yes, I know your meaning, no worries and the multi-downloading issue will damage the sflash issue had fixed in WICED Studio 6.1. Let's discuss your issue(I need the logto.log file to find out the root case) in case system. |
huazhe 发表于 2018-10-12 20:56 在附件中,您可以找到Logto.Logic文件。 邮编 3 K 以上来自于百度翻译 以下为原文 In attached you can find the logto.log file.
柏树的支持者回答我的情况: 异常试剂盒不能修改。更换套件或重新焊接CYBT-32 3026模块。 以上来自于百度翻译 以下为原文 Cypress support replied to my case: The abnormal kit can't be revised. Replace the kit or re-soldering the CYBT-323026 module. |
只有小组成员才能发言,加入小组>>
742个成员聚集在这个小组
加入小组2011 浏览 1 评论
1773 浏览 1 评论
3561 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
1705 浏览 6 评论
1473 浏览 1 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
292浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
188浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
363浏览 2评论
303浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
502浏览 2评论
GMT+8, 2024-9-28 06:24 , Processed in 1.039113 second(s), Total 100, Slave 84 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
