亲爱的柏树支持团队,
我们公司在ISP领域工作,我们为编程设备建立我们自己的程序员和相关的驱动程序。 我正在与Traveo S6J329 C一起工作,我正面临一些问题。 我已经创建了一个小固件的设备,以擦除,读取和编程TCFlash和工作Flash。 当我擦除一个内存时,第一次读取内存内容时,值不正确:作为第一个字节,我读取0x00而不是0xFF。如果我再次执行读操作,我得到正确的值0xFF。这发生了每个地址我尝试阅读,所以它是独立于我尝试访问内存区域。我从记忆用*访问它((挥发性unsigned char *)使用axi_flash地址指针。 使用相同的固件,但是在s6j32ge装置我不面临同样的问题。 有什么我错过了吗?事实上,我想读到正确的值从内存从最初的访问,而无需做一个“假”读书只是为了摆脱第一次错误的字节。 先谢谢大家。 以上来自于百度翻译 以下为原文 Dear Cypress support team, Our company works in the ISP field and we build our own programmers and related drivers for programming devices. I am working with a TRAVEO S6J329C and I am facing some problems. I have created a small firmware for the device in order to erase, read and program both TCFLASH and WORKING FLASH. When I chip-erase one of the memories, the first time I read the memory content the values are not correct: as first byte I read 0x00 instead of 0xFF. If I perform again the read operation I get the correct value 0xFF. This appens for every address I try to read, so it is independent from the memory region I try to access. I read from the memory accessing to it by using an *((volatile unsigned char *) pointer using AXI_FLASH addresses. Using the same firmware but on a S6J32GE device I don't face the same issue. Is there something that I am missing? The fact is that I would like to read the correct values from the memory from the first access, without having to do a "fake" read just to get rid of the first wrong byte. Thank you all in advance. |
2个回答
请你澄清你的程序员使用的编程方法,JTAG或平行?你如果使用赛普拉斯Flash程序员有问题(连载作家通过UART)?
http://www.cypress.com/documentation/software-and-drivers/flash-mcu-programmer-1 诚挚的问候, 王欣 以上来自于百度翻译 以下为原文 Could you please clarify the programming method used in your programmer, Jtag or parallel? Do you have the issue if using Cypress Flash Programmer (serial writer via UART)? http://www.cypress.com/documentation/software-and-drivers/flash-mcu-programmer-1 Best regards, Amy Wang |
玩cool的girl 发表于 2018-8-14 06:49 我使用的是JTAG方法。我已经解决了阅读问题,这是一个问题的PLL频率设置。 非常感谢! 以上来自于百度翻译 以下为原文 I am using JTAG method. I have solved the reading issue, it was a problem with PLL frequency settings. Thank you very much! |
只有小组成员才能发言,加入小组>>
717个成员聚集在这个小组
加入小组1909 浏览 1 评论
1660 浏览 1 评论
3418 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
1579 浏览 6 评论
1387 浏览 1 评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
204浏览 2评论
193浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
334浏览 2评论
360浏览 1评论
71浏览 1评论
GMT+8, 2024-5-5 19:10 , Processed in 0.837192 second(s), Total 76, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
