电子发烧友论坛|
本人使用的是CCS7.0最新版本。
下面是报错的信息: Description Resource Path Location Type unresolved symbol _FDclass, first referenced in C:/ti/TivaWare_C_Series-2.0.1.11577/sensorlib/ccs/Debug/sensorlib.lib gmake: Target 'all' not remade because of errors. compdcm_mpu9150 C/C++ Problem gmake: *** [compdcm_mpu9150.out] Error 1 compdcm_mpu9150 C/C++ Problem #10234-D unresolved symbols remain compdcm_mpu9150 C/C++ Problem #10010 errors encountered during linking; "compdcm_mpu9150.out" not built compdcm_mpu9150 C/C++ Problem This project was created using a version of compiler that is not currently installed: 5.0.4 [ARM]. Another version of the compiler will be used during build: 16.9.0.LTS. See 'Help > Check for Updates' or visit CCS App Center to get the latest compilers. See 'Help > Install New Software...' to install older compilers. Alternatively, migrate the project to one of the available compiler versions by adjusting project properties. compdcm_mpu9150 properties Problems 似乎senserlib.lib存在未定义的变量。求解答 |
5 个讨论
ljmlvmd 发表于 2018-8-14 07:50 具体如下: 1.用CCS7.0对sensor工程重新编译生产新lib,路径在 C:Usersa0222569workspace_v7sensorlibDebug 2.将第一步编译生产的lib替代tivaware用的lib C:tiTivaWare_C_Series-2.1.1.71sensorlibccsDebug 3.导入此工程,选这rebuild all. 编译通过,没有报错。 |
只有小组成员才能发言,加入小组>>
576 浏览 0 评论
1636 浏览 0 评论
2070 浏览 0 评论
为啥BQ7693003DBTR芯片在和BQ769X0盒子通讯时收不到信号?
1527 浏览 0 评论
DSP 28027F 开发板 XDS100v2调试探针诊断日志显示了 Error -150 (SC_ERR_FTDI_FAIL)如何解决
1365 浏览 0 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
1779浏览 29评论
2806浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
1737浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
1651浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
1664浏览 13评论
/9
GMT+8, 2025-12-8 16:17 , Processed in 0.964353 second(s), Total 68, Slave 54 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2059
