电子发烧友论坛|
TM4C ti PinMux工具使用教程 记得以前TI的TM4C12x是有PinMux这个工具的电脑版的,可以自由的安装和使用,不过现在电脑版被放弃了,主打的是网络版。 地址如下所示: https://dev.ti.com/pinmux/app.html#/default 打开后显示如下: 首先选择开发板的型号和芯片的名称,由于我是自己的板子,所以直接选择芯片的名称就好了。点击start开始进行设计。 打开后的界面如下所示。最左面是所选择的芯片对应的所有外设名称和数量,中间是当前所选择外设的引脚,并列出了可选择或者映射的引脚名称,最右面是芯片的引脚图和可生成的配置文件下载。 配置好外设的引脚名称和功能后,点击最右面的下载,即可下载配置好的外设初始化.c和.h文件了。 |
2 个讨论
生成的代码如下所示:
//*****************************************************************************//// Configure the device pins for different signals//// Copyright (C) 2014 Texas Instruments Incorporated - http://www.ti.com/ // // // Redistribution and use in source and binary forms, with or without // modification, are permitted provided that the following conditions // are met://// Redistributions of source code must retain the above copyright // notice, this list of conditions and the following disclaimer.//// Redistributions in binary form must reproduce the above copyright// notice, this list of conditions and the following disclaimer in the // documentation and/or other materials provided with the // distribution.//// Neither the name of Texas Instruments Incorporated nor the names of// its contributors may be used to endorse or promote products derived// from this software without specific prior written permission.//// THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS // "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT // LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR// A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT // OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, // SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT // LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,// DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY// THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT // (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE // OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.////*****************************************************************************// This file was automatically generated on 2018/2/20 at 下午10:45:29// by TI PinMux version 4.0.1511 ////*****************************************************************************#include |
只有小组成员才能发言,加入小组>>
553 浏览 0 评论
1616 浏览 0 评论
2049 浏览 0 评论
为啥BQ7693003DBTR芯片在和BQ769X0盒子通讯时收不到信号?
1516 浏览 0 评论
DSP 28027F 开发板 XDS100v2调试探针诊断日志显示了 Error -150 (SC_ERR_FTDI_FAIL)如何解决
1343 浏览 0 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
1760浏览 29评论
2787浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
1726浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
1637浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
1647浏览 13评论
/9
GMT+8, 2025-12-3 10:36 , Processed in 0.723742 second(s), Total 63, Slave 49 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1822
