电子发烧友论坛|
各位专家好!
我在做C6678的 NAND&NOR boot ,根据说明烧写完eeprom IBL和NOR、NAND flash代码后,选择NAND Boot: Set the dip switches (pin1, pin2, pin3, pin4) to: SW3(off, off, on, off), SW4(on, off, on, on), SW5(on, on, on, off), SW6(on, on, on, on) 此时超级终端打印的信息如下: IBL: PLL and DDR Initialization Complete IBL Result code 00 IBL: Booting from NAND IBL: Booting from NAND IBL: Booting from NAND IBL: Booting from NAND ........(下面一直打印的是相同内容,而点灯的代码并没有执行) 选择NOR Boot: Set the dip switches (pin1, pin2, pin3, pin4) to: SW3(off, off, on, off), SW4(on, on, on, on), SW5(on, on, on, off), SW6(on, on, on, on) 此时超级终端打印的信息如下: IBL: PLL and DDR Initialization Complete IBL Result code 00 IBL: Booting from NOR IBL: Booting from NOR IBL: Booting from NOR IBL: Booting from NOR ........(仍然一直打印的是相同内容,真正要加载的代码并没执行)。 此处所有的烧写方法都是按照Texas Instrumentsmcsdk_2_00_05_17tools..里面的说明进行的。只不过烧写的代码是我自己写的应用程序(点灯或者对内存赋值程序,烧写前直接把test.out命名为test.bin或者直接拿test.out来烧写), 而如果我在nor flash中烧写的不是自己的应用程序,采用TI提供的HUA例程时,boot代码就能顺利执行,请问这是什么原因? 我个人怀疑的是DSP core0的boot magic address一直存放的I2C boot后的入口地址,没有被更新为应用程序的入口地址,希望有过类似经验的人出来指导一下,不胜感激! |
5 个讨论
Andy,你好! 我的程序在CCS下当然调试过,是ok的,但是烧写到flash后就是boot不起来。 后来发现是cmd的问题,参考某文档的描述: “Note: It is IBL (in local L2) that monitors magic address and boots the DDR init (in local L2) or POST (in local L2) in those two demos. If one wants to load his/her own boot demo code, then it shouldn’t overlap with the IBL code. As a guideline, the IBL uses memory from 0x00800000 to 0x0081BDFF.” 而我的程序正好在这段空间,。修改cmd,避开这段空间以后就好了! 谢谢! |
chexiaohuo 发表于 2018-8-6 06:50 你好! 我用的C6678 EMIF16的外挂一个NOR FLASH,16M x 16bit,NOR FLASH BOOT时,对EEPROM烧写IBL和参数配置成功,.out到.bin,烧写程序到flash后,重启后boot失败, 对于nor的烧写偏移地址是0x0吗?nand的地址是怎么算出来的?还有,sw3设置成1101,小端I2C启动后,读拨码值的寄存器DEVSTAT 0x02620020为FFFF,而设置成noboot或其他模式时则读值正确,对应为拨码开关的值0801.0803.0807等,为什么只有I2C模式读取错误呢?能看一下evm的值吗, |
chexiaohuo 发表于 2018-8-6 06:50 请问下面这段话的出处是那里?是那个文档?谢谢 “Note: It is IBL (in local L2) that monitors magic address and boots the DDR init (in local L2) or POST (in local L2) in those two demos. If one wants to load his/her own boot demo code, then it shouldn’t overlap with the IBL code. As a guideline, the IBL uses memory from 0x00800000 to 0x0081BDFF.” |
hkhwdz 发表于 2018-8-6 07:24 IBL需要占用0x00800000~0x0081FFFF作为运行空间,你的运行代码不应该把静态的段放在这里,比如.text, .const等,但是可以把运行后分配的段放到这块空间;文档我也不记得是在哪一篇了。 |
只有小组成员才能发言,加入小组>>
600 浏览 0 评论
1653 浏览 0 评论
2095 浏览 0 评论
为啥BQ7693003DBTR芯片在和BQ769X0盒子通讯时收不到信号?
1542 浏览 0 评论
DSP 28027F 开发板 XDS100v2调试探针诊断日志显示了 Error -150 (SC_ERR_FTDI_FAIL)如何解决
1385 浏览 0 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
1794浏览 29评论
2820浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
1748浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
1666浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
1680浏览 13评论
/9
GMT+8, 2025-12-14 09:52 , Processed in 0.922761 second(s), Total 77, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
8927
