电子发烧友论坛|
编译h264hpvenc时,编译错误,编译信息如下
**** Build of configuration Debug for project h264hpvenc_ti_c66x **** "C:\ti\ccsv5\utils\bin\gmake" -k all 'Building file: ../h264hpvenc.cfg' 'Invoking: XDCtools' "C:/ti/xdctools_3_25_03_72/xs" --xdcpath="C:/ti/Codecs/C66x_h264hpvenc_01_00_03_00_ELF/packages/ti/sdo/codecs/h264hpvenc/App/Client/Build/packages;/home/a0868396/builds/DEV.H264HP.E.C6678.01.00.03.00/tools/edma3_lld_02_11_05_02/packages;/home/a0868396/builds/DEV.H264HP.E.C6678.01.00.03.00/tools/framework_components_3_23_02_16/packages;/home/a0868396/builds/DEV.H264HP.E.C6678.01.00.03.00/tools/ipc_1_25_03_15/packages;/home/a0868396/builds/DEV.H264HP.E.C6678.01.00.03.00/tools/bios_6_35_04_50/packages;/home/a0868396/builds/DEV.H264HP.E.C6678.01.00.03.00/tools/xdais_7_23_00_06/packages;C:/ti/ccsv5/ccs_base;C:/ti/xdais_7_23_00_06/packages;C:/ti/xdais_7_23_00_06/examples;" xdc.tools.configuro -o configPkg -t ti.targets.elf.C66 -p C6678EVM -r release -c "/home/a0868396/builds/DEV.H264HP.E.C6678.01.00.03.00/tools/TI_CGT_C6000_7.4.6" --compileOptions "-g --optimize_with_debug" "../h264hpvenc.cfg" making package.mak (because of package.bld) ... js: "C:tixdctools_3_25_03_72packagesxdctoolsconfigurotemplatecompiler.opt.xdt", line 57: Error: template generation of 'compiler.opt' failed: Error: /home/a0868396/builds/DEV.H264HP.E.C6678.01.00.03.00/tools/TI_CGT_C6000_7.4.6 cannot be found. Ensure that rootDir for the C66 target is set correctly in ./config.bld "./package.bld", line 52 xdctools_3_25_03_72gmake.exe: *** Deleting file `package.mak' xdctools_3_25_03_72gmake.exe: *** No rule to make target `.configuro'. Stop. Warning: directory "C:/home/a0868396/builds/DEV.H264HP.E.C6678.01.00.03.00/tools/edma3_lld_02_11_05_02/packages" on package path does not exist Warning: directory "C:/home/a0868396/builds/DEV.H264HP.E.C6678.01.00.03.00/tools/framework_components_3_23_02_16/packages" on package path does not exist Warning: directory "C:/home/a0868396/builds/DEV.H264HP.E.C6678.01.00.03.00/tools/ipc_1_25_03_15/packages" on package path does not exist Warning: directory "C:/home/a0868396/builds/DEV.H264HP.E.C6678.01.00.03.00/tools/bios_6_35_04_50/packages" on package path does not exist Warning: directory "C:/home/a0868396/builds/DEV.H264HP.E.C6678.01.00.03.00/tools/xdais_7_23_00_06/packages" on package path does not exist js: "C:/ti/xdctools_3_25_03_72/packages/xdc/tools/Cmdr.xs", line 51: Error: xdc.tools.configuro: configuration failed due to earlier errors (status = 2); 'linker.cmd' deleted. gmake: *** [configPkg/linker.cmd] Error 1 gmake: Target `all' not remade because of errors. **** Build Finished **** Description Resource Path Location Type template generation of 'compiler.opt' failed: Error: /home/a0868396/builds/DEV.H264HP.E.C6678.01.00.03.00/tools/TI_CGT_C6000_7.4.6 cannot be found. Ensure that rootDir for the C66 target is set correctly in ./config.bld .xdchelp /h264hpvenc_ti_c66x line 57 C/C++ Problem 是编译器的版本问题吗? 安装TI_CGT_C6000_7.4.6之后,进行编译,又有如下错误: **** Build of configuration Debug for project h264hpvenc_ti_c66x **** "C:\ti\ccsv5\utils\bin\gmake" -k all 'Building file: ../h264hpvenc.cfg' 'Invoking: XDCtools' "C:/ti/xdctools_3_25_03_72/xs" --xdcpath="C:/ti/Codecs/C66x_h264hpvenc_01_00_03_00_ELF/packages/ti/sdo/codecs/h264hpvenc/App/Client/Build/packages;/home/a0868396/builds/DEV.H264HP.E.C6678.01.00.03.00/tools/edma3_lld_02_11_05_02/packages;/home/a0868396/builds/DEV.H264HP.E.C6678.01.00.03.00/tools/framework_components_3_23_02_16/packages;/home/a0868396/builds/DEV.H264HP.E.C6678.01.00.03.00/tools/ipc_1_25_03_15/packages;/home/a0868396/builds/DEV.H264HP.E.C6678.01.00.03.00/tools/bios_6_35_04_50/packages;/home/a0868396/builds/DEV.H264HP.E.C6678.01.00.03.00/tools/xdais_7_23_00_06/packages;C:/ti/ccsv5/ccs_base;C:/ti/xdais_7_23_00_06/packages;C:/ti/xdais_7_23_00_06/examples;C:/ti/bios_6_35_04_50/packages;C:/ti/edma3_lld_02_11_05_02/packages;C:/ti/framework_components_3_23_02_16/packages;C:/ti/framework_components_3_23_02_16/examples;C:/ti/mcsdk_2_01_02_06/demos;C:/ti/pdk_C6678_1_1_2_6/packages;" xdc.tools.configuro -o configPkg -t ti.targets.elf.C66 -p C6678EVM -r release -c "/home/a0868396/builds/DEV.H264HP.E.C6678.01.00.03.00/tools/TI_CGT_C6000_7.4.6" --compileOptions "-g --optimize_with_debug" "../h264hpvenc.cfg" making package.mak (because of package.bld) ... js: "C:tixdctools_3_25_03_72packagesxdctoolsconfigurotemplatecompiler.opt.xdt", line 57: Error: template generation of 'compiler.opt' failed: Error: /home/a0868396/builds/DEV.H264HP.E.C6678.01.00.03.00/tools/TI_CGT_C6000_7.4.6 cannot be found. Ensure that rootDir for the C66 target is set correctly in ./config.bld "./package.bld", line 52 xdctools_3_25_03_72gmake.exe: *** Deleting file `package.mak' xdctools_3_25_03_72gmake.exe: *** No rule to make target `.configuro'. Stop. Warning: directory "C:/home/a0868396/builds/DEV.H264HP.E.C6678.01.00.03.00/tools/edma3_lld_02_11_05_02/packages" on package path does not exist Warning: directory "C:/home/a0868396/builds/DEV.H264HP.E.C6678.01.00.03.00/tools/framework_components_3_23_02_16/packages" on package path does not exist Warning: directory "C:/home/a0868396/builds/DEV.H264HP.E.C6678.01.00.03.00/tools/ipc_1_25_03_15/packages" on package path does not exist Warning: directory "C:/home/a0868396/builds/DEV.H264HP.E.C6678.01.00.03.00/tools/bios_6_35_04_50/packages" on package path does not exist Warning: directory "C:/home/a0868396/builds/DEV.H264HP.E.C6678.01.00.03.00/tools/xdais_7_23_00_06/packages" on package path does not exist js: "C:/ti/xdctools_3_25_03_72/packages/xdc/tools/Cmdr.xs", line 51: Error: xdc.tools.configuro: configuration failed due to earlier errors (status = 2); 'linker.cmd' deleted. gmake: *** [configPkg/linker.cmd] Error 1 gmake: Target `all' not remade because of errors. **** Build Finished **** Description Resource Path Location Type template generation of 'compiler.opt' failed: Error: /home/a0868396/builds/DEV.H264HP.E.C6678.01.00.03.00/tools/TI_CGT_C6000_7.4.6 cannot be found. Ensure that rootDir for the C66 target is set correctly in ./config.bld .xdchelp /h264hpvenc_ti_c66x line 57 C/C++ Problem 该如何解决 |
2 个讨论
如下提示,编译相关的模块如xdc tools,ipc及bios等在你指定的路径都没有找到,需要根据你电脑上安装的目录重新设定相应的环境变量。
xdctools_3_25_03_72gmake.exe: *** Deleting file `package.mak' xdctools_3_25_03_72gmake.exe: *** No rule to make target `.configuro'. Stop. Warning: directory "C:/home/a0868396/builds/DEV.H264HP.E.C6678.01.00.03.00/tools/edma3_lld_02_11_05_02/packages" on package path does not exist Warning: directory "C:/home/a0868396/builds/DEV.H264HP.E.C6678.01.00.03.00/tools/framework_components_3_23_02_16/packages" on package path does not exist Warning: directory "C:/home/a0868396/builds/DEV.H264HP.E.C6678.01.00.03.00/tools/ipc_1_25_03_15/packages" on package path does not exist Warning: directory "C:/home/a0868396/builds/DEV.H264HP.E.C6678.01.00.03.00/tools/bios_6_35_04_50/packages" on package path does not exist Warning: directory "C:/home/a0868396/builds/DEV.H264HP.E.C6678.01.00.03.00/tools/xdais_7_23_00_06/packages" on package path does not exist |
只有小组成员才能发言,加入小组>>
553 浏览 0 评论
1616 浏览 0 评论
2049 浏览 0 评论
为啥BQ7693003DBTR芯片在和BQ769X0盒子通讯时收不到信号?
1516 浏览 0 评论
DSP 28027F 开发板 XDS100v2调试探针诊断日志显示了 Error -150 (SC_ERR_FTDI_FAIL)如何解决
1343 浏览 0 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
1760浏览 29评论
2787浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
1726浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
1637浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
1647浏览 13评论
/9
GMT+8, 2025-12-3 11:08 , Processed in 1.063395 second(s), Total 61, Slave 47 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
8271
