电子发烧友论坛|
6 个讨论
板子是合众达的SEED-DEC6437,仿真器是SEED-XDS510PLUS,仿真器驱动怎么测试呢?ccs是6.1.1的,看了下xdsfast3.dll是91.5k,这个是正确安装的吗?还有就是初始化的时候就报错了 C64XP_0: GEL Output: Setup CacheC64XP_0: GEL: Error while executing StartUp( 6, 1, 0, 1349 ): Could not write 0x01840020: target is not connected at *((unsigned int *) 0x01840020)=7 [dec6437.gel:185] at Setup_Cache() [dec6437.gel:21] at StartUp(6, 1, 0, 1349) |
test connection之后出现这个错误 [Start] Execute the command: %ccs_base%/common/uscif/dbgjtag.exe -f %boarddatafile% -rv -o -F inform,logfile=yes -S pathlength -S integrity [Result] -----[Print the board config pathname(s)]------------------------------------ C:UserslyAppDataLocal.TI2526794187 0 BrdDattestBoard.dat -----[Print the reset-command software log-file]----------------------------- This utility has selected a 100- or 510-class product. This utility will load the adapter 'seedjca8990isa.dll'. The library build date was 'Aug 20 2013'. The library build time was '22:56:19'. The library package version is '5.1.232.0'. The library component version is '35.34.40.0'. The controller does not use a programmable FPGA. The controller has a version number of '1' (0x00000001). The controller has an insertion length of '16' (0x00000010). This utility will attempt to reset the controller. A error occurred while attempting to reset the controller. -----[An error has occurred and this utility has aborted]-------------------- This error is generated by TI's USCIF driver or utilities. The value is '-342' (0xfffffeaa). The title is 'SC_ERR_HUNG_COMMAND'. The explanation is: Failure due to the controller command-finish taking too long. [End] |
kingnet_52004 发表于 2018-7-25 09:28 1、首要要看仿真器支持的版本,合众达的xds510 plus的驱动目前好像只支持到5.x,以前问过他们技术说会有向后支持的计划,但是目前好像还没有 2、针对支持的ccs版本,仿真器的安装目录必须是……/ccs_base,而合众达的驱动安装程序后有自己默认的安装目录,安装的时候,必须要修正 |
只有小组成员才能发言,加入小组>>
549 浏览 0 评论
1613 浏览 0 评论
2047 浏览 0 评论
为啥BQ7693003DBTR芯片在和BQ769X0盒子通讯时收不到信号?
1513 浏览 0 评论
DSP 28027F 开发板 XDS100v2调试探针诊断日志显示了 Error -150 (SC_ERR_FTDI_FAIL)如何解决
1337 浏览 0 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
1756浏览 29评论
2781浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
1723浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
1634浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
1645浏览 13评论
/9
GMT+8, 2025-12-1 21:08 , Processed in 2.083952 second(s), Total 78, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3282
