电子发烧友论坛扫一扫,分享给好友
我把OV7670的 VSYNC HS 都设置成高电平了,VS引脚接pin_03,复用成CAM_hS功能了,但是就是不会触发中断,串口也不会打印,代码如下
void CameraIntHandler() [ MAP_CameraIntClear(CAMERA_BASE, CAM_INT_FE); g_frame_end = 1; Report(" goto interrupt nr "); MAP_CameraCaptureStop(CAMERA_BASE, true); ] void CaptureImage() [ int val; // // Configure DMA in ping-pong mode // DMAConfig(); // // Perform Image Capture // MAP_CameraCaptureStart(CAMERA_BASE); //HWREG(0x44018040)=1<<20; Report(" before nr "); while(g_frame_end == 0) [ //一直在这里循环 ] MAP_CameraCaptureStop(CAMERA_BASE, true); Report(" later nr "); ] void CamControllerInit() [ int val; MAP_PRCMPeripheralClkEnable(PRCM_CAMERA, PRCM_RUN_MODE_CLK); MAP_PRCMPeripheralReset(PRCM_CAMERA); HWREG(0x44025000) = 0x0000;//不分频 MAP_CameraReset(CAMERA_BASE); //CAM_HS_POL_HI,HSYNC极性为高电平有效 //CAM_VS_POL_LO,VSYNC低电平有效 //CAM_ORDERCAM_SWAP交换字节顺序,swapping image data in FIFO. //CAM_NOBT_SYNCHRO,在帧开始时捕捉数据 /* MAP_CameraParamsConfig(CAMERA_BASE, CAM_HS_POL_HI, CAM_VS_POL_LO, CAM_ORDERCAM_SWAP|CAM_NOBT_SYNCHRO);*/ MAP_CameraParamsConfig(CAMERA_BASE, CAM_HS_POL_HI, CAM_VS_POL_HI, CAM_NOBT_SYNCHRO|CAM_IF_SYNCHRO); HWREG(0x44018000 + 0x40) |= 1<<17;//FRAME_TRIG 置1 MAP_CameraIntRegister(CAMERA_BASE, CameraIntHandler); //MCLK is by-default set to 120MHz, and cannot be modified MAP_CameraXClkConfig(CAMERA_BASE, 120000000,12000000); MAP_CameraThresholdSet(CAMERA_BASE, 8); MAP_CameraIntEnable(CAMERA_BASE, CAM_INT_FE);//帧结束中断,低电平有效 MAP_CameraDMAEnable(CAMERA_BASE); ] void DMAConfig() [ memset(g_image_buffer,0xF80F,sizeof(g_image_buffer)); //这个内存大小有待考究,QVGA 50?120? p_buffer = &g_image_buffer[0]; // // Initilalize DMA // UDMAInit(); // // Setup ping-pong transfer // DMASetupTransfer(UDMA_CH22_CAMERA,UDMA_MODE_PINGPONG,TOTAL_DMA_ELEMENTS, UDMA_SIZE_32, UDMA_ARB_8,(void *)CAM_BUFFER_ADDR, UDMA_SRC_INC_32, (void *)p_buffer, UDMA_DST_INC_32); // // Pong Buffer // p_buffer += TOTAL_DMA_ELEMENTS; DMASetupTransfer(UDMA_CH22_CAMERA|UDMA_ALT_SELECT,UDMA_MODE_PINGPONG, TOTAL_DMA_ELEMENTS, UDMA_SIZE_32, UDMA_ARB_8,(void *)CAM_BUFFER_ADDR, UDMA_SRC_INC_32, (void *)p_buffer, UDMA_DST_INC_32); // // Ping Buffer // p_buffer += TOTAL_DMA_ELEMENTS; g_dma_txn_done = 0; g_frame_size_in_bytes = 0; g_frame_end = 0; g_total_dma_intrpts = 0; // // Clear any pending interrupt // HWREG(0x4402609C) |= 1 << 8; // // DMA Interrupt unmask from apps config // HWREG(0x44026094) |= 1 << 8; Report(" DMA INIT OK nr "); ] |
8个回答
VS 引脚是输入模式,测电平是1.8,这种输入引脚电平应该是0啊
已经知道为什么了,要把VS HS PCLK同时输入CC3200,才能判断是否是帧结束,只是给一个VS信号是没办法判断的
我解决了,要把VS、HS、pclk信号都接上,才能触发帧中断,只依靠VS一个信号是没办法触发的
OV2640的有调试出来么?
1,提供 CC2540/41/30 批量脱机烧录器 1拖16 2,提供 CC2540 CC2541 蓝牙开发板 3,提供 CC3200 WIFI视频开发板 4,https://amomcu.taobao.com/ |
你把摄像头输出的VS HS 极性设置成正有效试试 我现在又搞不清怎么从内存中恢复图像了,以前没有接触过,望赐教 |
没调2640,你遇到什么困难了,我现在遇到存储的问题了,一帧QVGA的图片是150KB,我想放到一个数组中,SRAM_DATA是用来存储变量的空间,只有100KB ,应该怎么办 |
pingnai 发表于 2018-6-23 03:26 你是用RGB输出的吧,如果用YUV应该会小一些。 如果有答案已经回答了您的问题,请标注为已回答。 Please close your question if it has been solved. ------------------------------------------------------------------ |
ji Ju 你好~ 最近也在调ov7670摄像头,遇到点问题,如果方便能加qq请教您几个问题吗~~ qq 759459067 |
只有小组成员才能发言,加入小组>>
549 浏览 0 评论
1613 浏览 0 评论
2047 浏览 0 评论
为啥BQ7693003DBTR芯片在和BQ769X0盒子通讯时收不到信号?
1513 浏览 0 评论
DSP 28027F 开发板 XDS100v2调试探针诊断日志显示了 Error -150 (SC_ERR_FTDI_FAIL)如何解决
1337 浏览 0 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
1756浏览 29评论
2781浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
1723浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
1634浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
1645浏览 13评论
/9
GMT+8, 2025-12-1 20:39 , Processed in 1.209566 second(s), Total 85, Slave 69 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1298
