电子发烧友论坛|
18个回答
先sccb初始化,然后就读数据就ok了
请问 对于摄像头的系统时钟 我给出8MHZ的时钟 会输出PCLK 行同步 帧同步等信号 这些不用考虑吗
可以输出pclk,行同步和祯同步都是要考虑的
这些都是重要参数,当然要考虑.对着电路的连接再细看OV7670时序就知道了
既然楼上传了资料,我也来一点.CMOS_AL422_STM32F103ZET6_ili9328----.rar (332.2 KB )
CF7670B-V2_pcb.PDF (84.34 KB ) OV7670_DS_(1_4).pdf (738.26 KB ) OV7670 中文版数据手册1.01.pdf (595.38 KB ) OV7670_FIFO_SCH 原理图.pdf (38.18 KB ) |
呵呵,原子哥,这东西ourdev那边多人玩一点
是的,那边wangguanfu玩的很欢...
可是我在那个论坛中下不了资料
u8 OV7670_Init(void)
{ u8 temp=0,num; u16 ID; SCCB_GPIO_Init(); OV7670_GPIO_Init(); if(OV7670_WR_REG(REG_COM7,COM7_RESET)==1)//复位SCCB寄存器 { return 1; //复位失败 } for(num=0;num if(OV7670_WR_REG(OV7670_REG[num][0],OV7670_REG[num][1])==1) { return 1;//返回错误 } } 原子老师 您看这个OV7670的初始化程序,总是在对OV7670的寄存器初始化时出错 是怎么回事啊?? const char OV7670_REG[OV7670_REG_NUM][2]= { /*以下为OV7670 QVGA RGB565参数 */ {0x3a, 0x04},// {0x40, 0x10}, {0x12, 0x14}, {0x32, 0x80}, {0x17, 0x16}, {0x18, 0x04},//5 {0x19, 0x02}, {0x1a, 0x7b},//0x7a, {0x03, 0x06},//0x0a, {0x0c, 0x0c}, {0x15, 0x02}, {0x3e, 0x00},//10 {0x70, 0x00}, {0x71, 0x01},//0x81彩条测试 {0x72, 0x11}, {0x73, 0x09},// {0xa2, 0x02},//15 {0x11, 0x00}, {0x7a, 0x20}, {0x7b, 0x1c}, {0x7c, 0x28}, {0x7d, 0x3c},//20 {0x7e, 0x55}, {0x7f, 0x68}, {0x80, 0x76}, {0x81, 0x80}, {0x82, 0x88}, {0x83, 0x8f}, {0x84, 0x96}, {0x85, 0xa3}, {0x86, 0xaf}, {0x87, 0xc4},//30 {0x88, 0xd7}, {0x89, 0xe8}, {0x13, 0xe0}, {0x00, 0x00},//AGC {0x10, 0x00}, {0x0d, 0x00}, {0x14, 0x20},//0x38, limit the max gain {0xa5, 0x05}, {0xab, 0x07}, {0x24, 0x75},//40 {0x25, 0x63}, {0x26, 0xA5}, {0x9f, 0x78}, {0xa0, 0x68}, {0xa1, 0x03},//0x0b, {0xa6, 0xdf},//0xd8, {0xa7, 0xdf},//0xd8, {0xa8, 0xf0}, {0xa9, 0x90}, {0xaa, 0x94},//50 {0x13, 0xe5}, {0x0e, 0x61}, {0x0f, 0x4b}, {0x16, 0x02}, {0x1e, 0x27},//0x07, {0x21, 0x02}, {0x22, 0x91}, {0x29, 0x07}, {0x33, 0x0b}, {0x35, 0x0b},//60 {0x37, 0x1d}, {0x38, 0x71}, {0x39, 0x2a}, {0x3c, 0x78}, {0x4d, 0x40}, {0x4e, 0x20}, {0x69, 0x5d}, {0x6b, 0x00},//PLL {0x74, 0x19}, {0x8d, 0x4f}, {0x8e, 0x00},//70 {0x8f, 0x00}, {0x90, 0x00}, {0x91, 0x00}, {0x92, 0x00},//0x19,//0x66 {0x96, 0x00}, {0x9a, 0x80}, {0xb0, 0x84}, {0xb1, 0x0c}, {0xb2, 0x0e}, {0xb3, 0x82},//80 {0xb8, 0x0a}, {0x43, 0x14}, {0x44, 0xf0}, {0x45, 0x34}, {0x46, 0x58}, {0x47, 0x28}, {0x48, 0x3a}, {0x59, 0x88}, {0x5a, 0x88}, {0x5b, 0x44},//90 {0x5c, 0x67}, {0x5d, 0x49}, {0x5e, 0x0e}, {0x64, 0x04}, {0x65, 0x20}, {0x66, 0x05}, {0x94, 0x04}, {0x95, 0x08}, {0x6c, 0x0a}, {0x6d, 0x55}, {0x4f, 0x80}, {0x50, 0x80}, {0x51, 0x00}, {0x52, 0x22}, {0x53, 0x5e}, {0x54, 0x80}, //{0x54, 0x40},//110 {0x6e, 0x11},//100 {0x6f, 0x9f},//0x9e for advance AWB {0x55, 0x00},//亮度 {0x56, 0x40},//对比度 {0x57, 0x80},//0x40, };> |
说不定你电路连接有问题!
是在OV7670寄存器的配置过程中报错的,并不是一开始配置寄存器就出错 如果是硬件的问题会这样吗??
原子老师 这样配置寄存器 用那么多吗 只配置几个关键的寄存器可以吗
不可以
原子老师 //设置VSYNC(PD2)帧同步输出中断
Ex_NVIC_Config(GPIO_D,2,FTIR);//设置PD2下降沿触发 MY_NVIC_Init(1,2,EXTI2_IRQChannel,2);//抢占1,响应2,组2线中断 return 0; } /************配置OV7670中断服务函数******************/ void EXTI2_IRQHandler(void) { if((EXTI->R&0x04)&&(EXTI->IMR&0X04)!=0)//PR为挂起寄存器,IMR为中断屏蔽寄存器。 { if(status==0) { FIFO_WE_SET; FIFO_WRST_CLR; //写复位 Delay_us(1); FIFO_WRST_SET; FIFO_WE_SET; status=1; }else if(status==1) { FIFO_WE_CLR; status=2; } EXTI->R=1<<2;//清除中断2标志 } } 我这样配置中断 可是这样进不去中断,用示波器观察了PD2的波形有下降沿啊 不知为什么?? |
代码的问题,慢慢研究下吧
好的 谢谢 原子老师
顶一下。
只有小组成员才能发言,加入小组>>
调试STM32H750的FMC总线读写PSRAM遇到的问题求解?
4130 浏览 1 评论
X-NUCLEO-IHM08M1板文档中输出电流为15Arms,15Arms是怎么得出来的呢?
3221 浏览 1 评论
2747 浏览 2 评论
STM32F030F4 HSI时钟温度测试过不去是怎么回事?
2175 浏览 2 评论
ST25R3916能否对ISO15693的标签芯片进行分区域写密码?
14939 浏览 2 评论
STM32仿真器是选择ST-LINK还是选择J-LINK?各有什么优势啊?
3084浏览 4评论
stm32f4下spi+dma读取数据不对是什么原因导致的?
1894浏览 3评论
STM32F0_TIM2输出pwm2后OLED变暗或者系统重启是怎么回事?
2064浏览 3评论
1976浏览 3评论
stm32cubemx生成mdk-arm v4项目文件无法打开是什么原因导致的?
2166浏览 3评论
/9
GMT+8, 2025-12-2 05:30 , Processed in 1.771833 second(s), Total 77, Slave 70 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
6765
