扫一扫,分享给好友
我用的是官方的EVM板,我的SW5的设置是off ,也就是拨码开关都设置为靠近PCIE插座。在这种设置下,当我插了PCIE网卡(x1),上电串口竟然无反应,此PCIE网卡我已经在PC机上测试过了,可以使用。以下是我不插PCIE网卡的时候串口打印信息。
Linux version 2.6.37 (root@ubuntu) (gcc version 4.3.3 (Sourcery G++ Lite 2009q1-203) ) #21 Mon May 6 11:39:25 CST 2013 CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c53c7f CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache Machine: ti8168evm reserved size = 52428800 at 0x0 FB: Reserving 52428800 bytes SDRAM for VRAM Memory policy: ECC disabled, Data cache writeback OMAP chip is TI8168 2.0 On node 0 totalpages: 80384 free_area_init_node: node 0, pgdat c0590158, node_mem_map c05cc000 Normal zone: 728 pages used for memmap Normal zone: 0 pages reserved Normal zone: 79656 pages, LIFO batch:15 pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768 pcpu-alloc: [0] 0 Built 1 zonelists in Zone order, mobility grouping on. Total pages: 79656 Kernel command line: console=ttyO2,115200n8 rootwait root=/dev/sda1 rw mem=364M@0x80000000 324M@0x9F900000 notifyk.vpssm3_sva=0xBF900000 ip=off noinitrd PID hash table entries: 2048 (order: 1, 8192 bytes) Dentry cache hash table entries: 65536 (order: 6, 262144 bytes) Inode-cache hash table entries: 32768 (order: 5, 131072 bytes) Memory: 314MB = 314MB total Memory: 312248k/312248k available, 60488k reserved, 0K highmem Virtual kernel memory layout: vector : 0xffff0000 - 0xffff1000 ( 4 kB) fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) DMA : 0xffc00000 - 0xffe00000 ( 2 MB) vmalloc : 0xd7000000 - 0xf8000000 ( 528 MB) lowmem : 0xc0000000 - 0xd6c00000 ( 364 MB) pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) modules : 0xbf000000 - 0xbfe00000 ( 14 MB) .init : 0xc0008000 - 0xc003d000 ( 212 kB) .text : 0xc003d000 - 0xc0546000 (5156 kB) .data : 0xc0546000 - 0xc0591b40 ( 303 kB) SLUB: Genslabs=11, HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1 NR_IRQS:407 IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts Total of 128 interrupts on 1 active controller GPMC revision 6.0 Trying to install interrupt handler for IRQ400 Trying to install interrupt handler for IRQ401 Trying to install interrupt handler for IRQ402 Trying to install interrupt handler for IRQ403 Trying to install interrupt handler for IRQ404 Trying to install interrupt handler for IRQ405 Trying to install interrupt handler for IRQ406 Trying to install type control for IRQ407 Trying to set irq flags for IRQ407 OMAP clockevent source: GPTIMER1 at 27000000 Hz Console: colour dummy device 80x30 Calibrating delay loop... 986.31 BogoMIPS (lpj=4931584) pid_max: default: 32768 minimum: 301 Security Framework initialized Mount-cache hash table entries: 512 CPU: Testing write buffer coherency: ok devtmpfs: initialized omap_voltage_early_init: voltage driver support not added regulator: core version 0.5 regulator: dummy: NET: Registered protocol family 16 omap_voltage_domain_lookup: Voltage driver init not yet happened.Faulting! omap_voltage_add_dev: VDD specified does not exist! OMAP GPIO hardware version 0.1 OMAP GPIO hardware version 0.1 omap_mux_init: Add partition: #1: core, flags: 0 NOR: Can't request GPMC CS registered ti816x_gpio_vr device registered ti816x_sr device clk get on i2c3 fck failed _omap_mux_get_by_name: Could not find signal dcan0_tx.dcan0_tx _omap_mux_get_by_name: Could not find signal dcan0_rx.dcan0_rx pm_dbg_init: only OMAP3 supported registered ti81xx_vpss device registered ti81xx_vidout device registered ti81xx on-chip HDMI device registered ti81xx_fb device registered ti81xx_vin device ti81xx_pcie: Invoking PCI BIOS... ti81xx_pcie: Setting up Host Controller... ti81xx_pcie: Register base mapped @0xd7020000 ti81xx_pcie: Setting outbound translation for 0x20000000-0x2fffffff ti81xx_pcie: Starting PCI scan... pci_bus 0000:00: scanning bus ti81xx_pcie: Reading config[0] for device 0000:00:00.. failed. No link/device. ti81xx_pcie: Reading config[0] for device 0000:01:00.. failed. No link/device. ti81xx_pcie: Reading config[0] for device 0000:02:00.. failed. No link/device. ti81xx_pcie: Reading config[0] for device 0000:03:00.. failed. No link/device. ti81xx_pcie: Reading config[0] for device 0000:04:00.. failed. No link/device. ti81xx_pcie: Reading config[0] for device 0000:05:00.. failed. No link/device. ti81xx_pcie: Reading config[0] for device 0000:06:00.. failed. No link/device. ti81xx_pcie: Reading config[0] for device 0000:07:00.. failed. No link/device. ti81xx_pcie: Reading config[0] for device 0000:08:00.. failed. No link/device. ti81xx_pcie: Reading config[0] for device 0000:09:00.. failed. No link/device. ti81xx_pcie: Reading config[0] for device 0000:0a:00.. failed. No link/device. ti81xx_pcie: Reading config[0] for device 0000:0b:00.. failed. No link/device. ti81xx_pcie: Reading config[0] for device 0000:0c:00.. failed. No link/device. ti81xx_pcie: Reading config[0] for device 0000:0d:00.. failed. No link/device. ti81xx_pcie: Reading config[0] for device 0000:0e:00.. failed. No link/device. ti81xx_pcie: Reading config[0] for device 0000:0f:00.. failed. No link/device. ti81xx_pcie: Reading config[0] for device 0000:10:00.. failed. No link/device. ti81xx_pcie: Reading config[0] for device 0000:11:00.. failed. No link/device. ti81xx_pcie: Reading config[0] for device 0000:12:00.. failed. No link/device. ti81xx_pcie: Reading config[0] for device 0000:13:00.. failed. No link/device. ti81xx_pcie: Reading config[0] for device 0000:14:00.. failed. No link/device. ti81xx_pcie: Reading config[0] for device 0000:15:00.. failed. No link/device. ti81xx_pcie: Reading config[0] for device 0000:16:00.. failed. No link/device. ti81xx_pcie: Reading config[0] for device 0000:17:00.. failed. No link/device. ti81xx_pcie: Reading config[0] for device 0000:18:00.. failed. No link/device. ti81xx_pcie: Reading config[0] for device 0000:19:00.. failed. No link/device. ti81xx_pcie: Reading config[0] for device 0000:1a:00.. failed. No link/device. ti81xx_pcie: Reading config[0] for device 0000:1b:00.. failed. No link/device. ti81xx_pcie: Reading config[0] for device 0000:1c:00.. failed. No link/device. ti81xx_pcie: Reading config[0] for device 0000:1d:00.. failed. No link/device. ti81xx_pcie: Reading config[0] for device 0000:1e:00.. failed. No link/device. ti81xx_pcie: Reading config[0] for device 0000:1f:00.. failed. No link/device. pci_bus 0000:00: fixups for bus PCI: bus0: Fast back to back transfers enabled pci_bus 0000:00: bus scan returning with max=00 pci_bus 0000:00: resource 0 [mem 0x20000000-0x2fffffff] pci_bus 0000:00: resource 1 [io 0x40000000-0x402fffff] bio: create slab regulator: VFB: 800 <--> 1025 mV at 1010 mV vgaarb: loaded SCSI subsystem initialized libata version 3.00 loaded. u***core: registered new interface driver u***fs u***core: registered new interface driver hub u***core: registered new device driver u*** USBSS revision 4ea20809 registerd cppi-dma Intr @ IRQ 17 Cppi41 Init Done Advanced Linux Sound Architecture Driver Version 1.0.23. Switching to clocksource gp timer mu***-hdrc: version 6.0, host, debug=0 mu***-hdrc mu***-hdrc.0: dma type: dma-cppi41 MUSB controller-0 revision 4ea20800 TxFifo Empty intr disabled mu***-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk combine, bulk split, HB-ISO Rx, HB-ISO Tx, SoftConn) mu***-hdrc: MHDRC RTL version 2.0 mu***-hdrc: setup fifo_mode 4 mu***-hdrc: 28/31 max ep, 16384/16384 memory mu***-hdrc mu***-hdrc.0: MUSB HDRC host driver mu***-hdrc mu***-hdrc.0: new USB bus registered, assigned bus number 1 u*** u***1: New USB device found, idVendor=1d6b, idProduct=0002 u*** u***1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 u*** u***1: Product: MUSB HDRC host driver u*** u***1: Manufacturer: Linux 2.6.37 mu***-hcd u*** u***1: SerialNumber: mu***-hdrc.0 hub 1-0:1.0: USB hub found hub 1-0:1.0: 1 port detected mu***-hdrc mu***-hdrc.0: USB Host mode controller at d701e000 using DMA, IRQ 18 Registered /proc/driver/mu***_hdrc.0 mu***-hdrc mu***-hdrc.1: dma type: dma-cppi41 MUSB controller-1 revision 4ea20800 TxFifo Empty intr disabled mu***-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk combine, bulk split, HB-ISO Rx, HB-ISO Tx, SoftConn) mu***-hdrc: MHDRC RTL version 2.0 mu***-hdrc: setup fifo_mode 4 mu***-hdrc: 28/31 max ep, 16384/16384 memory mu***-hdrc mu***-hdrc.1: MUSB HDRC host driver mu***-hdrc mu***-hdrc.1: new USB bus registered, assigned bus number 2 u*** u***2: New USB device found, idVendor=1d6b, idProduct=0002 u*** u***2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 u*** u***2: Product: MUSB HDRC host driver u*** u***2: Manufacturer: Linux 2.6.37 mu***-hcd u*** u***2: SerialNumber: mu***-hdrc.1 hub 2-0:1.0: USB hub found hub 2-0:1.0: 1 port detected mu***-hdrc mu***-hdrc.1: USB Host mode controller at d7026800 using DMA, IRQ 19 Registered /proc/driver/mu***_hdrc.1 NET: Registered protocol family 2 IP route cache hash table entries: 4096 (order: 2, 16384 bytes) TCP established hash table entries: 16384 (order: 5, 131072 bytes) TCP bind hash table entries: 16384 (order: 4, 65536 bytes) TCP: Hash tables configured (established 16384 bind 16384) TCP reno registered UDP hash table entries: 256 (order: 0, 4096 bytes) UDP-Lite hash table entries: 256 (order: 0, 4096 bytes) NET: Registered protocol family 1 RPC: Registered udp transport module. RPC: Registered tcp transport module. RPC: Registered tcp NFSv4.1 backchannel transport module. PCI: CLS 0 bytes, default 64 NetWinder Floating Point Emulator V0.97 (double precision) PMU: registered new PMU device of type 0 omap-iommu omap-iommu.0: ducati registered omap-iommu omap-iommu.1: sys registered JFFS2 version 2.2. (NAND) 漏 2001-2006 Red Hat, Inc. msgmni has been set to 609 io scheduler noop registered io scheduler deadline registered io scheduler cfq registered (default) ti81xx_pcie_ep: No TI81xx PCIe EP [0xb800] found ti81xx_pcie_ep: No TI81xx PCIe EP [0xb801] found ti81xx_pcie_ep: No TI81xx PCIe EP found. Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled omap_uart.0: ttyO0 at MMIO 0x48020000 (irq = 72) is a OMAP UART0 omap_uart.1: ttyO1 at MMIO 0x48022000 (irq = 73) is a OMAP UART1 omap_uart.2: ttyO2 at MMIO 0x48024000 (irq = 74) is a OMAP UART2 console [ttyO2] enabled brd: module loaded loop: module loaded ahci ahci.0: forcing PORTS_IMPL to 0x3 ahci ahci.0: AHCI 0001.0100 32 slots 2 ports 3 Gbps 0x3 impl platform mode ahci ahci.0: flags: ncq sntf pm led clo only pmp pio slum part ccc scsi0 : ahci_platform scsi1 : ahci_platform ata1: SATA max UDMA/133 irq_stat 0x00400040, connection status changed irq 16 ata2: SATA max UDMA/133 mmio [mem 0x4a140000-0x4a150fff] port 0x180 irq 16 m25p80 spi1.0: found w25q32, expected m25p80 m25p80 spi1.0: w25q32 (4096 Kbytes) Creating 4 MTD partitions on "spi_flash": 0x000000000000-0x000000040000 : "U-Boot" 0x000000040000-0x000000042000 : "U-Boot Env" 0x000000042000-0x0000002c2000 : "Kernel" 0x0000002c2000-0x000000400000 : "File System" omap2-nand driver initializing ONFI flash detected NAND device: Manufacturer ID: 0x2c, Chip ID: 0xca (Micron ) Creating 5 MTD partitions on "omap2-nand.0": 0x000000000000-0x000000260000 : "U-Boot" 0x000000260000-0x000000280000 : "U-Boot Env" 0x000000280000-0x0000006c0000 : "Kernel" 0x0000006c0000-0x00000cee0000 : "File System" 0x00000cee0000-0x000010000000 : "Reserved" davinci_mdio davinci_mdio.0: davinci mdio revision 1.6 davinci_mdio davinci_mdio.0: detected phy mask fffffff9 davinci_mdio.0: probed davinci_mdio davinci_mdio.0: phy[1]: device 0:01, driver unknown davinci_mdio davinci_mdio.0: phy[2]: device 0:02, driver unknown u***core: registered new interface driver cdc_ether u***core: registered new interface driver smsc95xx ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver uhci_hcd: USB Universal Host Controller Interface driver Initializing USB Mass Storage driver... u***core: registered new interface driver u***-storage USB Mass Storage support registered. mice: PS/2 mouse device common for all mice u*** 1-1: new full speed USB device using mu***-hdrc and address 2 omap_rtc omap_rtc: rtc core: registered omap_rtc as rtc0 i2c /dev entries driver Linux video capture interface: v2.00 u***core: registered new interface driver uvcvideo USB Video Class driver (v1.0.0) OMAP Watchdog Timer Rev 0x00: initial timeout 60 sec u***core: registered new interface driver u***hid u***hid: USB HID core driver notify_init : notify drivercreated for remote proc id 2 at physical Address 0xbf900000 u***core: registered new interface driver snd-u***-audio ALSA device list: No soundcards found. TCP cubic registered NET: Registered protocol family 17 VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3 omap_voltage_late_init: Voltage driver support not added Power Management for TI81XX. smartreflex smartreflex: Driver initialized omap_rtc omap_rtc: setting system clock to 2000-01-01 00:00:00 UTC (946684800) ata2: SATA link down (SStatus 0 SControl 300) mmc0: new high speed SD card at address cffe mmcblk0: mmc0:cffe SD02G 1.83 GiB u*** 1-1: New USB device found, idVendor=05e3, idProduct=0606 u*** 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 u*** 1-1: Product: USB Hub 2.0 u*** 1-1: Manufacturer: ALCOR mmcblk0: p1 p2 p3 hub 1-1:1.0: USB hub found hub 1-1:1.0: 4 ports detected u*** 1-1.2: new low speed USB device using mu***-hdrc and address 3 u*** 1-1.2: New USB device found, idVendor=0425, idProduct=0001 u*** 1-1.2: New USB device strings: Mfr=0, Product=1, SerialNumber=0 u*** 1-1.2: Product: USB OPTICAL MOUSE input: USB OPTICAL MOUSE as /devices/platform/omap/ti81xx-u***ss/mu***-hdrc.0/u***1/1-1/1-1.2/1-1.2:1.0/input/input0 generic-u*** 0003:0425:0001.0001: input: USB HID v1.11 Mouse [ USB OPTICAL MOUSE] on u***-mu***-hdrc.0-1.2/input0 ata1: link is slow to respond, please be patient (ready=0) ata1: softreset failed (device not ready) ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300) ata1.00: ATA-8: Hitachi HTS545032B9A300, PB3OC64G, max UDMA/133 ata1.00: 625142448 sectors, multi 0: LBA48 NCQ (depth 31/32) ata1.00: configured for UDMA/133 scsi 0:0:0:0: Direct-Access ATA Hitachi HTS54503 PB3O PQ: 0 ANSI: 5 sd 0:0:0:0: Attached scsi generic sg0 type 0 sd 0:0:0:0: [sda] 625142448 512-byte logical blocks: (320 GB/298 GiB) sd 0:0:0:0: [sda] Write Protect is off sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00 sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA sda: sda1 sda2 sda3 sd 0:0:0:0: [sda] Attached SCSI disk EXT3-fs: barriers not enabled kjournald starting. Commit interval 5 seconds EXT3-fs (sda1): warning: maximal mount count reached, running e2fsck is recommended EXT3-fs (sda1): using internal journal EXT3-fs (sda1): recovery complete EXT3-fs (sda1): mounted filesystem with writeback data mode VFS: Mounted root (ext3 filesystem) on device 8:1. devtmpfs: mounted Freeing init memory: 212K udevd (90): /proc/90/oom_adj is deprecated, please use /proc/90/oom_score_adj instead. udev: starting version 141 minix: disagrees about version of symbol module_layout minix: disagrees about version of symbol module_layout FAT: bogus number of reserved sectors VFS: Can't find a valid FAT filesystem on dev mmcblk0. EXT3-fs (mmcblk0): error: can't find ext3 filesystem on dev mmcblk0. EXT2-fs (mmcblk0): error: can't find an ext2 filesystem on dev mmcblk0. FAT: bogus number of reserved sectors VFS: Can't find a valid FAT filesystem on dev mmcblk0. NET: Registered protocol family 10 ISOFS: Unable to identify CD-ROM format. EXT3-fs: barriers not enabled kjournald starting. Commit interval 5 seconds EXT3-fs (sda3): warning: maximal mount count reached, running e2fsck is recommended EXT3-fs: barriers not enabled EXT3-fs (sda3): using internal journal EXT3-fs (sda3): recovery complete EXT3-fs (sda3): mounted filesystem with writeback data mode kjournald starting. Commit interval 5 seconds EXT3-fs (sda2): warning: maximal mount count reached, running e2fsck is recommended EXT3-fs (sda2): using internal journal EXT3-fs (sda2): recovery complete EXT3-fs (sda2): mounted filesystem with writeback data mode EXT3-fs: barriers not enabled kjournald starting. Commit interval 5 seconds EXT3-fs (mmcblk0p2): warning: maximal mount count reached, running e2fsck is recommended EXT3-fs (mmcblk0p2): using internal journal EXT3-fs (mmcblk0p2): recovery complete EXT3-fs (mmcblk0p2): mounted filesystem with writeback data mode davinci_mdio davinci_mdio.0: resetting idled controller net eth0: attached PHY driver [Generic PHY] (mii_bus:phy_addr=0:01, id=282f014) ADDRCONF(NETDEV_UP): eth0: link is not ready net eth0: DaVinci EMAC: ioctl not supported net eth0: DaVinci EMAC: ioctl not supported net eth1: DaVinci EMAC: ioctl not supported SysLink version : 2.10.03.20 SysLink module created on Date:Apr 29 2012 Time:20:45:11 PHY: 0:01 - Link is Up - 100/Full ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready HDMI W1 rev 2.0 hdmi: Enter HDMI_W1_StopVideoFrame() found best resolution: 1680x1050 (31) Extension block present db 2 23 84 Extension block present db 1 23 84 Extension block present db 3 23 84 Extension block present db 3 23 84 Extension block present db 3 23 84 hdmi: Enter HDMI_W1_GlobalInitVars() hdmi: Enter HDMI_Core_GlobalInitVars() hdmi: Enter HDMI_W1_ConfigVideoResolutionTiming() hdmi: Enter HDMI_W1_ConfigVideoInterface() hdmi: HDMI_WP_AUDIO_CFG = 0x1030006 hdmi: HDMI_WP_AUDIO_CFG2 = 0x20c0 hdmi: HDMI_WP_AUDIO_CTRL = 0x20 hdmi: Enter DSS_HDMI_CORE_SW_RESET_ASSERT () hdmi: Enter DSS_HDMI_CORE_POWER_DOWN_DISABLE() hdmi: Enter DSS_HDMI_CORE_SW_RESET_RELEASE() hdmi: Enter HDMI_W1_StartVideoFrame () hdmi: Irqenable 60000011 hdmi: 40 hpd hdmi: -------------DEBUG------------------- hdmi: 1 hdmi_wp_irqstatus hdmi: 1 hdmi_core_intr_state hdmi: 60 hdmi_core_intr1 hdmi: 3 hdmi_core_intr2 hdmi: f hdmi_core_intr3 hdmi: 87 hdmi_core_sys_sys_stat hdmi: -------------DEBUG------------------- hdmi: first hpd net eth1: attached PHY driver [Generic PHY] (mii_bus:phy_addr=0:02, id=282f014) ADDRCONF(NETDEV_UP): eth1: link is not ready PHY: 0:02 - Link is Up - 100/Full ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready eth0: no IPv6 routers present eth1: no IPv6 routers present root@luhao:~# 求助...我的PCIE网卡是RTL8111C的。 |
24个回答
louis你好,最近有一些进展,以下是 我最近做的测试: |
问题解决了,谢谢大家这么长时间的关注。 Since TI81XX RC supports maximum remote read request size (MRRQS) as 256 bytes, ensure that the EP driver/device you are using doesn't set read request size more than this value. If it does, then modify the driver to set read request size to 256 bytes before building it. Ensuring Maximum Read Request size within 256 Byte limit is required even for any intermediate Switch/Bridge devices in the fabric. 需要改驱动里面read request size,这个每个驱动对应的函数描述不大一样,但是类似,大家可以参考下博通的pcie_set_readrq函数,默认设置的是4096,改成256就行了。 OK。 |
binro 发表于 2018-6-21 05:30 谢谢你的分享 |
只有小组成员才能发言,加入小组>>
458 浏览 0 评论
普中科技F28335开发板每次上电复位后数码管都会显示,如何熄灭它?
310 浏览 1 评论
906 浏览 0 评论
TMS320F28377D:新做了以377d为芯片的板子,上电后芯片复位引脚出现方波请问如何解决?
2081 浏览 0 评论
TPS55340通电后输入端保险丝烧断,芯片输入和GND之间短路
3823 浏览 4 评论
CC3100BOOST使用CC3200lunchXL进行烧录
863浏览 2评论
99浏览 2评论
134浏览 2评论
111浏览 2评论
132浏览 2评论
GMT+8, 2024-9-1 12:19 , Processed in 0.628401 second(s), Total 53, Slave 46 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
