电子发烧友论坛扫一扫,分享给好友
板子已经通过smartLink配置成功
//// Device connect ap//deviceConnectWlan();DeviceDefaultConfig(); while (1)[ _SlNonOsMainLoopTask();] 如果我先连接WIFI ,在进行读写文件,就没问题; DeviceDefaultConfig(); //// Device connect ap//deviceConnectWlan(); 如果我先读写文件, 在调用fs_open之后,就会一直处于_SlNonOsMainLoopTask函数中; void main()[ // // Board Initialization // BoardInit(); // // Initialize the uDMA // UDMAInit(); // // Configure the pinmux settings for the peripherals exercised // PinMuxConfig(); // // Configuring UART // InitTerm(); // // Display banner // DisplayBanner(APPLICATION_NAME); DeviceDefaultConfig(); // // Device connect ap // //deviceConnectWlan(); while (1) [ _SlNonOsMainLoopTask(); ]]//*****************************************************************************//// Close the Doxygen group.//! @]////*****************************************************************************int deviceConnectWlan( void )[ long lRetVal = -1; InitializeAppVariables(); //lRetVal = ConfigureSimpleLinkToDefaultState(); if(lRetVal < 0) [ if (DEVICE_NOT_IN_STATION_MODE == lRetVal) UART_PRINT("Failed to configure the device in its default state nr"); // ASSERT_ON_ERROR(DEVICE_DEFAULT_ERROR); ] UART_PRINT("Device is configured in default state nr"); lRetVal = sl_Start(0, 0, 0); if (lRetVal < 0) [ UART_PRINT("Failed to start the device nr"); ASSERT_ON_ERROR(DEVICE_START_ERROR); ] UART_PRINT("Device started as STATION nr"); UART_PRINT("Connecting to AP: %s ...rn",SSID_NAME); //lRetVal = WlanConnect(); if(lRetVal < 0) [ UART_PRINT("Connection to AP failed nr"); ASSERT_ON_ERROR(DEVICE_CONNECT_ERROR); ] // Wait for WLAN Event while((!IS_CONNECTED(g_ulStatus)) || (!IS_IP_ACQUIRED(g_ulStatus))) [ _SlNonOsMainLoopTask(); ] UART_PRINT("Connected to AP: %s nr",SSID_NAME); UART_PRINT("Device IP: %d.%d.%d.%dnrnr", SL_IPV4_BYTE(g_ulIpAddr,3), SL_IPV4_BYTE(g_ulIpAddr,2), SL_IPV4_BYTE(g_ulIpAddr,1), SL_IPV4_BYTE(g_ulIpAddr,0)); return SUCCESS; ]long DeviceDefaultConfig( void )[ long lRetVal = -1; // // create a user file // lRetVal = sl_FsOpen((unsigned char *)USER_FILE_NAME, FS_MODE_OPEN_CREATE(65536, _FS_FILE_OPEN_FLAG_COMMIT|_FS_FILE_PUBLIC_WRITE), NULL, lFileHandle); if(lRetVal < 0) [ // // File may already be created // lRetVal = sl_FsClose(*lFileHandle, 0, 0, 0); ASSERT_ON_ERROR(lRetVal); ] else [ // // close the user file // lRetVal = sl_FsClose(*lFileHandle, 0, 0, 0); if (SL_RET_CODE_OK != lRetVal) [ ASSERT_ON_ERROR(FILE_CLOSE_ERROR); ] ] Report("Cread file success.rn"); lRetVal = sl_FsOpen((unsigned char *)USER_FILE_NAME, FS_MODE_OPEN_READ, NULL, lFileHandle); if(lRetVal < 0) [ lRetVal = sl_FsClose(*lFileHandle, 0, 0, 0); ASSERT_ON_ERROR(FILE_OPEN_WRITE_FAILED); ] Report("open read is success.rn"); return SUCCESS;] 代码如下: |
1个回答
文件系统是通过NWP进行读写的,在文件读写之前需要将Sl_Start()开启后才能正常操作文件系统
只有小组成员才能发言,加入小组>>
549 浏览 0 评论
1613 浏览 0 评论
2047 浏览 0 评论
为啥BQ7693003DBTR芯片在和BQ769X0盒子通讯时收不到信号?
1513 浏览 0 评论
DSP 28027F 开发板 XDS100v2调试探针诊断日志显示了 Error -150 (SC_ERR_FTDI_FAIL)如何解决
1337 浏览 0 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
1757浏览 29评论
2781浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
1724浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
1634浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
1645浏览 13评论
/9
GMT+8, 2025-12-2 06:50 , Processed in 0.796944 second(s), Total 75, Slave 58 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
4394
