电子发烧友论坛扫一扫,分享给好友
在用Sitara, 在用Windows 7。 想用Flash Tool. 但是Flash Tool User Guide里说
Applicability For Sitara SDK 5.0.2: For AM35x, AM37x, DM37x and OMAP35x devices: 1. This Windows XP-based Flash Toolcan be used to program x-loader, u-boot and kernel to NAND flash. -----http://processors.wiki.ti.com/index.php/Flash_v1.6_User_Guide#Applicability 非常不爽,不成我还要去装一下Windows XP专门干这个事不成。 同样要在Windows 7下使用Flashtool的有木有。请向下看。(欢迎转载,但必须指明出处为www.deyisupport.com,另请保留作者信息,谢谢)。 Use TI Flashtool 1.6 overWindows 7 David Chan Blacksword.David@gmail.com Asthe product developed, I was asked to provide a easy to use method to thefactory for them to program the product. Wehave created some assistant board just used to program the product. But youknow this will do have a big plus to the BOM if we build a lot of the assistantboards. Asthe product is based on TI's OMAP3. USB boot and UART boot is supported on thisplatform, and TI provide a tool named Flashtool help the customer to do thejob. Whata good tool the Flashtool is! But unfortunately TI mention in the guide: Applicability For Sitara SDK 5.0.2: For AM35x, AM37x, DM37x and OMAP35x devices: 1. This Windows XP-based Flash Toolcan be used to program x-loader, u-boot and kernel to NAND flash. -----http://processors.wiki.ti.com/index.php/Flash_v1.6_User_Guide#Applicability It is WindowsXP-based Flash Tool. What a bad news for us. You know my pc runs Windows 7, andMost of the PC in our product build team runs Windows 7. ShouldI have the whole team downgrade to Windows XP? You know how hard it is! Itmeans that I have to build my own flash tool or have the TI Flash Tool runableunder Windows 7. Asthe program can be opened under Windows 7, and the USB driver of OMAP can beeninstalled under Windows 7. I do think that there is no reason that Flash Toolcan not be used with Windows 7. Afteranalyze, I found there is nothing different for Flash Tool to run with WindowsXP or Windows 7 except the USB is allowed to access or not. It'svery clear the that t security mechanism of Windows 7 will block the access toUSB of the Flash Tool. Ok,Just let's tell the Windows 7 to allow Flash tool to access the USB driver ofthe OMAP3. Right on the Flash.exe and choose Property in the menu. See Figure1. Figure1.Flash.exe in menu Inthe property sheets of the Flash.exe, go to page "Compatibility". Then turn onthe option "Run this program as an administrator". See Figure 2. And click okto save the settings. Figure2 Property of Flash.exe Nowjust run the Flash.exe, you can use it to program you Sitara/Omap platform withWindows 7 just like what you have done with Windows XP. Figure 3 shows "EraseAll" regions of the NAND on the OMAP3 board. |
1个回答
只有小组成员才能发言,加入小组>>
549 浏览 0 评论
1613 浏览 0 评论
2047 浏览 0 评论
为啥BQ7693003DBTR芯片在和BQ769X0盒子通讯时收不到信号?
1513 浏览 0 评论
DSP 28027F 开发板 XDS100v2调试探针诊断日志显示了 Error -150 (SC_ERR_FTDI_FAIL)如何解决
1337 浏览 0 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
1756浏览 29评论
2781浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
1724浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
1634浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
1645浏览 13评论
/9
GMT+8, 2025-12-2 01:23 , Processed in 0.583652 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1299
