电子发烧友论坛扫一扫,分享给好友
用6657EVM烧写NAND FLASH,出现下面的错误,注意标红的部分,看起来是随机错误,找不到原因
[C66xx_0] NAND Writer Utility Version 01.00.00.01 [C66xx_0] [C66xx_0] Flashing block 1 (0 bytes of 263568) [C66xx_0] Flashing block 2 (131072 bytes of 263568) [C66xx_0] Flashing block 3 (262144 bytes of 263568) [C66xx_0] Reading and verifying block 1 (0 bytes of 263568) [C66xx_0] Failure in block 1, at byte 961, (at byte 0 in the data file) expected 0x00000000, read 0x00000000 [C66xx_0] Flashing block 1 (0 bytes of 263568) [C66xx_0] Flashing block 2 (131072 bytes of 263568) [C66xx_0] Flashing block 3 (262144 bytes of 263568) [C66xx_0] Reading and verifying block 1 (0 bytes of 263568) [C66xx_0] Failure in block 1, at byte 33, (at byte 0 in the data file) expected 0x00000080, read 0x00000080 [C66xx_0] Flashing block 1 (0 bytes of 263568) [C66xx_0] Flashing block 2 (131072 bytes of 263568) [C66xx_0] Flashing block 3 (262144 bytes of 263568) [C66xx_0] Reading and verifying block 1 (0 bytes of 263568) [C66xx_0] Failure in block 1, at byte 691, (at byte 0 in the data file) expected 0x00000000, read 0x00000000 [C66xx_0] Flashing block 1 (0 bytes of 263568) [C66xx_0] Flashing block 2 (131072 bytes of 263568) [C66xx_0] Flashing block 3 (262144 bytes of 263568) [C66xx_0] Reading and verifying block 1 (0 bytes of 263568) [C66xx_0] Failure in block 1, at byte 541, (at byte 0 in the data file) expected 0x00000080, read 0x00000080 [C66xx_0] Flashing block 1 (0 bytes of 263568) [C66xx_0] Flashing block 2 (131072 bytes of 263568) [C66xx_0] Flashing block 3 (262144 bytes of 263568) [C66xx_0] Reading and verifying block 1 (0 bytes of 263568) [C66xx_0] Failure in block 1, at byte 1069, (at byte 0 in the data file) expected 0x00000000, read 0x00000000 [C66xx_0] NAND write failed (maximum retries reached) |
3个回答
忘说了,烧写程序用到是MCSDK自带的nandwriter_EVMC6657。修改了nand_writer_input.txt,内容为
file_name = app.bin start_addr = 131072 |
问题暂时解决。
原来的程序中读写NAND的数据都放在了DDR里,我把它改为放在MSMC中,加了cache一致性保护,顺利烧写。 原来的程序貌似缺少对DDR的初始化。 其他人就没有遇到过这个问题吗?这个MCSDK自带的程序应该有很多人在用啊 |
fdhsfagd 发表于 2018-6-21 17:10 Hi wang: 首先用MCSDK提供的工具进行NAND写,必须执行GEL文件以初始化DDR3,然后一切才能正常。此时用户程序装入的地址是:0x8000000。 如果采用MSMC内存,你必须调整MCSDK的NAND写工具中的地址为:0x0C000000,并且此时用户程序装入的地址是:0x0C00000。 |
只有小组成员才能发言,加入小组>>
601 浏览 0 评论
1654 浏览 0 评论
2096 浏览 0 评论
为啥BQ7693003DBTR芯片在和BQ769X0盒子通讯时收不到信号?
1542 浏览 0 评论
DSP 28027F 开发板 XDS100v2调试探针诊断日志显示了 Error -150 (SC_ERR_FTDI_FAIL)如何解决
1386 浏览 0 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
1794浏览 29评论
2821浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
1748浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
1667浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
1681浏览 13评论
/9
GMT+8, 2025-12-15 02:51 , Processed in 0.683811 second(s), Total 78, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3714
