电子发烧友论坛|
你好, 我使用AM1808,linux3.2.0, 插入U盘,一点反应都没有,插入鼠标还有信息打印出来。请问到底要怎么样配置menuconfig才能读U盘啊,网上收罗各种配置我都试过了。 补充:USB硬件口是USB1,对的。 系统运行时调试信息显示各种驱动都加载了,但插入U盘就是没有反应。请大神帮帮忙,搞了1周了。 |
2个回答
补充: 这是调试信息,感觉各种驱动都已经加载了。
Console: colour dummy device 80x30 Calibrating delay loop... 148.88 BogoMIPS (lpj=744448) pid_max: default: 32768 minimum: 301 Mount-cache hash table entries: 512 CPU: Testing write buffer coherency: ok devtmpfs: initialized DaVinci: 144 gpio irqs NET: Registered protocol family 16 baseboard_pre_init: Entered mityomapl138_setup_nand: using 8 bit data baseboard_init [IndustrialIO]... bio: create slab SCSI subsystem initialized u***core: registered new interface driver u***fs u***core: registered new interface driver hub u***core: registered new device driver u*** Switching to clocksource timer0_1 NET: Registered protocol family 2 IP route cache hash table entries: 1024 (order: 0, 4096 bytes) TCP established hash table entries: 4096 (order: 3, 32768 bytes) TCP bind hash table entries: 4096 (order: 2, 16384 bytes) TCP: Hash tables configured (established 4096 bind 4096) TCP reno registered UDP hash table entries: 256 (order: 0, 4096 bytes) UDP-Lite hash table entries: 256 (order: 0, 4096 bytes) NET: Registered protocol family 1 RPC: Registered named UNIX socket transport module. RPC: Registered udp transport module. RPC: Registered tcp transport module. RPC: Registered tcp NFSv4.1 backchannel transport module. NTFS driver 2.1.30 [Flags: R/W DEBUG]. JFFS2 version 2.2. (NAND) 漏 2001-2006 Red Hat, Inc. msgmni has been set to 179 io scheduler noop registered (default) start plist test end plist test Serial: 8250/16550 driver, 3 ports, IRQ sharing disabled serial8250.0: ttyS0 at MMIO 0x1c42000 (irq = 25) is a 16550A serial8250.0: ttyS1 at MMIO 0x1d0c000 (irq = 53) is a 16550A console [ttyS1] enabled serial8250.0: ttyS2 at MMIO 0x1d0d000 (irq = 61) is a 16550A brd: module loaded u***core: registered new interface driver ub at24 1-0050: 256 byte 24c02 EEPROM, read-only, 0 bytes/write MityOMAPL138: Read Factory Config Failed: -110 Uniform Multi-Platform E-IDE driver ide-gd driver 1.18 st: Version 20101219, fixed bufsize 32768, s/g segs 256 ONFI flash detected ONFI param page 0 valid NAND device: Manufacturer ID: 0x2c, Chip ID: 0xda (Micron MT29F2G08ABAEAWP) Bad block table found at page 131008, version 0x01 Bad block table found at page 130944, version 0x01 Creating 2 MTD partitions on "davinci_nand.1": 0x000000000000-0x000008000000 : "rootfs" 0x000008000000-0x000010000000 : "homefs" davinci_nand davinci_nand.1: controller rev. 2.5 spi_davinci spi_davinci.1: DMA: supported spi_davinci spi_davinci.1: DMA: RX channel: 18, TX channel: 19, event queue: 0 m25p80 spi1.0: m25p64-nonjedec (8192 Kbytes) Creating 8 MTD partitions on "m25p80": 0x000000000000-0x000000010000 : "ubl" 0x000000010000-0x000000090000 : "u-boot" 0x000000090000-0x0000000a0000 : "u-boot-env" 0x0000000a0000-0x0000000b0000 : "periph-config" Using LCD panel: baseboard_setup_lcd: unknown LCD type : RMII PHY configured 0x0000000b0000-0x000000100000 : "reserved" 0x000000100000-0x000000400000 : "kernel" 0x000000400000-0x000000600000 : "fpga" 0x000000600000-0x000000800000 : "spare" spi_davinci spi_davinci.1: Controller at 0xfef0e000 CAN device driver interface mcp251x spi1.1: MCP251x didn't enter in conf mode after reset mcp251x spi1.1: Probe failed mcp251x spi1.1: probe failed davinci_mdio davinci_mdio.0: davinci mdio revision 1.5 davinci_mdio davinci_mdio.0: detected phy mask fffffffe davinci_mdio.0: probed davinci_mdio davinci_mdio.0: phy[0]: device 0:00, driver unknown u***core: registered new interface driver hwa-rc ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver ohci ohci.0: DA8xx OHCI ohci ohci.0: new USB bus registered, assigned bus number 1 Waiting for USB PHY clock good... ohci ohci.0: irq 59, io mem 0x01e25000 u*** u***1: New USB device found, idVendor=1d6b, idProduct=0001 u*** u***1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 u*** u***1: Product: DA8xx OHCI u*** u***1: Manufacturer: Linux 3.2.0 ohci_hcd u*** u***1: SerialNumber: ohci.0 hub 1-0:1.0: USB hub found hub 1-0:1.0: 1 port detected u***core: registered new interface driver uas Initializing USB Mass Storage driver... u***core: registered new interface driver u***-storage USB Mass Storage support registered. u***core: registered new interface driver libusual u***core: registered new interface driver ums-alauda u***core: registered new interface driver ums-cypress u***core: registered new interface driver ums-datafab u***core: registered new interface driver ums_eneub6250 u***core: registered new interface driver ums-freecom u***core: registered new interface driver ums-isd200 u***core: registered new interface driver ums-jumpshot u***core: registered new interface driver ums-karma u***core: registered new interface driver ums-onetouch u***core: registered new interface driver ums-realtek u***core: registered new interface driver ums-sddr09 u***core: registered new interface driver ums-sddr55 u***core: registered new interface driver ums-u***at u***core: registered new interface driver u***serial u***serial: USB Serial Driver core idmouse: 0.6:Siemens ID Mouse FingerTIP Sensor Driver u***core: registered new interface driver idmouse mousedev: PS/2 mouse device common for all mice omap_rtc omap_rtc: rtc core: registered omap_rtc as rtc0 omap_rtc: RTC power up reset detected omap_rtc: already running i2c /dev entries driver cpuidle: using governor ladder cpuidle: using governor menu davinci_mmc davinci_mmc.0: Using DMA, 4-bit mode u***core: registered new interface driver ushc u***core: registered new interface driver u***hid u***hid: USB HID core driver u***ip_core: USB/IP Core v1.0.0 u***core: registered new interface driver u***ip-host u***ip_host: USB/IP Host Driver v1.0.0 下面是插入一个鼠标,有反应: root@mityomapl138:~# u*** 1-1: new low-speed USB device number 2 using ohci u*** 1-1: device descriptor read/64, error -62 u*** 1-1: device descriptor read/64, error -62 u*** 1-1: new low-speed USB device number 3 using ohci u*** 1-1: device descriptor read/64, error -62 u*** 1-1: device descriptor read/64, error -62 u*** 1-1: new low-speed USB device number 4 using ohci u*** 1-1: device not accepting address 4, error -62 u*** 1-1: new low-speed USB device number 5 using ohci u*** 1-1: device not accepting address 5, error -62 hub 1-0:1.0: unable to enumerate USB device on port 1 但插入U盘,确实一点反应都没有。 请大神帮忙看看,要如何才能识别U盘啊 |
杀戮之神 发表于 2018-6-21 01:43 我找到原因了,原来是USB接口的信号定义搞反了。 |
只有小组成员才能发言,加入小组>>
549 浏览 0 评论
1613 浏览 0 评论
2047 浏览 0 评论
为啥BQ7693003DBTR芯片在和BQ769X0盒子通讯时收不到信号?
1513 浏览 0 评论
DSP 28027F 开发板 XDS100v2调试探针诊断日志显示了 Error -150 (SC_ERR_FTDI_FAIL)如何解决
1337 浏览 0 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
1756浏览 29评论
2781浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
1724浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
1634浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
1645浏览 13评论
/9
GMT+8, 2025-12-2 04:30 , Processed in 3.256505 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2653
