我用自己的u-boot和内核加ti论坛上搜到文件系统FlasherFS,在BBBlack开发板上可以跑起来,但是我看不到他动态分配的地址。是什么引起的,还是哪里出问题了? 启动log: [ 2.259514] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6 [ 2.265901] davinci_mdio 4a101000.mdio: detected phy mask fffffffe [ 2.275152] libphy: 4a101000.mdio: probed [ 2.279365] davinci_mdio 4a101000.mdio: phy[0]: device 4a101000.mdio:00, driv er SMSC LAN8710/LAN8720 [ 2.290715] Detected MACID = f4:5e:ab:64:34:0d [ 2.300706] omap_rtc 44e3e000.rtc: setting system clock to 2014-02-17 19:04:4 6 UTC (1392663886) [ 2.336006] EXT3-fs (mmcblk0p2): recovery required on readonly filesystem [ 2.343301] EXT3-fs (mmcblk0p2): write access will be enabled during recovery [ 2.370333] kjournald starting. Commit interval 5 seconds [ 2.380836] EXT3-fs (mmcblk0p2): recovery complete [ 2.385855] EXT3-fs (mmcblk0p2): mounted filesystem with ordered data mode [ 2.393233] VFS: Mounted root (ext3 filesystem) readonly on device 179:2. [ 2.403402] devtmpfs: mounted [ 2.407083] Freeing unused kernel memory: 376K (c07f0000 - c084e000) INIT: version 2.88 booting Starting udev [ 2.993469] udev[701]: starting version 164 [ 7.490267] random: nonblocking pool is initialized Starting Bootlog daemon: bootlogd: cannot allocate pseudo tty: No such file or d irectory bootlogd. [ 8.391469] EXT3-fs (mmcblk0p2): using internal journal Configuring network interfaces... [ 9.193776] net eth0: initializing cpsw ver sion 1.12 (0) [ 9.280277] net eth0: phy found : id is : 0x7c0f1 [ 9.285338] libphy: PHY 4a101000.mdio:01 not found [ 9.290394] net eth0: phy 4a101000.mdio:01 not found on slave 1 udhcpc (v1.20.2) started Sending discover... [ 12.390071] libphy: 4a101000.mdio:00 - Link is Up - 100/Full Sending discover... Sending discover... No lease, failing done. INIT: Entering runlevel: 5 Starting syslogd/klogd: done Stopping Bootlog daemon: bootlogd. _____ _____ _ _ | _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_ | | _| .'| . | . | | __| _| . | | | -_| _| _| |__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_| |___| |___| Arago Project http://arago-project.org zyr-am335x ttyO0 Arago 2013.05 zyr-am335x ttyO0 我也可以ifconfig找到eth0: eth0 Link encap:Ethernet HWaddr F4:5E:AB:64:34:0D UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:0 errors:0 dropped:0 overruns:0 frame:0 TX packets:139 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:0 (0.0 B) TX bytes:44758 (43.7 KiB) Interrupt:56 lo Link encap:Local Loopback inet addr:127.0.0.1 Mask:255.0.0.0 UP LOOPBACK RUNNING MTU:65536 Metric:1 RX packets:0 errors:0 dropped:0 overruns:0 frame:0 TX packets:0 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:0 RX bytes:0 (0.0 B) TX bytes:0 (0.0 B) 但是并没发现它分配的动态IP地址。 查看etc下的resolv.conf 里边也是空的。 使用udhcpc命令,一直是Sending Discover... root@zyr-am335x:~# udhcpc -i eth0 udhcpc (v1.20.2) started Sending discover... Sending discover... Sending discover... Sending discover... Sending discover... Sending discover... 发生这种情况是什么造成的? |
2个回答
请问您是在测试烧写么?是用USB模拟网卡么?
不是在测试烧写,我已经烧写完毕了,不是模拟u***网卡,我可以手动分配静态IP的 |
只有小组成员才能发言,加入小组>>
NA555DR VCC最低电压需要在5V供电,为什么用3.3V供电搭了个单稳态触发器也使用正常?
669 浏览 3 评论
MSP430F249TPMR出现高温存储后失效了的情况,怎么解决?
597 浏览 1 评论
对于多级放大电路板,在PCB布局中,电源摆放的位置应该注意什么?
1048 浏览 1 评论
731 浏览 0 评论
普中科技F28335开发板每次上电复位后数码管都会显示,如何熄灭它?
520 浏览 1 评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
158浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
120浏览 14评论
在使用3254进行录音的时候出现一个奇怪的现象,右声道有吱吱声,请教一下,是否是什么寄存器设置存在问题?
123浏览 13评论
TLV320芯片内部自带数字滤波功能,请问linein进来的模拟信号是否是先经过ADC的超采样?
122浏览 12评论
TPA6304-Q1: TPA6304 两片公用一组I2C的话,其中一片配置不成功怎么办
163浏览 10评论
GMT+8, 2024-11-22 16:08 , Processed in 0.805811 second(s), Total 77, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
