扫一扫,分享给好友
各位网友你们好,用STM32f7搭载了rt-thread操作系统,移植lwip1.4.1版本的,网卡用的是Lan8720, 网卡可以初始化程序,但是dhcp一直失败,打印信息如下,请问这个是什么问题呢???
netif->output()dhcp_discover: deleting()ing dhcp_discover: SELECTING dhcp_discover(): set request timeout 4000 msecs dhcp_fine_tmr(): request timeout dhcp_timeout() dhcp_timeout(): restarting discovery dhcp_discover() transaction id xid(718021cb) dhcp_discover: making request dhcp_discover: realloc()ing dhcp_discover: sendto(DISCOVER, IP_ADDR_BROADCAST, DHCP_SERVER_PORT) udp_send: added header in given pbuf 20033584 udp_send: sending datagram of length 316 udp_send: UDP packet length 316 udp_send: UDP checksum 0x0000 udp_send: ip_output_if (,,,,IP_PROTO_UDP,) ip_output_if: hg0 IP header: +-------------------------------+ | 4 | 5 | 0x00 | 336 | (v, hl, tos, len) +-------------------------------+ | 3 |000| 0 | (id, flags, offset) +-------------------------------+ | 255 | 17 | 0x0000 | (ttl, proto, chksum) +-------------------------------+ | 0 | 0 | 0 | 0 | (src) +-------------------------------+ | 255 | 255 | 255 | 255 | (dest) +-------------------------------+ netif->output()dhcp_discover: deleting()ing dhcp_discover: SELECTING dhcp_discover(): set request timeout 8000 msecs dhcp_fine_tmr(): request timeout dhcp_timeout() dhcp_timeout(): restarting discovery dhcp_discover() transaction id xid(718021cb) dhcp_discover: making request dhcp_discover: realloc()ing dhcp_discover: sendto(DISCOVER, IP_ADDR_BROADCAST, DHCP_SERVER_PORT) udp_send: added header in given pbuf 20033584 udp_send: sending datagram of length 316 udp_send: UDP packet length 316 udp_send: UDP checksum 0x0000 udp_send: ip_output_if (,,,,IP_PROTO_UDP,) ip_output_if: hg0 IP header: +-------------------------------+ | 4 | 5 | 0x00 | 336 | (v, hl, tos, len) +-------------------------------+ | 4 |000| 0 | (id, flags, offset) +-------------------------------+ | 255 | 17 | 0x0000 | (ttl, proto, chksum) +-------------------------------+ | 0 | 0 | 0 | 0 | (src) +-------------------------------+ | 255 | 255 | 255 | 255 | (dest) +-------------------------------+ netif->output()dhcp_discover: deleting()ing dhcp_discover: SELECTING dhcp_discover(): set request timeout 16000 msecs dhcp_fine_tmr(): request timeout dhcp_timeout() dhcp_timeout(): restarting discovery dhcp_discover() transaction id xid(718021cb) dhcp_discover: making request dhcp_discover: realloc()ing dhcp_discover: sendto(DISCOVER, IP_ADDR_BROADCAST, DHCP_SERVER_PORT) udp_send: added header in given pbuf 20033584 udp_send: sending datagram of length 316 udp_send: UDP packet length 316 udp_send: UDP checksum 0x0000 udp_send: ip_output_if (,,,,IP_PROTO_UDP,) ip_output_if: hg0 IP header: |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
1618 浏览 1 评论
1260 浏览 0 评论
1114 浏览 0 评论
STM32F405驱动DS1302时钟模块,输出时间错乱该怎么排查?
5494 浏览 2 评论
stm32f405rgt6驱动DS1302ZN出现时间错乱问题
4285 浏览 1 评论
/9
GMT+8, 2025-12-17 19:42 , Processed in 0.540466 second(s), Total 69, Slave 52 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3257
