我把MLO.spi和u-boot.img分别烧写到SPI FLASH的0x0和0x20000,然后设置从SPI启动。结果出现了如下的提示信息,一直卡在这里: U-Boot SPL 2011.09 (Mar 19 2013 - 15:02:01) Texas Instruments Revision detection unimplemented Could not probe the EEPROM; something fundamentally wrong on the I2C bus. read_eeprom() failure. continuing with ddr3 No daughter card present Did not find a recognized configuration, assuming General purpose EVM in Profile 0 with Daughter board SF: Detected W25Q64 with page size 4 KiB, total 8 MiB 我跟进去,找到了函数:spi_boot,然后打印出在内存CONFIG_SYS_TEXT_BASE的内容,和u-boot.img的内容是完全一样的,可是u-boot.img为什么就没有被执行呢?(注:我使用的是自己做的板子,用这个u-boot.img放到SD卡中,是可以被正常执行的) void spi_boot(void) [ struct spi_flash *flash; void (*uboot)(void) __noreturn; /* * Load U-Boot image from SPI flash into RAM */ flash = spi_flash_probe(CONFIG_SPL_SPI_BUS, CONFIG_SPL_SPI_CS, CONFIG_SF_DEFAULT_SPEED, SPI_MODE_3); if (!flash) [ puts("failed.n"); hang(); ] spi_flash_read(flash, CONFIG_SYS_SPI_U_BOOT_OFFS, CONFIG_SYS_SPI_U_BOOT_SIZE, (void *) CONFIG_SYS_TEXT_BASE); /* * Jump to U-Boot image */ uboot = (void *) CONFIG_SYS_TEXT_BASE; (*uboot)(); ] |
19个回答
根据你的log信息,ms没有去掉EEPROM。
read_eeprom() failure. continuing with ddr3 你可以在board/ti/arm335x/evm.c中的board_init()函数中去掉EEPROM的相关操作。 |
林宇宣55 发表于 2018-6-4 08:38 我现在去掉了EEPROM的相关操作了,还是一样的。而且我感觉跟EEPROM没什么关系。程序运行到函数:(*uboot)(),也就是u-boot.img,就过不去了。但是当我make am335x_evm产生的MLO和make am335x_evm_spiboot产生的u-boot.img 一起放到MMC卡,这时候可以正常启动,进入到u-boot命令行: U-Boot SPL 2011.09 (Mar 19 2013 - 10:08:40) Texas Instruments Revision detection unimplemented Could not probe the EEPROM; something fundamentally wrong on the I2C bus. read_eeprom() failure. continuing with ddr3 No daughter card present Did not find a recognized configuration, assuming General purpose EVM in Profile 0 with Daughter board OMAP SD/MMC: 0 reading u-boot.img U-Boot 2011.09 (Mar 20 2013 - 10:01:42) I2C: ready DRAM: 256 MiB WARNING: Caches not enabled NAND: HW ECC Hamming Code selected No NAND device found!!! 0 MiB MMC: OMAP SD/MMC: 0, OMAP SD/MMC: 1 SF: Detected W25Q64 with page size 4 KiB, total 8 MiB *** Warning - bad CRC, using default environment Net: cpsw Hit any key to stop autoboot: 0 U-Boot# 这样的话,应该能表明u-boot.img也没错啊,可是为什么从SPI FLASH读出来后没能正常执行呢? |
LY90186 发表于 2018-6-4 08:50 uboot 烧写的地址对么? 如果我的回答解决了您的问题,请确认答案,谢谢!:) |
对的,我打印出来uboot=0x80100000,和Am335x_evm.h里面定义的是一样的。而且我在执行(*uboot)()函数前,把内存起始地址为0x80100000的内容给打印出来,跟下载到SPI FLASH的u-boot.img比较,内容也是完全一样的。 |
LY90186 发表于 2018-6-4 08:50 您好,我看了您之前的帖子,您之前没有发现spi SF: Unsupported manufacturer ff Failed to initialize SPI flash at 0:0 ,现在我看您的信息已经发现了SF: Detected W25Q64 with page size 4 KiB, total 8 MiB,您做了什么处理?请指教,我的QQ:348566267 |
ji56789 发表于 2018-6-4 09:36 将EVM 的PROFILE开关2设置为ON,其余设置为OFF 同时需要重新编译u-boot, |
我也出现了上述现象,一直卡在这里
U-Boot SPL 2011.09 (Apr 16 2013 - 17:09:41) Texas Instruments Revision detection unimplemented No daughter card present Did not find a recognized configuration, assuming General purpose EVM in Profile 0 with Daughter board SF: Detected W25Q64 with page size 4 KiB, total 8 MiB 请问楼主解决了吗?跪求解决啊 |
你好,启动方式我是选择对的了。而且我也是用make O=am335x CROSS_COMPILE=arm-arago-linux-gnueabi- ARCH=arm am335x_evm_spiboot 这条命令去生成对应的文件,不过我生成的文件是:MLO.spi和u-boot.img,并没有你说的MLO.byteswap,烧写到SPI FLASH对应的位置是0x0,0x20000 |
LY90186 发表于 2018-6-4 10:22 解决方法在sitara-linuxsdk-sdg-05.05.00.00.pdf找到了: U-Boot# sf probe 0 U-Boot# sf erase 0 +80000 U-Boot# mmc rescan U-Boot# fatload mmc 0 $[loadaddr] MLO.spi U-Boot# sf write $[loadaddr] 0 $[filesize] U-Boot# fatload mmc 0 $[loadaddr] u-boot.bin U-Boot# sf write $[loadaddr] 0x20000 $[filesize] 我应当使用u-boot.bin而不是u-boot.img。 |
LY90186 发表于 2018-6-4 10:34 我也解决了 方法和你的一样 但是现在网络不能用 您的网络能用吗 Lee Jiejia |
可以用啊,网络那一部分的内容我什么也没改。不过IP得两边都设置为同一网段。 请问你的kernel也能成功加载了吗? |
你的是什么开发板 我的QQ是348566267 加我 我们QQ聊 |
LY90186 发表于 2018-6-4 10:34 想请问一下,从SPI FLASH启动时,uboot的启动参数要怎么设置,设置完成后要怎么保存到SPI FLASH中去。 已经找到了相关资料:http://processors.wiki.ti.com/index.php/Booting_Linux_kernel_using_U-Boot#SPI_Flash。至于变量的保存,只需要在u-boot 命令行下输入saveenv即可。 |
你好 我正在做 spi flash 启动 我们的 spi flash 换成了 W25Q128 情况和你一样 也还是运行到 SF: Detected W25Q128 with page size 4 KiB, total 16 MiB 就停止了,我想问一下怎么 打印出在内存CONFIG_SYS_TEXT_BASE的内容,和 u-boot.img 的内容啊!! qq 296380219
LY90186 发表于 2018-6-4 11:25 最近我也在搞这个spi启动uboot,目前遇到sd卡启动下发送sf probe 0,不能识别flash的情况,我的uboot版本是2011.09(英蓓特的版本),跟你的版本是一样的,我修改了evm.c中的通用版管脚设置,修改了am335x_evm.h 中对应的板子上的flash型号的定义,编译后总是出现 sf: unsupport manufacture 0,看到你已经解决了,麻烦问问是怎么解决的,我的qq:20112000,请赐教 |
lu90597 发表于 2018-6-4 11:46 已解决,硬件问题 |
Hi Gary, 你好。 我在BeagleBone Black板子上Mount一个W25Q64,通过修改Uboot代码,配置SPI0,将I2C1的Mux配置代码注释掉了。将U-boot配置成AM335x_evm_spiboot再重新编译 ,生成了MLO和uboot.img文件,没有MLO.byteswap文件。copy到SD卡里,将S2强制接地(boot引脚为11000),然后上电,从串口输出了字符发现了SPI DataFlash,然后我按如下命令烧录,再重新上电,串口什么信息也没有输出。我用的是arm-rtems4.11-gcc, 内核是RTEMS 4.11操作系统,不是Linux. 如下是我的LOG,请赐教。 U-Boot# mmc rescan U-Boot# sf probe 0 SF: Detected W25Q64CV with page size 256 Bytes, erase size 4 KiB, total 8 MiB U-Boot# sf erase 0 +80000 SF: 524288 bytes @ 0x0 Erased: OK U-Boot# fatload mmc 0 $[loadaddr] MLO reading MLO 76548 bytes read in 8 ms (9.1 MiB/s) U-Boot# sf write $[loadaddr] 0 $[filesize] SF: 76548 bytes @ 0x0 Written: OK U-Boot# fatload mmc 0 $[loadaddr] u-boot.img reading u-boot.img 341928 bytes read in 23 ms (14.2 MiB/s) U-Boot# sf write $[loadaddr] 0x20000 $[filesize] SF: 341928 bytes @ 0x20000 Written: OK U-Boot# sf erase 80000 +$[spiimgsize] SF: 3604480 bytes @ 0x80000 Erased: OK U-Boot# fatload mmc 0 $[loadaddr] rtems-app.img reading rtems-app.img 60295 bytes read in 9 ms (6.4 MiB/s) U-Boot# sf write $[loadaddr] $[spisrcaddr] $[filesize] SF: 60295 bytes @ 0xe0000 Written: OK U-Boot# run spiboot Booting from spi ... SF: Detected W25Q64CV with page size 256 Bytes, erase size 4 KiB, total 8 MiB SPI RXS timed out, status=0x00000007 SF: 3547136 bytes @ 0xe0000 Read: ERROR Bad Linux ARM zImage magic! U-Boot# |
LY90186 发表于 2018-6-4 10:34 Hi Lee, 我也没有生成 MLO.spi, 只有MLO,请问你的uboot.img怎样转换成uboot.bin的?我的uboot配置是am335x_evm_spiboot |
只有小组成员才能发言,加入小组>>
549 浏览 0 评论
1613 浏览 0 评论
2047 浏览 0 评论
为啥BQ7693003DBTR芯片在和BQ769X0盒子通讯时收不到信号?
1513 浏览 0 评论
DSP 28027F 开发板 XDS100v2调试探针诊断日志显示了 Error -150 (SC_ERR_FTDI_FAIL)如何解决
1337 浏览 0 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
1756浏览 29评论
2781浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
1723浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
1634浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
1645浏览 13评论
/9
GMT+8, 2025-12-1 22:34 , Processed in 1.100343 second(s), Total 108, Slave 92 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3499
