扫一扫,分享给好友
/mnt/nfs/Z-Stack_Linux_Gateway-1.0.1/z-stack_linux_gateway_ARM_binaries/servers # ./zigbeeHAgw bbb
running zigbeegw.scr on an ARM resetting beaglebone black ../tools/bbb_u***reset.bin: line 1: syntax error: unexpected word (expecting ")") sleeping 6 seconds after reset... ../tools/gw_soc_fw_version_query.bin: line 1: syntax error: unexpected word (expecting ")") done stty: /dev/ttyACM0: Inappropriate ioctl for device stty: /dev/ttyACM0: Inappropriate ioctl for device Starting the ZigBee gateway subsystem ./NPI_lnx_arm_server: line 1: syntax error: unexpected word (expecting ")") NPI started (pid 564) at Fri Aug 28 09:04:59 UTC 2015 ./ZLSZNP_arm: line 1: syntax error: unexpected word (expecting ")") ZLSZNP started (pid 571) at Fri Aug 28 09:05:03 UTC 2015 ./NWKMGR_SRVR_arm: line 1: syntax error: unexpected word (expecting ")") NETWORK MANAGER started (pid 578) at Fri Aug 28 09:05:04 UTC 2015 ./GATEWAY_SRVR_arm: line 1: syntax error: unexpected word (expecting ")") GATEWAY SERVER started (pid 585) at Fri Aug 28 09:05:06 UTC 2015 ./OTA_SRVR_arm: line 1: syntax error: unexpected word (expecting ")") OTA SERVER started (pid 592) at Fri Aug 28 09:05:08 UTC 2015 starting tracker with our pid ./zigbeeHAgw and pid list 564 571 585 592 =================================================== ./zigbeeHAgw: line 1036: ./track_servers: not found NETWORK MANAGER exited with code 2 at Fri Aug 28 09:05:08 UTC 2015 sh: can't kill pid 603: No such process killall: GATEWAY_SRVR_arm: no process killed killall: OTA_SRVR_arm: no process killed killall: ZLSZNP_arm: no process killed killall: NPI_lnx_arm_server: no process killed resetting beaglebone black ../tools/bbb_u***reset.bin: line 1: syntax error: unexpected word (expecting ")") sleeping 6 seconds after reset... ../tools/gw_soc_fw_version_query.bin: line 1: syntax error: unexpected word (expecting ")") done stty: /dev/ttyACM0: Inappropriate ioctl for device stty: /dev/ttyACM0: Inappropriate ioctl for device Starting the ZigBee gateway subsystem ./NPI_lnx_arm_server: line 1: syntax error: unexpected word (expecting ")") NPI started (pid 676) at Fri Aug 28 09:05:27 UTC 2015 ./ZLSZNP_arm: line 1: syntax error: unexpected word (expecting ")") ZLSZNP started (pid 683) at Fri Aug 28 09:05:31 UTC 2015 ./NWKMGR_SRVR_arm: line 1: syntax error: unexpected word (expecting ")") NETWORK MANAGER started (pid 690) at Fri Aug 28 09:05:33 UTC 2015 ./GATEWAY_SRVR_arm: line 1: syntax error: unexpected word (expecting ")") GATEWAY SERVER started (pid 697) at Fri Aug 28 09:05:35 UTC 2015 ./OTA_SRVR_arm: line 1: syntax error: unexpected word (expecting ")") OTA SERVER started (pid 704) at Fri Aug 28 09:05:37 UTC 2015 starting tracker with our pid ./zigbeeHAgw and pid list 676 683 697 704 ./zigbeeHAgw: line 1149: ./track_servers: not found |
5个回答
找到解决方法了!
编译出来的程序在arm平台上运行时,将导致line 1: syntax error: word unexpected (expecting ")")错误, 这是由于 在编译目标hello的时候 使用了选项-c ,导致生成的hello 不是可执行文件, 可通过file hello 来查看其属性,如下所示: hello: ELF 32-bit LSB relocatable, ARM, version 1 (SYSV), not stripped 从file命令可以看出目标文件hello并非可执行文件,执行时当然会报错。 |
frzzing 发表于 2018-6-1 03:15 你好,请问是如何获得到z-stack linux gateway 的source code。十分感谢 |
.run文件安装完毕以后,生成的目录里面就有个Source,就是linux gateway的源代码,这个是全部开源的,只是针对Sitara平台的,其他平台可能要移植底层SPI/UART部分的实现 |
ggfvxv 发表于 2018-6-1 03:43 请问你的ARM9是如何控制zigbee呢?是ZNP模式吗 |
@nicolas zhao4,对的目前Linux gateway参考设计中,搭配的zigbee就是运行的ZNP程序 |
只有小组成员才能发言,加入小组>>
545 浏览 0 评论
1609 浏览 0 评论
2045 浏览 0 评论
为啥BQ7693003DBTR芯片在和BQ769X0盒子通讯时收不到信号?
1507 浏览 0 评论
DSP 28027F 开发板 XDS100v2调试探针诊断日志显示了 Error -150 (SC_ERR_FTDI_FAIL)如何解决
1331 浏览 0 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
1756浏览 29评论
2781浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
1723浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
1634浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
1645浏览 13评论
/9
GMT+8, 2025-12-1 17:50 , Processed in 0.869068 second(s), Total 82, Slave 65 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2008
