扫一扫,分享给好友
在ti官网上下载到的z-stack linux gateway 将文件里的Precompiled_ARM 里的的文件 copy到bbb里,在bbb里运行 ./zigbeeHAgw bbb 打印出来一下信息
请问这是什么原因导致的,该如何去解决这个问题????? --------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- root@beaglebone:~/Desktop/z-stack_linux_gateway_arm_binaries_38883# cd servers/ root@beaglebone:~/Desktop/z-stack_linux_gateway_arm_binaries_38883/servers# ls GATEWAY_SRVR_arm NWKMGR_SRVR_arm config.ini start_application NPI_Gateway.cfg OTA_SRVR_arm gateway_config.tlg track_servers NPI_lnx_arm_server ZLSZNP_arm sample_app_ota.cfg zigbeeHAgw root@beaglebone:~/Desktop/z-stack_linux_gateway_arm_binaries_38883/servers# ./zigbeeHAgw bbb running zigbeegw.scr on an ARM resetting beaglebone black ./zigbeeHAgw: line 989: ../tools/bbb_u***reset.bin: No such file or directory sleeping 6 seconds after reset... ./zigbeeHAgw: line 997: ../tools/gw_soc_fw_version_query.bi n: No such file or directory done stty: /dev/ttyACM0: No such file or directory stty: /dev/ttyACM0: No such file or directory Starting the ZigBee gateway subsystem ./zigbeeHAgw: line 332: ./NPI_lnx_arm_server: No such file or directory NPI started (pid 687) at Wed Jan 13 09:59:08 UTC 2016 ./zigbeeHAgw: line 359: ./ZLSZNP_arm: No such file or directory ZLSZNP started (pid 690) at Wed Jan 13 09:59:12 UTC 2016 ./zigbeeHAgw: line 417: ./NWKMGR_SRVR_arm: No such file or directory NETWORK MANAGER started (pid 693) at Wed Jan 13 09:59:13 UTC 2016 ./zigbeeHAgw: line 387: ./GATEWAY_SRVR_arm: No such file or directory GATEWAY SERVER started (pid 696) at Wed Jan 13 09:59:15 UTC 2016 ./zigbeeHAgw: line 446: ./OTA_SRVR_arm: No such file or directory OTA SERVER started (pid 699) at Wed Jan 13 09:59:17 UTC 2016 starting tracker with our pid ./zigbeeHAgw and pid list 687 690 696 699 =================================================== oops! Network manager has already exited (!) at Wed Jan 13 09:59:17 UTC 2016 ./zigbeeHAgw: line 482: 706 Killed ./track_servers $$ "$pids" killall: GATEWAY_SRVR_arm: no process killed killall: OTA_SRVR_arm: no process killed killall: ZLSZNP_arm: no process killed killall: NPI_lnx_arm_server: no process killed unexpected exit code (127) from netmgr! resetting beaglebone black ./zigbeeHAgw: line 989: ../tools/bbb_u***reset.bin: No such file or directory sleeping 6 seconds after reset... ./zigbeeHAgw: line 997: ../tools/gw_soc_fw_version_query.bi n: No such file or directory done stty: /dev/ttyACM0: Inappropriate ioctl for device stty: /dev/ttyACM0: Inappropriate ioctl for device Starting the ZigBee gateway subsystem ./zigbeeHAgw: line 332: ./NPI_lnx_arm_server: No such file or directory NPI started (pid 772) at Wed Jan 13 09:59:41 UTC 2016 ./zigbeeHAgw: line 359: ./ZLSZNP_arm: No such file or directory ZLSZNP started (pid 775) at Wed Jan 13 09:59:45 UTC 2016 ./zigbeeHAgw: line 417: ./NWKMGR_SRVR_arm: No such file or directory NETWORK MANAGER started (pid 778) at Wed Jan 13 09:59:46 UTC 2016 ./zigbeeHAgw: line 387: ./GATEWAY_SRVR_arm: No such file or directory GATEWAY SERVER started (pid 781) at Wed Jan 13 09:59:48 UTC 2016 ./zigbeeHAgw: line 446: ./OTA_SRVR_arm: No such file or directory OTA SERVER started (pid 784) at Wed Jan 13 09:59:50 UTC 2016 starting tracker with our pid ./zigbeeHAgw and pid list 772 775 781 784 =================================================== oops! Network manager has already exited (!) at Wed Jan 13 09:59:51 UTC 2016 ./zigbeeHAgw: line 482: 791 Killed ./track_servers $$ "$pids" killall: GATEWAY_SRVR_arm: no process killed killall: OTA_SRVR_arm: no process killed killall: ZLSZNP_arm: no process killed killall: NPI_lnx_arm_server: no process killed ^Ccaught SIGTERM, killing all the servers and cleaning up --------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- |
5个回答
jvwueurw 发表于 2018-5-15 04:23 嗯 是的,我在官网上下载的z-stack_linux_gateway-1.0.1 搭建Beaglebone black运行环境,将z-stack_linux_gateway中Precompiled_arm中的可执行文件scp 到 Beaglebone black Precompiled_arm中的可执行文件有main.bin,和NPI_lnx_arm_server ,GATEWAY_SRVR_arm ,NWKMGR_SRVR_arm, ZLSZNP_arm ,OTA_SRVR_arm几个可执行文件。通过执行一个脚本文件 启动这几个sever,然后在执行应用程序main.bin 再执行脚本启动server的时候 打印出 ./zigbeeHAgw: line 332: ./NPI_lnx_arm_server: No such file or directory 原因已经明确。对于这个问题,首先联想到的事gcc的版本,arm开发板的gcc一般是arm-linux-gcc,但是这个系列的gcc还是有很多版本的,看了下板子上的gcc和电脑上交叉编译的版本同时gcc-4.7.3. 再想了一下,它用的是beaglebone black板子,多了个hf是因为该芯片支持硬件浮点数运算。 对于gcc也是有对hf进行优化的,也就是带hf的gcc编译器:arm-linux-gnueabihf-gcc 在beaglebong运行的文件系统上的gcc是arm-angstrom-linux-gnueabi,而交叉编译环境下的gcc却是:arm-linux-gnueabihf-gcc,所以放到板子上运行时直接是不能解释该文件。 通过在beaglebong的环境下使用arm-angstrom-linux-gnueabi编译了一个可执行程序,并且运行成功。 通过file命令查看文件信息 root@beaglebone:~/Desktop/z-stack_linux_gateway_arm_binaries_38883/app# file main.bin main.bin: ELF 32-bit LSB executable, ARM, version 1 (SYSV), dynamically linked (uses shared li bs), for GNU/Linux 2.6.16, not stripped 然而提供的可执行程序通过file命令查看文件信息为: root@beaglebone:~/Desktop/z-stack_linux_gateway_arm_binaries_38883/app# file main.bin main.bin: ELF 32-bit LSB executable, ARM, EABI5 version 1 (SYSV), dynamically linked (uses shared libs), for GNU/Linux 2.6.31, BuildID[sha1]=9b748c88b78cfe7032ffb1e2f37e59b1ca2396a3, not stripped 由于application的源码提供了,我们可以自己修改编译器,重新编译即可,不过几个server的源码暂时还没有,不过也可以通过相同的方法来解决这一问题。 最后我更新了Beagle bone Black 的系统为最新版本,解决了可执行程序不能运行的问题 |
jvwueurw 发表于 2018-5-15 04:23 另外,解决了程序不能运行的问题后,又遇到了一个新的问题,希望你们帮助我看一下,ps我是按照z-stack_linux_gateway官方提供的文档一步一步做的啊? z-stack_linux_gateway 在BB Black上运行./zigbeeHWgw bbb 出现错误 完全按照TI发布的z-stack_linux_gateway 的文档上操作。但在运行时还是出现了 一下错误,请问这个问题是可执行程序和BB Black上的系统不兼容么?还有有其他原因...... root@beaglebone:~/z-stack_linux_gateway_arm_binaries_38883# ls app misc protobuf servers tools root@beaglebone:~/z-stack_linux_gateway_arm_binaries_38883# cd servers/ root@beaglebone:~/z-stack_linux_gateway_arm_binaries_38883/servers# ls config.ini NPI_Gateway.cfg OTA_SRVR_arm track_servers gateway_config.tlg NPI_lnx_arm_server sample_app_ota.cfg zigbeeHAgw GATEWAY_SRVR_arm NWKMGR_SRVR_arm start_application ZLSZNP_arm root@beaglebone:~/z-stack_linux_gateway_arm_binaries_38883/servers# ./zigbeeHAgw bbb running zigbeegw.scr on an ARM resetting beaglebone black sleeping 6 seconds after reset... Using serial port: /dev/ttyACM0 zbSocProcessRpc: CMD0:41, CMD1:80, not handled Received System version. Transport Protocol Version: 2 Product ID: 0 Software Release: 2.6.1 Software Revision: 38724 done Starting the ZigBee gateway subsystem deviceKey = 0 (0 ) devPath = '/dev/ttyACM0' logPath = './NpiLnxLog.txt' ... freeing memory (ret 0) Port: 2533 Following IP addresses are available: ./zigbeeHAgw: line 324: 676 Segmentation fault $NPI_CMD NPI started (pid 676) at Thu Nov 12 21:30:07 UTC 2015 connect: Connection refused [ZSTACKZNP_SRVR/MAIN] ERROR: ERROR: signal 11 was trigerred: [ZSTACKZNP_SRVR/MAIN] ERROR: Fault address: (nil) [ZSTACKZNP_SRVR/MAIN] ERROR: Fault reason: address not mapped to object [ZSTACKZNP_SRVR/MAIN] ERROR: Stack trace unavailable [ZSTACKZNP_SRVR/MAIN] ERROR: Executing original handler... ./zigbeeHAgw: line 351: 681 Segmentation fault $ZLSZNP_CMD ZLSZNP started (pid 681) at Thu Nov 12 21:30:12 UTC 2015 [NWK_MGR/MAIN] : there are 2 args [NWK_MGR/MAIN] : argv[0] = ./NWKMGR_SRVR_arm [NWK_MGR/MAIN] : argv[1] = 127.0.0.1:2536 connect: Connection refused [NWK_MGR/MAIN] ERROR: ERROR: signal 11 was trigerred: [NWK_MGR/MAIN] ERROR: Fault address: (nil) [NWK_MGR/MAIN] ERROR: Fault reason: address not mapped to object [NWK_MGR/MAIN] ERROR: Stack trace unavailable [NWK_MGR/MAIN] ERROR: Executing original handler... ./zigbeeHAgw: line 407: 684 Segmentation fault $NWKMGR_CMD $NWKMGR_RESTART_FLAG NETWORK MANAGER started (pid 684) at Thu Nov 12 21:30:13 UTC 2015 connect: Connection refused |
jvwueurw 发表于 2018-5-15 04:23 在http://www.ti.com.cn/tool/cn/z-stack?keyMatch=z-stack-linux-gateway&tisearch=Search-CN-Everything 下载的z-stack-linux-gateway |
hu_wfllllllllfl 发表于 2018-5-15 04:53 建议您到http://www.deyisupport.com/question_answer/wireless_connectivity/zigbee/f/104.aspx 去提问,因为stack方面的问题,我们这边也没有做过。 如果我的回答解决了您的问题,请确认答案,谢谢!:) |
只有小组成员才能发言,加入小组>>
549 浏览 0 评论
1613 浏览 0 评论
2047 浏览 0 评论
为啥BQ7693003DBTR芯片在和BQ769X0盒子通讯时收不到信号?
1513 浏览 0 评论
DSP 28027F 开发板 XDS100v2调试探针诊断日志显示了 Error -150 (SC_ERR_FTDI_FAIL)如何解决
1337 浏览 0 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
1756浏览 29评论
2781浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
1724浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
1634浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
1645浏览 13评论
/9
GMT+8, 2025-12-2 01:06 , Processed in 0.714519 second(s), Total 79, Slave 62 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3888
