扫一扫,分享给好友
您好: DM368接收720p60的YCbCr图像信号,ISIF->SDRAM->OSD输出,电视上可以正确显示源图像。 但是 ISIF->IPIPE->SDRAM->OSD,图像颜色错误。 请问这是什么原因??? 源图像: 经裁剪后(422to420),实际图像 以下是RSZ部分的寄存器: rsz SRC_EN reg val is : 0x00000001 rsz SRC_MODE reg val is : 0x00000000 rsz SRC_FMT0 reg val is : 0x00000001 rsz SRC_FMT1 reg val is : 0x00000000 rsz SRC_VPS reg val is : 0x00000000 rsz SRC_VSZ reg val is : 0x000002df rsz SRC_HPS reg val is : 0x00000000 rsz SRC_HSZ reg val is : 0x000004ff rsz DMA_RZA reg val is : 0x00000080 rsz DMA_RZB reg val is : 0x00000040 rsz DMA_STA reg val is : 0x00000000 rsz GCK_MMR reg val is : 0x00000001 rsz GCK_SDR reg val is : 0x00000001 rsz IRQ_RZA reg val is : 0x00001fff rsz IRQ_RZB reg val is : 0x00001fff rsz YUV_Y_MIN reg val is : 0x00000000 rsz YUV_Y_MAX reg val is : 0x000000ff rsz YUV_C_MIN reg val is : 0x00000000 rsz YUV_C_MAX reg val is : 0x000000ff rsz YUV_PHS reg val is : 0x00000001 rsz SEQ reg val is : 0x00000000 rsz RZA_EN reg val is : 0x00000001 rsz RZA_MODE reg val is : 0x00000000 rsz RZA_420 reg val is : 0x00000003 rsz RZA_I_VPS reg val is : 0x00000000 rsz RZA_I_HPS reg val is : 0x00000000 rsz RZA_O_VSZ reg val is : 0x000002df rsz RZA_O_HSZ reg val is : 0x000004ff rsz RZA_V_PHS_Y reg val is : 0x00000000 rsz RZA_V_PHS_C reg val is : 0x00000000 rsz RZA_V_DIF reg val is : 0x00000100 rsz RZA_V_TYP reg val is : 0x00000000 rsz RZA_V_LPF reg val is : 0x00000000 rsz RZA_H_PHS reg val is : 0x00000000 rsz RZA_H_PHS_ADJ reg val is : 0x00000000 rsz RZA_H_DIF reg val is : 0x00000100 rsz RZA_H_TYP reg val is : 0x00000000 rsz RZA_H_LPF reg val is : 0x00000000 rsz RZA_DWN_EN reg val is : 0x00000000 rsz RZA_DWN_AV reg val is : 0x00000000 rsz RZA_RGB_EN reg val is : 0x00000000 rsz RZA_RGB_TYP reg val is : 0x00000000 rsz RZA_RGB_BLD reg val is : 0x00000000 rsz RZA_SDR_Y_BAD_H reg val is : 0x000083c1 rsz RZA_SDR_Y_BAD_L reg val is : 0x00006080 rsz RZA_SDR_Y_SAD_H reg val is : 0x00008396 rsz RZA_SDR_Y_SAD_L reg val is : 0x00000080 rsz RZA_SDR_Y_OFT reg val is : 0x00000500 rsz RZA_SDR_Y_PTR_S reg val is : 0x00000000 rsz RZA_SDR_Y_PTR_E reg val is : 0x000002e0 rsz RZA_SDR_C_BAD_H reg val is : 0x000083d0 rsz RZA_SDR_C_BAD_L reg val is : 0x0000c080 rsz RZA_SDR_C_SAD_H reg val is : 0x000083a4 rsz RZA_SDR_C_SAD_L reg val is : 0x00006080 rsz RZA_SDR_C_OFT reg val is : 0x00000500 rsz RZA_SDR_C_PTR_S reg val is : 0x00000000 rsz RZA_SDR_C_PTR_E reg val is : 0x00000170 rsz RZB_EN reg val is : 0x00000001 rsz RZB_MOD reg val is : 0x00000000 rsz RZB_420 reg val is : 0x00000003 rsz RZB_I_VPS reg val is : 0x00000000 rsz RZB_I_HPS reg val is : 0x00000000 rsz RZB_O_VSZ reg val is : 0x000000bf rsz RZB_O_HSZ reg val is : 0x0000013f rsz RZB_V_PHS_Y reg val is : 0x00000000 rsz RZB_V_PHS_C reg val is : 0x00000000 rsz RZB_V_DIF reg val is : 0x000003d5 rsz RZB_V_TYP reg val is : 0x00000000 rsz RZB_V_LPF reg val is : 0x00000000 rsz RZB_H_PHS reg val is : 0x00000000 rsz RZB_H_PHS_ADJ reg val is : 0x00000000 rsz RZB_H_DIF reg val is : 0x00000400 rsz RZB_H_TYP reg val is : 0x00000000 rsz RZB_H_LPF reg val is : 0x00000000 rsz RZB_DWN_EN reg val is : 0x00000000 rsz RZB_DWN_AV reg val is : 0x00000000 rsz RZB_RGB_EN reg val is : 0x00000000 rsz RZB_RGB_TYP reg val is : 0x00000000 rsz RZB_RGB_BLD reg val is : 0x00000000 rsz RZB_SDR_Y_BAD_H reg val is : 0x000083da rsz RZB_SDR_Y_BAD_L reg val is : 0x00002080 rsz RZB_SDR_Y_SAD_H reg val is : 0x000083d7 rsz RZB_SDR_Y_SAD_L reg val is : 0x00004080 rsz RZB_SDR_Y_OFT reg val is : 0x00000140 rsz RZB_SDR_Y_PTR_S reg val is : 0x00000000 rsz RZB_SDR_Y_PTR_E reg val is : 0x000000c0 rsz RZB_SDR_C_BAD_H reg val is : 0x000083db rsz RZB_SDR_C_BAD_L reg val is : 0x00001080 rsz RRZB_SDR_C_SAD_H reg val is : 0x000083d8 rsz RZB_SDR_C_SAD_L reg val is : 0x00003080 rsz RZB_SDR_C_OFT reg val is : 0x00000140 rsz RZB_SDR_C_PTR_S reg val is : 0x00000000 rsz RZB_SDR_C_PTR_E reg val is : 0x00000060 |
2个回答
60user102 发表于 2018-5-31 04:59 谢谢,问题已解决。 CbCr顺序是对了。ipipeif的寄存器设置错误了,改正后,图像正确 |
只有小组成员才能发言,加入小组>>
594 浏览 0 评论
1647 浏览 0 评论
2089 浏览 0 评论
为啥BQ7693003DBTR芯片在和BQ769X0盒子通讯时收不到信号?
1538 浏览 0 评论
DSP 28027F 开发板 XDS100v2调试探针诊断日志显示了 Error -150 (SC_ERR_FTDI_FAIL)如何解决
1381 浏览 0 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
1789浏览 29评论
2818浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
1747浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
1664浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
1677浏览 13评论
/9
GMT+8, 2025-12-12 14:13 , Processed in 2.339433 second(s), Total 77, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2161
