扫一扫,分享给好友
[linux-devkit]:~/c> make
/root/CodeSourcery/Sourcery_G++_Lite//bin/ARM-none-linux-gnueabi-gcc -I/usr/local/dvsdk/xdctools_3_16_03_36/packages -I/usr/local/dvsdk/dmai_2_20_00_14/packages -I/usr/local/dvsdk/codec-engine_2_26_01_09/packages -I/usr/local/dvsdk/framework-components_2_25_03_07/packages -I/usr/local/dvsdk/xdais_6_26_00_02/packages -I/usr/local/dvsdk/codecs-dm365_4_00_00_00/packages -DDmai_Device_dm368 -I/usr/local/dvsdk/psp/linux-2.6.32.17-psp03.01.01.38/in -g -Wall -Werror -o hello a.c In file included from /usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/Engine.h:57, from /usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/CERuntime.h:57, from a.c:11: /usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/Server.h:101: error: expected specifier-qualifier-list before 'Int' /usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/Server.h:114: error: expected specifier-qualifier-list before 'Char' /usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/Server.h:145: error: expected declaration specifiers or '...' before 'Int' /usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/Server.h:167: error: expected declaration specifiers or '...' before 'Int' /usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/Server.h:196: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'Server_fwriteTrace' /usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/Server.h:224: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'Server_getAlgInfo' /usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/Server.h:251: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'Server_getCpuLoad' /usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/Server.h:275: error: expected declaration specifiers or '...' before 'Int' /usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/Server.h:296: error: expected declaration specifiers or '...' before 'Int' /usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/Server.h:318: error: expected declaration specifiers or '...' before 'Int' /usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/Server.h:324: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'Server_init' /usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/Server.h:380: error: expected declaration specifiers or '...' before 'String' /usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/Server.h:381: error: expected declaration specifiers or '...' before 'Uint32' /usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/Server.h:381: error: expected declaration specifiers or '...' before 'Uint32' /usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/Server.h:417: error: expected declaration specifiers or '...' before 'String' /usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/Server.h:443: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'Server_setTrace' In file included from /usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/Engine.h:58, from /usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/CERuntime.h:57, from a.c:11: /usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/ipc/Comm.h:50: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'Comm_MSGSIZE' /usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/ipc/Comm.h:55: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'Comm_Queue' /usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/ipc/Comm.h:73: error: expected declaration specifiers or '...' before '*' token /usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/ipc/Comm.h:73: error: expected ')' before 'callHandle' /usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/ipc/Comm.h:80: error: expected specifier-qualifier-list before 'Ptr' /usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/ipc/Comm.h:93: error: expected specifier-qualifier-list before 'UInt32' /usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/ipc/Comm.h:124: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'Comm_locate' /usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/ipc/Comm.h:130: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'Comm_alloc' /usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/ipc/Comm.h:136: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'Comm_free' /usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/ipc/Comm.h:142: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'Comm_put' /usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/ipc/Comm.h:148: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'Comm_get' /usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/ipc/Comm.h:154: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'Comm_getMsgSize' /usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/ipc/Comm.h:160: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'Comm_getSrcQueue' /usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/ipc/Comm.h:166: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'Comm_setSrcQueue' /usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/ipc/Comm.h:172: error: expected ')' before 'queueName' /usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/ipc/Comm.h:179: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'Comm_delete' /usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/ipc/Comm.h:184: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'Comm_init' /usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/ipc/Comm.h:189: error: expected '=', ',', ';', 'asm' or '__attribute__' |
3个回答
/root/CodeSourcery/Sourcery_G++_Lite//bin/arm-none-linux-gnueabi-gcc -I/usr/local/dvsdk/xdctools_3_16_03_36/packages -I/usr/local/dvsdk/dmai_2_20_00_14/packages -I/usr/local/dvsdk/codec-engine_2_26_01_09/packages -I/usr/local/dvsdk/framework-components_2_25_03_07/packages -I/usr/local/dvsdk/xdais_6_26_00_02/packages -I/usr/local/dvsdk/codecs-dm365_4_00_00_00/packages -DDmai_Device_dm368 -I/usr/local/dvsdk/psp/linux-2.6.32.17-psp03.01.01.38/include -I/usr/local/dvsdk/psp/linux-2.6.32.17-psp03.01.01.38/arch/arm/include -I/usr/local/dvsdk/psp/linux-2.6.32.17-psp03.01.01.38/arch/arm/mach-davinci/include -include /usr/local/dvsdk/psp/linux-2.6.32.17-psp03.01.01.38/include/linux/autoconf.h -I/usr/local/dvsdk/linuxutils_2_25_05_11/packages -I -DDmai_BuildOs_linux -Dxdc_target_types__=gnu/targets/std.h -I/usr/local/dvsdk/linux-devkit/arm-none-linux-gnueabi/usr/include -Dxdc_target_name__=arm/GCArmv5T -g -Wall -Werror -o hello a.c
In file included from /usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/Engine.h:57, from /usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/CERuntime.h:57, from a.c:11: /usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/Server.h:101: error |
jessica_ma 发表于 2018-5-31 00:24 sr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/Server.h:101: error: expected specifier-qualifier-list before 'Int' /usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/Server.h:114: error: expected specifier-qualifier-list before 'Char' |
jessica_ma 发表于 2018-5-31 00:34 修改路径 OK |
只有小组成员才能发言,加入小组>>
549 浏览 0 评论
1613 浏览 0 评论
2047 浏览 0 评论
为啥BQ7693003DBTR芯片在和BQ769X0盒子通讯时收不到信号?
1513 浏览 0 评论
DSP 28027F 开发板 XDS100v2调试探针诊断日志显示了 Error -150 (SC_ERR_FTDI_FAIL)如何解决
1337 浏览 0 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
1757浏览 29评论
2781浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
1724浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
1634浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
1645浏览 13评论
/9
GMT+8, 2025-12-2 10:21 , Processed in 0.867749 second(s), Total 78, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2194
