电子发烧友论坛扫一扫,分享给好友
| _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_| | _| .'| . | . | | __| _| . | | | -_| _| _||__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_||___| |___|Arago Project http://arago-project.org DM8127_IPNC ttyO0Arago 2011.09 DM8127_IPNC ttyO0DM8127_IPNC login: root (automatic login)[m3vpss ] CT: 1000, 3dlut index:0[host]Application Run Completed[m3vpss ] 6332: CAMERA: Fields = 2 (fps = 0), Total Resets = 0 (Avg 0 ms per reset)root@DM8127_IPNC:~#[host] ITT server task running !!![host]ITT ittServer_run[host] ITT Server Message initialization successful[host]ITT capture task created[host] DCC server Message ques is open succefully[host] Setting cmd <1> in message <40bb5100>[host] Posting message <40bb5100> in QId <20002>[m3vpss ] Command 1 recived from HOST A8[host] Response from M3 is : 1[m3vpss ] Command 2 recived from HOST A8[m3vpss ] New DCC data of size <33603>[m3video] Channel:1 inputframerate:30 targetfps:60[m3vpss ] Call to VNF_LINK_CMD_UPDATE_DCC 536870980[host] Response from M3 is : 1[host] Default parameters were sent sucessfully[host] Server Socket created with ID <22>[m3video] Channel:0 inputframerate:60 targetfps:60[m3video] Channel:2 inputframerate:60 targetfps:5mkdosfs 3.0.12 (29 Oct 2011)unable to get drive geometry, using default 255/63/dev/***ulla has 255 heads and 63 sectors per track,logical sector size is 512,using 0xf8 media descriptor, with 1024 sectors;file system has 2 12-bit FATs and 4 sectors per cluster.FAT size is 1 sector, and provides 247 clusters.There is 1 reserved sector.Root directory contains 512 slots and uses 32 sectors.Volume ID is d2e3abdd, no volume label.g_file_storage gadget: No serial-number string provided!g_file_storage gadget: File-backed Storage Gadget, version: 1 September 2010g_file_storage gadget: Number of LUNs=1g_file_storage gadget-lun0: ro=0, nofua=0, file: /dev/***ullaSimple mixer control 'PGA',0Capabilities: cvolume cswitch penumCapture channels: Front Left - Front RightLimits: Capture 0 - 119Front Left: Capture 80 [67%] [40.00dB] [on]Front Right: Capture 80 [67%] [40.00dB] [on][m3vpss ] 8444: DISPLAY: Stop in progress !!!Venc not supported!![m3vpss ] 8510: DISPLAY: Stop Done !!![m3vpss ] 8513: DISPLAY: Start in progress !!!queue id:0[m3vpss ] 8563: DISPLAY: Start Done !!![m3vpss ] 8563: DISPLAY: SDDAC(SEC1): 1340 fps, Latency (Min / Max) = ( 4 / 107 ), Callback Interval (Min / Max) = ( 33 / 34 ) !!![host] VNF MESSAGE RECIEVED: (Enable:0) (Mode:5) (Strength:0) (EnableTNF:0) (EnableSNF:0)[host]Channel Selected: 0[host]Channel Selected: 0,rate control = 0 [m3vpss ] 8496: VNF:[m3vpss ] EnableSNF current SNF 1 => new 0!!![m3vpss ] NSF: EnableSNF 0 current mode 0!!![host]========== Stream FrameRate1 = 30 =================[host]Channel Selected: 0[host]Channel Selected: 0[host]Channel Selected: 0[host]Channel Selected: 0,packet size = 100[host]Channel Selected: 0,encPreset = 0[host]Channel Selected: 0,enable = 0[host]Channel Selected: 1[host]Channel Selected: 1,rate control = 0 [m3vpss ] 8497: VNF:[m3vpss ] EnableTNF current TNF 1 => new 0!!![m3vpss ] NSF: EnableTNF 0 current mode 1!!![m3vpss ] CT: 6032, 3dlut index:3[m3vpss ] framerateParams->FrameRate = 30[host]Channel Selected: 1[host]Channel Selected: 1[host]Channel Selected: 1[host]Channel Selected: 1,packet size = 100[host]Channel Selected: 1,encPreset = 0[host]Channel Selected: 1,enable = 0[host]Channel Selected: 2[host]Channel Selected: 2,rate control = 2[host] MJPEG in Rate Control OFF ModeCheck_device_version : DEVICE VER = 1 !![m3video] Channel:0 inputframerate:30 targetfps:30[m3video] Channel:2 inputframerate:30 targetfps:5[m3video] ENCLINK: new targetbitrate to set:10000000[m3video] ENCLINK: new targetframerate to set:30000[m3video] ENCLINK: new intraFrameInterval to set:30,new maxPicSizeRatioI to set = 960[m3video] ENCLINK: new QP I Param to set:10 36 -1[m3video] ENCLINK: new QP P Param to set:10 40 28Simple mixer control 'PGA',0Capabilities: cvolume cswitch penumCapture channels: Front Left - Front RightLimits: Capture 0 - 119Front Left: Capture 95 [80%] [47.50dB] [on]Front Right: Capture 95 [80%] [47.50dB] [on]Check_device_version : DEVICE VER = 1 !![m3video] ENCLINK: new PacketSize Param to set:100[m3video] ENCLINK: new Encode Preset Param to set:0[m3video] ENCLINK: new rate control algorithm to set:0[m3video] Channel:1 inputframerate:30 targetfps:30[m3video] JPGLINK: new targetframerate to set:5000 for bitrate 100000[m3video] JPGLINK: new QP Param to set:1 51 80[m3video] JPGLINK: new qualityFactor Param to set:80Simple mixer control 'PCM',0Capabilities: pvolume penumPlayback channels: Front Left - Front RightLimits: Playback 0 - 127Mono:Front Left: Playback 101 [80%] [-13.00dB]Front Right: Playback 101 [80%] [-13.00dB][m3video] JPGLINK: new rate control algorithm to set:2 for bitrate: 100000[host]Force IDR on Channel: 0[host]Force IDR on Channel: 1 [m3video] JPGLINK: Run time parameters changed 0[m3video] ENCLINK: new targetbitrate to set:2000000[m3video] ENCLINK: new targetframerate to set:30000[m3video] ENCLINK: new intraFrameInterval to set:30,new maxPicSizeRatioI to set = 960[m3video] ENCLINK: new QP I Param to set:10 36 -1[m3video] ENCLINK: new QP P Param to set:10 40 28SystemInit successSchedule manager init success[m3video] ENCLINK: new PacketSize Param to set:100Dmva Schedule manager init success[m3video] ENCLINK: new Encode Preset Param to set:0[m3video] ENCLINK: new rate control algorithm to set:0[m3video] Channel:2 inputframerate:30 targetfps:5umount: can't umount /mnt/mmc: Invalid argumentkillall: dhcpcd: no process killedrm: cannot remove '/var/run/dhcpcd-eth0.pid': No such file or directoryTimeOut occure in boot_proc.Program exit.TFTP烧录镜像可以正常启动,但是NFS挂载始终都无法正常启动,论坛上看了很多类似帖子,也没解决,还望TI工程师大神们给解决一下,谢啦!
8个回答
请问用的是pre_build的镜像还是什么? 请一定确认你的镜像是从NFS的同一个文件系统生成的。
您好,pre_build是target目录下filesys_ipnc_dm81xx.tar.gz解压完,开放最高权限而未经编译的文件系统么?我在配置NFS时设置的是/IPNC_RDK_V3.8.0/Source/ipnc_rdk/target/filesys/ *(rw,no_root_squash,no_all_squash,sync),文件系统我用make -s ubifs也编译过,TFTP烧录ubifs_ipnc.bin也能正常启动,改成NFS就不行 |
hu_wflllllllg11 发表于 2018-5-28 07:47 你好, 你这里是通过nfs来挂载文件系统,启动网络忘记系统,是这样吗? 还是你系统启动后,挂载数据,执行程序失败 ? |
我是通过NFS来挂载文件系统,启动文件系统。看串口输出,应该是系统挂载成功了,但不知道为什么最后会显示time out in boot_proc,然后就进行不下去了。看了很多帖子,但也没一个准确解答这个问题的 |
hu_wflllllllg11 发表于 2018-5-28 08:20 应当已经挂载成功了,你可以关闭程序的自启动,应当就正常了 |
您好,怎么关闭程序自启动呢?还望指点一下,多谢! |
在文件系统里面的 /etc/init.d/finish_*.sh 你把对应的执行文件屏蔽掉,或者删除,就可以; 再重新启动,挂载试一下 |
好的,谢谢您如此详细的解释,祝您工作愉快 |
只有小组成员才能发言,加入小组>>
594 浏览 0 评论
1647 浏览 0 评论
2089 浏览 0 评论
为啥BQ7693003DBTR芯片在和BQ769X0盒子通讯时收不到信号?
1538 浏览 0 评论
DSP 28027F 开发板 XDS100v2调试探针诊断日志显示了 Error -150 (SC_ERR_FTDI_FAIL)如何解决
1381 浏览 0 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
1791浏览 29评论
2820浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
1748浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
1666浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
1678浏览 13评论
/9
GMT+8, 2025-12-12 23:25 , Processed in 1.172491 second(s), Total 86, Slave 69 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2199
