扫一扫,分享给好友
请问arago-base-tisdk-image-am335x-evm.ubi启动后正常现象应该是怎样的?
我启动后控制台不能用,LCD能显示TI的加载进度条,但是串口控制各开始打印乱码,然后LCD出现控制台,只能用USB键盘操作控制台。 请问这是正常的现象吗?有没有关于arago-base-tisdk-image-am335x-evm.ubi 文件系统的介绍?正常的启动现象应该 是怎样的,谢谢。 Starting kernel ... [ 0.000000] Booting Linux on physical CPU 0x0 [ 0.000000] Linux version 3.14.43-g875c69b (root@richard-H81M-DS2) (gcc version 4.9.3 20150413 (prerelease) (Linaro GCC 4.9-2015.05) ) #2 Mon Dec 14 14:07:55 CST 2015 [ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c5387d [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache [ 0.000000] Machine model: TI AM335x BeagleBone [ 0.000000] cma: CMA: reserved 24 MiB at 9d800000 [ 0.000000] Memory policy: Data cache writeback [ 0.000000] CPU: All CPU(s) started in SVC mode. [ 0.000000] AM335X ES2.1 (sgx neon ) [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 129792 [ 0.000000] Kernel command line: console=ttyO0,115200n8 root=ubi0:rootfs rootfstype=ubifs ubi.mtd=10,2048 rw rootwait=1 init=/init ip=off lcd=X800Y4 80 uart1_d_can=uart1 uart2_i2c2=uart2 [ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes) [ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes) [ 0.000000] Memory: 485072K/523264K available (5955K kernel code, 302K rwdata, 2144K rodata, 261K init, 232K bss, 38192K reserved, 0K highmem) [ 0.000000] Virtual kernel memory layout: [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB) [ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) [ 0.000000] vmalloc : 0xe0800000 - 0xff000000 ( 488 MB) [ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB) [ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) [ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB) [ 0.000000] .text : 0xc0008000 - 0xc07f10e4 (8101 kB) [ 0.000000] .init : 0xc07f2000 - 0xc0833424 ( 262 kB) [ 0.000000] .data : 0xc0834000 - 0xc087fba0 ( 303 kB) [ 0.000000] .bss : 0xc087fba0 - 0xc08b9ba8 ( 233 kB) [ 0.000000] NR_IRQS:16 nr_irqs:16 16 [ 0.000000] IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts [ 0.000000] Total of 128 interrupts on 1 active controller [ 0.000000] OMAP clockevent source: timer2 at 24000000 Hz [ 0.000013] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956969942ns [ 0.000033] OMAP clocksource: timer1 at 24000000 Hz [ 0.000283] Console: colour dummy device 80x30 [ 0.000308] WARNING: Your 'console=ttyO0' has been replaced by 'ttyS0' [ 0.000313] This ensures that you still see kernel messages. Please [ 0.000318] update your kernel commandline. [ 0.000336] Calibrating delay loop... 996.14 BogoMIPS (lpj=4980736) [ 0.089543] pid_max: default: 32768 minimum: 301 [ 0.089638] Security Framework initialized [ 0.089694] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes) [ 0.089703] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes) [ 0.096397] CPU: Testing write buffer coherency: ok [ 0.096813] Setting up static identity map for 0x805d63a8 - 0x805d6400 [ 0.097722] devtmpfs: initialized [ 0.099603] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3 [ 0.105356] omap_hwmod: tptc0 using broken dt data from edma [ 0.105421] omap_hwmod: tptc1 using broken dt data from edma [ 0.105479] omap_hwmod: tptc2 using broken dt data from edma [ 0.109422] omap_hwmod: debugss: _wait_target_disable failed [ 0.163715] pinctrl core: initialized pinctrl subsystem [ 0.164659] regulator-dummy: no parameters [ 0.166995] NET: Registered protocol family 16 [ 0.168878] DMA: preallocated 256 KiB pool for atomic coherent allocations [ 0.171231] cpuidle: using governor ladder [ 0.171246] cpuidle: using governor menu [ 0.176525] syscon 44e10000.control_module: regmap [mem 0x44e10000-0x44e107fb] registered [ 0.177817] platform 49000000.edma: alias fck already exists [ 0.177838] platform 49000000.edma: alias fck already exists [ 0.177849] platform 49000000.edma: alias fck already exists [ 0.178842] OMAP GPIO hardware version 0.1 [ 0.187843] omap-gpmc 50000000.gpmc: could not find pctldev for node /pinmux@44e10800/nandflash_pins_default, deferring probe [ 0.187878] platform 50000000.gpmc: Driver omap-gpmc requests probe deferral [ 0.191272] No ATAGs? [ 0.191296] hw-breakpoint: debug architecture 0x4 unsupported. [ 0.213064] bio: create slab [ 0.226581] edma-dma-engine edma-dma-engine.0: TI EDMA DMA engine driver [ 0.227513] vmmcsd_fixed: 3300 mV [ 0.230150] vgaarb: loaded [ 0.230623] i2c-core: driver [palmas] using legacy suspend method [ 0.230633] i2c-core: driver [palmas] using legacy resume method [ 0.231298] SCSI subsystem initialized [ 0.232611] u***core: registered new interface driver u***fs [ 0.232783] u***core: registered new interface driver hub [ 0.232952] u***core: registered new device driver u*** [ 0.233802] omap_i2c 44e0b000.i2c: could not find pctldev for node /pinmux@44e10800/pinmux_i2c0_pins, deferring probe [ 0.233832] platform 44e0b000.i2c: Driver omap_i2c requests probe deferral [ 0.234169] pps_core: LinuxPPS API ver. 1 registered [ 0.234180] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti [ 0.234295] PTP clock support registered [ 0.236000] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400 [ 0.236816] Advanced Linux Sound Architecture Driver Initialized. [ 0.238345] Switched to clocksource timer1 [ 0.255017] NET: Registered protocol family 2 [ 0.255774] TCP established hash table entries: 4096 (order: 2, 16384 bytes) [ 0.255823] TCP bind hash table entries: 4096 (order: 2, 16384 bytes) [ 0.255861] TCP: Hash tables configured (established 4096 bind 4096) [ 0.255929] TCP: reno registered [ 0.255941] UDP hash table entries: 256 (order: 0, 4096 bytes) [ 0.255965] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes) [ 0.256112] NET: Registered protocol family 1 [ 0.256495] RPC: Registered named UNIX socket transport module. [ 0.256508] RPC: Registered udp transport module. [ 0.256514] RPC: Registered tcp transport module. [ 0.256520] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.257611] hw perfevents: enabled with ARMv7 Cortex-A8 PMU driver, 5 counters available [ 0.260188] futex hash table entries: 256 (order: -1, 3072 bytes) [ 0.399331] VFS: Disk quotas dquot_6.5.2 [ 0.399401] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) [ 0.399900] NFS: Registering the id_resolver key type [ 0.399978] Key type id_resolver registered [ 0.399985] Key type id_legacy registered [ 0.400020] jffs2: version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc. [ 0.400176] msgmni has been set to 995 [ 0.401417] NET: Registered protocol family 38 [ 0.401461] io scheduler noop registered [ 0.401468] io scheduler deadline registered [ 0.401488] io scheduler cfq registered (default) [ 0.403067] pinctrl-single 44e10800.pinmux: 142 pins at pa f9e10800 size 568 [ 0.406639] backlight supply power not found, using dummy regulator [ 0.410081] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled [ 0.414861] 44e09000.serial: ttyS0 at MMIO 0x44e09000 (irq = 88, base_baud = 3000000) is a 8250 [ 1.066139] console [ttyS0] enabled [ 1.071357] omap_rng 48310000.rng: OMAP Random Number Generator ver. 20 [ 1.078418] [drm] Initialized drm 1.1.0 20060810 [ 1.092510] brd: module loaded [ 1.100529] loop: module loaded [ 1.104089] (hci_tty): inside hci_tty_init [ 1.108680] (hci_tty): allocated 250, 0 [ 1.115233] mtdoops: mtd device (mtddev=name/number) must be supplied [ 1.125068] u***core: registered new interface driver asix [ 1.130737] u***core: registered new interface driver ax88179_178a [ 1.137027] u***core: registered new interface driver cdc_ether [ 1.143051] u***core: registered new interface driver smsc95xx [ 1.148995] u***core: registered new interface driver net1080 [ 1.154833] u***core: registered new interface driver cdc_subset [ 1.160915] u***core: registered new interface driver zaurus [ 1.166733] u***core: registered new interface driver cdc_ncm [ 1.172931] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 1.179518] ehci-pci: EHCI PCI platform driver [ 1.184160] ehci-omap: OMAP-EHCI Host Controller driver [ 1.189895] u***core: registered new interface driver cdc_wdm [ 1.195768] u***core: registered new interface driver u***-storage [ 1.202829] mousedev: PS/2 mouse device common for all mice [ 1.210160] i2c-core: driver [rtc-ds1307] using legacy suspend method [ 1.216637] i2c-core: driver [rtc-ds1307] using legacy resume method [ 1.223834] omap_rtc 44e3e000.rtc: rtc core: registered 44e3e000.rtc as rtc0 [ 1.231775] i2c /dev entries driver [ 1.235425] Driver for 1-wire Dallas network protocol. [ 1.242875] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec [ 1.251608] 48060000.mmc supply vmmc not found, using dummy regulator [ 1.258856] omap_hsmmc 48060000.mmc: could not set regulator OCR (-22) [ 1.301659] ledtrig-cpu: registered to indicate activity on CPUs [ 1.307995] omap-aes 53500000.aes: OMAP AES hw accel rev: 3.2 [ 1.315094] omap-sham 53100000.sham: hw accel on OMAP rev 4.3 [ 1.322274] u***core: registered new interface driver u***hid [ 1.327878] u***hid: USB HID core driver [ 1.332003] platform 44d00000.wkup_m3: Driver wkup_m3 requests probe deferral [ 1.342177] oprofile: using arm/armv7 [ 1.346119] TCP: cubic registered [ 1.349507] Initializing XFRM netlink socket [ 1.353873] NET: Registered protocol family 17 [ 1.358393] NET: Registered protocol family 15 [ 1.362962] Key type dns_resolver registered [ 1.368004] cpu cpu0: of_pm_voltdm_notifier_register: Failed to get cpu0 regulator/voltdm: -517 [ 1.376814] cpu cpu0: cpu0 clock notifier not ready, retry [ 1.382414] platform cpufreq-cpu0.0: Driver cpufreq-cpu0 requests probe deferral [ 1.390498] PM: bootloader does not support rtc-only! [ 1.395582] ThumbEE CPU extension supported. [ 1.400099] Registering SWP/SWPB emulation handler [ 1.406381] vmmcsd_fixed: disabling [ 1.410004] regulator-dummy: disabling [ 1.414435] Error: Driver 'tfp410' is already registered, aborting... [ 1.421250] slave hdmi: could not get i2c [ 1.425314] platform hdmi: Driver slave requests probe deferral [ 1.432064] platform 4830e000.lcdc: Driver tilcdc requests probe deferral [ 1.439471] omap-gpmc 50000000.gpmc: GPMC revision 6.0 [ 1.444638] gpmc_mem_init: disabling cs 0 mapped at 0x0-0x1000000 [ 1.451948] nand: device found, Manufacturer ID: 0x01, Chip ID: 0xd3 [ 1.458382] nand: AMD/Spansion S34ML08G1 [ 1.462322] nand: 1024MiB, SLC, page size: 2048, OOB size: 64 [ 1.468088] nand: using OMAP_ECC_HAM1_CODE_HW [ 1.472612] 11 ofpart partitions found on MTD device omap2-nand.0 [ 1.478750] Creating 11 MTD partitions on "omap2-nand.0": [ 1.484179] 0x000000000000-0x000000020000 : "SPL" [ 1.490511] 0x000000020000-0x000000040000 : "SPL.backup1" [ 1.497278] 0x000000040000-0x000000060000 : "SPL.backup2" [ 1.504104] 0x000000060000-0x000000080000 : "SPL.backup3" [ 1.510975] 0x000000080000-0x000000180000 : "u-boot" [ 1.518010] 0x000000180000-0x0000001a0000 : "u-boot-env" [ 1.524707] 0x0000001a0000-0x0000001c0000 : "u-boot-env.backup1" [ 1.532083] 0x0000001c0000-0x0000001e0000 : "dtb" [ 1.538090] 0x0000001e0000-0x0000006e0000 : "logo" [ 1.548233] 0x0000006e0000-0x000000be0000 : "kernel" [ 1.558616] 0x000000be0000-0x000040000000 : "root" [ 2.391828] tps65217 0-0024: Read from reg 0x16 failed [ 2.397006] DCDC1: failed to enable [ 2.400809] tps65217 0-0024: failed to register tps65217-pmic regulator [ 2.407468] tps65217-pmic: probe of tps65217-pmic failed with error -121 [ 2.414728] tps65217 0-0024: Failed to read revision register: -121 [ 2.421163] tps65217: probe of 0-0024 failed with error -121 [ 2.426905] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz [ 2.433112] remoteproc0: wkup_m3 is available [ 2.437585] remoteproc0: Note: remoteproc is still under development and considered experimental. [ 2.446616] remoteproc0: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed. [ 2.457146] remoteproc0: Direct firmware load failed with error -2 [ 2.463464] remoteproc0: Falling back to user helper [ 2.468834] cpu cpu0: of_pm_voltdm_notifier_register: Failed to get cpu0 regulator/voltdm: -517 [ 2.477577] cpu cpu0: cpu0 clock notifier not ready, retry [ 2.483515] platform cpufreq-cpu0.0: Driver cpufreq-cpu0 requests probe deferral [ 2.491349] pinctrl-single 44e10800.pinmux: pin 44e108a0.0 already requested by panel; cannot claim for hdmi [ 2.501257] pinctrl-single 44e10800.pinmux: pin-40 (hdmi) status -22 [ 2.507642] pinctrl-single 44e10800.pinmux: could not request pin 40 (44e108a0.0) from group nxp_hdmi_bonelt_pins on device pinctrl-single [ 2.520228] slave hdmi: Error applying setting, reverse things back [ 2.526622] pinctrl-single 44e10800.pinmux: pin 44e108a0.0 already requested by panel; cannot claim for hdmi [ 2.536510] pinctrl-single 44e10800.pinmux: pin-40 (hdmi) status -22 [ 2.542902] pinctrl-single 44e10800.pinmux: could not request pin 40 (44e108a0.0) from group nxp_hdmi_bonelt_pins on device pinctrl-single [ 2.555482] slave hdmi: Error applying setting, reverse things back [ 2.561798] slave hdmi: pins are not configured [ 2.568690] dummy 0-0034: Error -121 writing to cec:0xff [ 2.574101] tda998x 0-0070: Error -121 writing to REG_CURPAGE [ 2.579958] tda998x 0-0070: Error -121 reading from 0xa [ 2.585256] tda998x 0-0070: Error -121 writing to 0xa [ 2.648399] tda998x 0-0070: Error -121 reading from 0xa [ 2.653693] tda998x 0-0070: Error -121 writing to 0xa [ 2.718397] tda998x 0-0070: Error -121 reading from 0x1 [ 2.723687] tda998x 0-0070: Error -121 writing to 0x1 [ 2.728814] tda998x 0-0070: Error -121 reading from 0x1 [ 2.734106] tda998x 0-0070: Error -121 writing to 0x1 [ 2.739233] tda998x 0-0070: Error -121 writing to REG_CURPAGE [ 2.745047] tda998x 0-0070: Error -121 writing to 0x200 [ 2.750348] tda998x 0-0070: Error -121 writing to 0x201 [ 2.755638] tda998x 0-0070: Error -121 writing to 0x202 [ 2.760940] tda998x 0-0070: Error -121 writing to 0x203 [ 2.766232] tda998x 0-0070: Error -121 writing to 0x204 [ 2.771534] tda998x 0-0070: Error -121 writing to 0x205 [ 2.776824] tda998x 0-0070: Error -121 writing to 0x20e [ 2.782125] tda998x 0-0070: Error -121 writing to 0x211 [ 2.787415] tda998x 0-0070: Error -121 writing to 0x207 [ 2.792716] tda998x 0-0070: Error -121 writing to 0x208 [ 2.798006] tda998x 0-0070: Error -121 writing to 0x209 [ 2.803307] tda998x 0-0070: Error -121 writing to 0x20a [ 2.808606] tda998x 0-0070: Error -121 writing to 0x206 [ 2.813897] tda998x 0-0070: Error -121 writing to REG_CURPAGE [ 2.819721] tda998x 0-0070: Error -121 writing to 0x27 [ 2.824927] tda998x 0-0070: Error -121 reading from 0x0 [ 2.830227] tda998x 0-0070: Error -121 reading from 0x2 [ 2.836243] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013). [ 2.842919] [drm] No driver support for vblank timestamp query. ����������������������<�<��<�<�<��<�<����<�<��<��<<�<��<��<�<���<�<���<�<��<�<<�<����<�<<��<�<���<<��<��<�<�<���<�<��<��<<�<������< �����������������������������<��<��<<��<<����������<�������<<��<<����<�<���������<�<<��<�<���<<��<��<�<�<���<�<��<��<<�<������ �������������������<��<��<<��<<����������<�������<<��<<����<�<�<��<�<��<�<�<�<��<��<<��<��<<����<�<��<��<��<��<�<�<��������������� ���������������<�<��<����<��<��<��<<��<��<<�<��<���<��<��<<��<<� |
2个回答
请不要用SDK里自带的.ubi做文件系统,请把SDK里自带的.tar.gz解压后,按照下面的步骤制作ubi文件系统:
http://www.deyisupport.com/question_answer/dsp_arm/sitara_arm/f/25/t/59921.aspx |
344868615qq 发表于 2018-5-15 13:50 问题已解决,是lcd的问题,另外http://www.deyisupport.com/question_answer/dsp_arm/sitara_arm/f/25/t/59921.aspx 的 Ubifs文件系统的制作和启动.pdf 有笔误 ,mkfs.ubifs -F中-是减号,而不能用长破折号,我刚开始是复制粘贴的方式使用这行命令,结果第二次启动后文件系统会出错。 |
只有小组成员才能发言,加入小组>>
549 浏览 0 评论
1613 浏览 0 评论
2047 浏览 0 评论
为啥BQ7693003DBTR芯片在和BQ769X0盒子通讯时收不到信号?
1513 浏览 0 评论
DSP 28027F 开发板 XDS100v2调试探针诊断日志显示了 Error -150 (SC_ERR_FTDI_FAIL)如何解决
1337 浏览 0 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
1756浏览 29评论
2781浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
1724浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
1634浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
1645浏览 13评论
/9
GMT+8, 2025-12-2 02:21 , Processed in 0.840572 second(s), Total 75, Slave 58 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3063
