扫一扫,分享给好友
我想要使用多通道的采样,下面是CC1310_LAUNCHXL - ADCBuf配置表
const ADCBufCC26XX_AdcChannelLutEntry ADCBufCC26XX_adcChannelLut[CC1310_LAUNCHXL_ADCBUF0CHANNELCOUNT] = [ [CC1310_LAUNCHXL_DIO23_ANALOG, ADC_COMPB_IN_AUXIO7], [CC1310_LAUNCHXL_DIO24_ANALOG, ADC_COMPB_IN_AUXIO6], [CC1310_LAUNCHXL_DIO25_ANALOG, ADC_COMPB_IN_AUXIO5], [CC1310_LAUNCHXL_DIO26_ANALOG, ADC_COMPB_IN_AUXIO4], [CC1310_LAUNCHXL_DIO27_ANALOG, ADC_COMPB_IN_AUXIO3], [CC1310_LAUNCHXL_DIO28_ANALOG, ADC_COMPB_IN_AUXIO2], [CC1310_LAUNCHXL_DIO29_ANALOG, ADC_COMPB_IN_AUXIO1], [CC1310_LAUNCHXL_DIO30_ANALOG, ADC_COMPB_IN_AUXIO0], [PIN_UNASSIGNED, ADC_COMPB_IN_VDDS], [PIN_UNASSIGNED, ADC_COMPB_IN_DCOUPL], [PIN_UNASSIGNED, ADC_COMPB_IN_VSS], ]; //***********************************end******************************// 我是这样开启adc以及选择通道的,q是按照哪只引脚有电压就设多少,但却没有成功 adcBuf = ADCBuf_open(CC1310_LAUNCHXL_ADC0 , &adcBufParams); if(PIN_getinputValue(CC1310_LAUNCHXL_DIO23_ANALOG) == 1) [ q = 0; ] if(PIN_getInputValue(CC1310_LAUNCHXL_DIO24_ANALOG) == 1) [ q = 1; ] if(PIN_getInputValue(CC1310_LAUNCHXL_DIO25_ANALOG) == 1) [ q = 2; ] continuousConversion.adcChannel = q; 我该如何依照上表去选择通道 |
1个回答
Hi
/* * Copyright (c) 2016-2017, Texas Instruments Incorporated * All rights reserved. * * Redistribution and use in source and binary forms, with or without * modification, are permitted provided that the following conditions * are met: * * * Redistributions of source code must retain the above copyright * notice, this list of conditions and the following disclaimer. * * * Redistributions in binary form must reproduce the above copyright * notice, this list of conditions and the following disclaimer in the * documentation and/or other materials provided with the distribution. * * * Neither the name of Texas Instruments Incorporated nor the names of * its contributors may be used to endorse or promote products derived * from this software without specific prior written permission. * * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, * THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR * PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR * CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. *//* * ======== adcsinglechannel.c ======== */#include |
只有小组成员才能发言,加入小组>>
549 浏览 0 评论
1613 浏览 0 评论
2047 浏览 0 评论
为啥BQ7693003DBTR芯片在和BQ769X0盒子通讯时收不到信号?
1513 浏览 0 评论
DSP 28027F 开发板 XDS100v2调试探针诊断日志显示了 Error -150 (SC_ERR_FTDI_FAIL)如何解决
1337 浏览 0 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
1756浏览 29评论
2781浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
1723浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
1634浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
1645浏览 13评论
/9
GMT+8, 2025-12-1 21:27 , Processed in 0.602445 second(s), Total 71, Slave 54 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3282
