嗨,大家好,
我正在研究XC6SLX75T,工具:ISE13.4。 XST中的设备利用率摘要低于切片寄存器数量9071932969%切片LUT数量115694664824%完全使用的LUT-FF对数量58321480839%已绑定IOB数量16329255%块RAM数量/ FIFO3917222%BUFG / BUFGCTRL数量91656% 但是当它变成maping时,这是一个错误: 地点:543 - 由于设计和/或约束的复杂性,此设计不适合此设备中可用的切片数量。 未按类型放置的实例: FF 76(16.6)LUT 10(28.6)BLOCKRAM 25(67.6) 请评估以下内容: - 如果存在用户定义的约束或区域组:请查看下面的“用户定义的约束”部分,以确定可能影响此设计拟合的约束。 评估它们是否可以移动,移除或调整大小以允许拟合。 验证它们是否与时钟区域限制重叠或冲突。 有关时钟区域使用的更多详细信息,请参阅MAP日志文件(* map)中的时钟区域报告。 - 如果放置LUT有困难:尝试使用MAP LUT组合选项(映射lc区域|自动|关闭)。 - 如果放置FF有困难:评估设计中控制集的数量和配置。 我已将LUT组合设置为自动(地图属性),将Ram风格设置为分布式(XST HDL选项) 以上来自于谷歌翻译 以下为原文 Hi .everyone, I am working on XC6SLX75T, tool:ISE13.4. Device Utilization Summary in XST is below Number of Slice Registers 9071 93296 9% Number of Slice LUTs 11569 46648 24% Number of fully used LUT-FF pairs 5832 14808 39% Number of bonded IOBs 163 292 55% Number of Block RAM/FIFO 39 172 22% Number of BUFG/BUFGCTRLs 9 16 56% But when it maping ,these is a error: Place:543 - This design does not fit into the number of slices available in this device due to the complexity of the design and/or constraints. Unplaced instances by type: FF 76 (16.6) LUT 10 (28.6) BLOCKRAM 25 (67.6) Please evaluate the following: - If there are user-defined constraints or area groups: Please look at the "User-defined constraints" section below to determine what constraints might be impacting the fitting of this design. Evaluate if they can be moved, removed or resized to allow for fitting. Verify that they do not overlap or conflict with clock region restrictions. See the clock region reports in the MAP log file (*map) for more details on clock region usage. - If there is difficulty in placing LUTs: Try using the MAP LUT Combining Option (map lc area|auto|off). - If there is difficulty in placing FFs: Evaluate the number and configuration of the control sets in your design. And I had set LUT Combining to Auto(Map Properties) and Ram Style to Distributed(XST HDL options) |
4个回答
嗨,
您是否尝试删除错误中提到的约束? 你能在这里附上地图报告吗? 以上来自于谷歌翻译 以下为原文 Hi, Did you try removing the constraints as mentioned in the error? Can you pelase attach the map report here? |
嗨,
在哪个阶段之后你收到错误信息? 谢谢,Anusheel ----------------------------------------------- - - - - - - - - - - - - - - - - - - - - - - - - 搜索 在论坛上发布查询之前,与您的设备和工具相关的文档/答案记录。搜索相关论坛并确保您的查询不会重复。请将帖子标记为“接受为解决方案”,以防它有助于解决您的查询。帮助 回答 - >给予Kudos --------------------------------------------- -------------------------------------------------- 以上来自于谷歌翻译 以下为原文 Hi, After which phase are you getting the error message? Thanks, Anusheel ----------------------------------------------------------------------------------------------- Search for documents/answer records related to your device and tool before posting query on forums. Search related forums and make sure your query is not repeated. Please mark the post as an answer "Accept as solution" in case it helps to resolve your query. Helpful answer -> Give Kudos ----------------------------------------------------------------------------------------------- |
嗨,
查看这篇文章http://www.xilinx.com/support/answers/35539.html 谢谢, 迪皮卡。 谢谢,迪皮卡.---------------------------------------------- ---------------------------------------------- Google之前的问题 张贴。 如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。 如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(左边的明星) 以上来自于谷歌翻译 以下为原文 Hi, Check this article http://www.xilinx.com/support/answers/35539.html Thanks, Deepika. Thanks, Deepika. -------------------------------------------------------------------------------------------- Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (the star on the left) |
谢谢大家。
这个问题已经解决了。 DCM的输出必须有BUFG。 以上来自于谷歌翻译 以下为原文 Thanks all. This problem has been solved. There must be a BUFG at the output of DCM. |
只有小组成员才能发言,加入小组>>
2178 浏览 7 评论
2616 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2090 浏览 9 评论
3156 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2211 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
448浏览 1评论
1540浏览 1评论
在使用xc5vsx95T时JTAG扫片不成功,测量TDO无信号输出
2184浏览 0评论
515浏览 0评论
1658浏览 0评论
GMT+8, 2024-5-13 04:49 , Processed in 1.046581 second(s), Total 82, Slave 66 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
