我正在考虑购买使用XC6SLX150T-3FGG676 FPGA的LX150T开发套件。
但是,在我的设计中我想使用XC6SLX150-2FGG484 FPGA。 如果套件中的ISE Design Suite是否支持此设备,请告诉我? 如果没有,是否有任何其他设备锁定套件我可以支持该设备,或者我是否需要购买非设备锁定到该特定设备的完整版ISE设计套件? 非常感谢。 以上来自于谷歌翻译 以下为原文 I am thinking about purchasing the LX150T development kit that uses the XC6SLX150T-3FGG676 FPGA. However, in my design I want to use the XC6SLX150-2FGG484 FPGA. Please can you tell me if the ISE Design Suite in the kit will support this device? If it does not, are there any other device locked kits that I can get to support the device, or do I need to buy a full version of the ISE Design Suite that is not device locked to that specific device? Many thanks. |
4个回答
XC6SLX150T与XC6SLX150不同 - 所以它很可能不起作用;
你必须得到一个完整的ISE版本。 顺便说一下:当你的开发板有LX150T时,你为什么要设计LX150? 阿德里安 请在询问之前先查询您的问题。如果有人回答您的问题,请在“接受为解决方案”标记该帖子。 如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(左边的星)。 以上来自于谷歌翻译 以下为原文 The XC6SLX150T is different from the XC6SLX150 – so it will in all likelihood not work; you'll have to get a full ISE version. By the way: why do you want to design for the LX150, when your dev board has a LX150T? Adrian Please google your question before asking it. If someone answers your question, mark the post with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (the star on the left). |
除了锁定到特定设备之外,许可证还允许您访问WebPACK设备的PlanAhead和WebPACK软件实现。
有关WebPACK设备的列表,请参阅以下产品表。 http://www.xilinx.com/publications/matrix/Software_matrix.pdf -------------------------------------------------- -----------------------不要忘记回答,kudo,并接受为解决方案.------------- -------------------------------------------------- ---------- 以上来自于谷歌翻译 以下为原文 Besides locked to a specific device, the license should give you access to PlanAhead and WebPACK software implementation for WebPACK devices. For a list of WebPACK devices, refer to the following product table. http://www.xilinx.com/publications/matrix/Software_matrix.pdf ------------------------------------------------------------------------- Don't forget to reply, kudo, and accept as solution. ------------------------------------------------------------------------- |
您可能需要联系销售代表,以了解是否有任何套件具有LX150的设备锁定许可证。
否则,您可能必须购买完整版的ISE Design Suite 以上来自于谷歌翻译 以下为原文 You might want to contact a Sales reprsentative to know if any kits has device locked license for LX150. Otherwise, you might have to buy the full version of ISE Design Suite as |
青睐,
S-6 LX150和S-6 LX150T都不是Webpack设备。 阿德里安 请在询问之前先查询您的问题。如果有人回答您的问题,请在“接受为解决方案”标记该帖子。 如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(左边的星)。 以上来自于谷歌翻译 以下为原文 graces, neither the S-6 LX150 nor the S-6 LX150T are Webpack devices. Adrian Please google your question before asking it. If someone answers your question, mark the post with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (the star on the left). |
只有小组成员才能发言,加入小组>>
3186 浏览 7 评论
3461 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2932 浏览 9 评论
4463 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3107 浏览 15 评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1236浏览 1评论
/5
GMT+8, 2026-1-21 05:15 , Processed in 0.712586 second(s), Total 78, Slave 62 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 长沙勒克斯教育咨询有限公司
淘帖
2083
