我使用了“xapp1151”CAM设计,并使用提供的perl脚本对其进行了定制。
它在ISE中合成没有错误,但是当涉及到模拟时会出现问题。 由于以下错误,在ModelSim 10.0C或Isim 14.2中模拟此核心失败。 似乎两个阵列具有不同的长度,因此模拟失败。 请告诉我如何解决此问题。 我应该补充说,更改两个向量长度并不是一件容易的事,因为要配置的参数太多。 只是提醒你,这个CAM不是我自己的设计。 我只是使用可用的脚本定制它。 我的配置:cam_depth = 16,cam_width = 48,二进制编码地址。 在此先感谢.ModelSim错误:#**致命:( vsim-3420)数组长度不匹配。 左边是36(35下降0)。 右边是72(71下降0)。#时间:0 ps迭代:0实例:/ test_ram_cam / u_cam_wrapper / top_cam / rtl_cam / mem / gblk / blkmem / gextw(0)/ gcp / extd / gextd(0)/ gincp / extdp / s6prim / BRAM_TDP_MACRO_inst / ramb_st / ramb18_dp_st / ram18_st文件:C:/Xilinx/14.2/ISE_DS/ISE/vhdl/src/unisims/primitive/RAMB16BWER.vhd行:599 #Datal ERROR加载设计时 Isim错误:HDLCompiler:410 - “N:/P.28xd/rtf/vhdl/src/unisims/primitive/RAMB16BWER.vhd”第599行:表达式有72个元素; 预期36ERROR:模拟器:777 - 图书馆工作中顶级VHDL设计单元test_ram_cam的静态细化失败 以上来自于谷歌翻译 以下为原文 I used "xapp1151" CAM design and customized it using presented perl scripts. It synthesizes without errors in ISE, but when it comes to simulation a problem arises. Simulating this core in either ModelSim 10.0C or Isim 14.2 fails due to the following errors. It seems that two arrays have different lengths, hence simulation fails. Please tell me how to resolve this issue. I should add that changing the two vector lengths is not an easy task, since there are too many parameters to be configured. Just to remind you, this CAM is not my own design. I just have customized it using available scripts. My Configurations: cam_depth = 16, cam_width = 48, Binary Encoded Address. Thanks in advance. ModelSim Error: # ** Fatal: (vsim-3420) Array lengths do not match. Left is 36 (35 downto 0). Right is 72 (71 downto 0). # Time: 0 ps Iteration: 0 Instance: /test_ram_cam/u_cam_wrapper/top_cam/rtl_cam/mem/gblk/blkmem/gextw(0)/gcp/extd/gextd(0)/gincp/extdp/s6prim/BRAM_TDP_MACRO_inst/ramb_st/ramb18_dp_st/ram18_st File: C:/Xilinx/14.2/ISE_DS/ISE/vhdl/src/unisims/primitive/RAMB16BWER.vhd Line: 599 # FATAL ERROR while loading design Isim Error: HDLCompiler:410 - "N:/P.28xd/rtf/vhdl/src/unisims/primitive/RAMB16BWER.vhd" Line 599: Expression has 72 elements ; expected 36 ERROR:Simulator:777 - Static elaboration of top level VHDL design unit test_ram_cam in library work failed |
1个回答
msjatxilinx写道:
我使用了“xapp1151”CAM设计,并使用提供的perl脚本对其进行了定制。 它在ISE中合成没有错误,但是当涉及到模拟时会出现问题。 由于以下错误,在ModelSim 10.0C或Isim 14.2中模拟此核心失败。 似乎两个阵列具有不同的长度,因此模拟失败。 请告诉我如何解决此问题。 我应该补充说,更改两个向量长度并不是一件容易的事,因为要配置的参数太多。 只是提醒你,这个CAM不是我自己的设计。 我只是使用可用的脚本定制它。 我的配置:cam_depth = 16,cam_width = 48,二进制编码地址。 在此先感谢.ModelSim错误:#**致命:( vsim-3420)数组长度不匹配。 左边是36(35下降0)。 右边是72(71下降0)。#时间:0 ps迭代:0实例:/ test_ram_cam / u_cam_wrapper / top_cam / rtl_cam / mem / gblk / blkmem / gextw(0)/ gcp / extd / gextd(0)/ gincp / extdp / s6prim / BRAM_TDP_MACRO_inst / ramb_st / ramb18_dp_st / ram18_st文件:C:/Xilinx/14.2/ISE_DS/ISE/vhdl/src/unisims/primitive/RAMB16BWER.vhd行:599 #Datal ERROR加载设计时 Isim错误:HDLCompiler:410 - “N:/P.28xd/rtf/vhdl/src/unisims/primitive/RAMB16BWER.vhd”第599行:表达式有72个元素; 预期36ERROR:模拟器:777 - 图书馆工作中顶级VHDL设计单元test_ram_cam的静态细化失败 好吧,生活有时并不容易,但错误信息很明确,它告诉你如何解决问题。 ----------------------------是的,我这样做是为了谋生。 以上来自于谷歌翻译 以下为原文 msjatxilinx wrote:Well, life sometimes isn't easy, but the error message is clear and it tells you exactly how to fix the problem. ----------------------------Yes, I do this for a living. |
只有小组成员才能发言,加入小组>>
2165 浏览 7 评论
2608 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2080 浏览 9 评论
3152 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2197 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
429浏览 1评论
1527浏览 1评论
在使用xc5vsx95T时JTAG扫片不成功,测量TDO无信号输出
2180浏览 0评论
511浏览 0评论
1644浏览 0评论
GMT+8, 2024-4-27 07:52 , Processed in 0.946918 second(s), Total 73, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
