我已经非常成功地使用嵌入式ARM处理器控制L6470步进驱动器芯片,以实现除无传感器失速检测功能之外的所有功能。我希望我错过了一些东西,有人可以向我指出这一点。我一直在这个论坛上,我可以看到每一块ST文档。
当我试图检测失速时,检测阈值似乎非常敏感;在一个电流设置下,芯片检测到任何停顿,并且在下一个失速阈值电流增量时,芯片显示停止。这几乎使该功能无法使用,所以我没有使用它。我真的希望能够使用这个功能,因为我们不能把编码器放在任何地方。此外,这是我们选择驱动芯片的一个原因,如果我们不能使用该功能,那将是令人失望的。 我错过了一些明显的东西吗除了L6470数据表中包含的内容之外,是否有更多关于此功能的文档? 谢谢, 韦恩 以上来自于谷歌翻译 以下为原文 I've been quite successful at controlling the L6470 stepper driver chip from my embedded ARM processor for all features other than the sensorless stall detection feature. I'm hoping that I'm missing something and that someone can point that out to me. I've been all over this forum and every scrap of ST documentation I can get my eyes on. When I try to detect stalling, the detection threshold seems to be very sensitive; at one current setting the chip detect any stalls, and at the next increment of stall threshold current the chip shows stalling. This pretty much makes the feature unusable, so I'm not using it. I would really like to be able to use this feature, since we can't afford to put encoders everywhere. Also, it's one reason we picked the driver chip, so it will be disappointing if we can't use that feature. Am I missing something obvious? Is there more documentation around this feature other than what is contained in the L6470 datasheet? Thanks, Wayne |
3个回答
亲爱的韦恩
我建议在https://my.st.com//public/STe2ecommunities/motordriver_ics/Lists/Motor%20Driver%20ICs%20and%20Boards/AllItems.aspx上发布此帖子 论坛。 谢谢 再见 梁咏琪 注意:原始帖子包含大量线程对话,只能迁移到第9级 以上来自于谷歌翻译 以下为原文 Dear Wayne I suggest post this thread in the https://my.st.com//public/STe2ecommunities/motordriver_ics/Lists/Motor%20Driver%20ICs%20and%20Boards/AllItems.aspx forum. Thanks Ciao Gigi Note: the original post contained a large number of threaded conversations and was only able to be migrated to the 9th level |
嗨韦恩,
你能解决这个问题吗?我也有同样的问题。 谢谢, 标记 以上来自于谷歌翻译 以下为原文 Hi Wayne, Were you able to resolve this issue? I have the same problem. Thanks, Mark |
嗨,
不,我无法解决这个问题。你有运气吗? 以上来自于谷歌翻译 以下为原文 Hi, No, I was not able to solve this problem. Have you had any luck? |
只有小组成员才能发言,加入小组>>
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
1463 浏览 1 评论
2131 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
1510 浏览 1 评论
2830 浏览 6 评论
5257 浏览 21 评论
364浏览 4评论
550浏览 4评论
在Linux上安装Atollic TRUEStudio的步骤有哪些呢?
279浏览 3评论
使用DMA激活某些外设会以导致外设无法工作的方式生成代码是怎么回事
625浏览 3评论
522浏览 3评论
GMT+8, 2024-4-26 13:11 , Processed in 0.775771 second(s), Total 75, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
