我希望在多核计算机上安装我的节点锁定许可证。
主板也可以采用第二处理器。 我想找到 如果我可以在节点上运行多个ISE会话(直到数字 处理器上的内核,假设我有足够的内存)或者我 将需要第二个处理器来有效地处理第二个ISE会话。 问候, 以上来自于谷歌翻译 以下为原文 I am looking to install my node-locked license on a multi-core machine. The mother board can also take a 2nd processor. I would like to find out if I can run multiple ISE sessions on the node (up to the number of cores on the processor, assuming I have enough memory) or if I will need a 2nd processor to handle a second ISE session efficiently. Regards, |
4个回答
节点锁定许可证锁定到您的PC而不是处理器。
所以它会起作用。 您正在寻找用于多线程使用的-mt选项。 请参阅Xilinx Docs并查找-mt开关。 问候,Debraj ----------------------------------------------- - - - - - - - - - - - - - - - - - - - - - - - -请注意- 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用且回复的帖子。感谢Kudos .-------------------- -------------------------------------------------- ------------------------ 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 The node locked license is locked to your PC not processor. So it would work. You are looking for -mt option which is for multi-threading usage. Refer to Xilinx Docs and look for -mt switch.Regards, Debraj ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ----------------------------------------------------------------------------------------------View solution in original post |
所以它会起作用。 您正在寻找用于多线程使用的-mt选项。 请参阅Xilinx Docs并查找-mt开关。 问候,Debraj ----------------------------------------------- - - - - - - - - - - - - - - - - - - - - - - - -请注意- 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用且回复的帖子。感谢Kudos .-------------------- -------------------------------------------------- ------------------------ 以上来自于谷歌翻译 以下为原文 The node locked license is locked to your PC not processor. So it would work. You are looking for -mt option which is for multi-threading usage. Refer to Xilinx Docs and look for -mt switch.Regards, Debraj ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------- |
要进一步添加,您可以在一台PC上运行任意数量的ISE会话。
-------------------------------------------------- ---------------------------------------------请将帖子标记为 如果提供的信息能够回答您的问题/解决您的问题,请“接受为解决方案”。给予您认为有用的帖子。 以上来自于谷歌翻译 以下为原文 To add further, you can run any number of ISE sessions on a single pc.----------------------------------------------------------------------------------------------- Please mark the post as "Accept as solution" if the information provided answers your query/resolves your issue. Give Kudos to a post which you think is helpful. |
只有小组成员才能发言,加入小组>>
2176 浏览 7 评论
2613 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2082 浏览 9 评论
3155 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2201 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
444浏览 1评论
1535浏览 1评论
在使用xc5vsx95T时JTAG扫片不成功,测量TDO无信号输出
2183浏览 0评论
513浏览 0评论
1653浏览 0评论
GMT+8, 2024-5-7 11:16 , Processed in 1.174880 second(s), Total 76, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
