【嘉楠堪智K230开发板试用体验】基于 K230 的 参照HHB的 demo 实现基于 c 语言的自定义模型公交 - RISC-V MCU技术社区 - 电子技术论坛 - 广受欢迎的专业电子论坛
分享 收藏 返回
[文章]
1 准备 K230 SDK和工具链
从 Gitee 上下载最新的 SDK
2 参照 HHB 的 demo 来实现自定义的模型,参照的 demo 在大核里面,如下图
参照官方的方法获取 hhb 的 docker image
tar xzf hhb-2.2.35.docker.tar.gz
cd hhb-2.2.35.docker/
docker load < hhb.2.2.35.img.tar
./start_hhb.sh
参照官方的方法,编译模型
准备自定义数据集
创建数据集脚本
import os
import shutil
from sklearn.model_selection import train_test_split
def create_dataset_structure(base_path, classes):
os.makedirs(base_path, exist_ok=True)
for split in ['train', 'val', 'test']:
split_path = os.path.join(base_path, split)
os.makedirs(split_path, exist_ok=True)
for class_name in classes:
class_path = os.path.join(split_path, class_name)
os.makedirs(class_path, exist_ok=True)
print(f"数据集结构已在 {base_path} 创建完成")
if name == "main":
classes = ["cat"]
create_dataset_structure("custom_dataset", classes)
数据增强和预处理脚本
from torchvision import transforms
from torch.utils.data import DataLoader
import torchvision.datasets as datasets
import os
def get_data_transforms(input_size=224):
train_transforms = transforms.Compose([
transforms.RandomResizedCrop(input_size),
transforms.RandomHorizontalFlip(),
transforms.RandomRotation(10),
transforms.ColorJitter(brightness=0.2, contrast=0.2, saturation=0.2, hue=0.1),
transforms.ToTensor(),
transforms.Normalize(mean=[0.485, 0.456, 0.406],
std=[0.229, 0.224, 0.225])
val_transforms = transforms.Compose([
transforms.Resize(256),
transforms.CenterCrop(input_size),
return train_transforms, val_transforms
def create_data_loaders(data_dir, batch_size=32, input_size=224):
train_transforms, val_transforms = get_data_transforms(input_size)
train_dataset = datasets.ImageFolder(
os.path.join(data_dir, 'train'),
transform=train_transforms
val_dataset = datasets.ImageFolder(
os.path.join(data_dir, 'val'),
transform=val_transforms
test_dataset = datasets.ImageFolder(
os.path.join(data_dir, 'test'),
train_loader = DataLoader(
train_dataset,
batch_size=batch_size,
shuffle=True,
num_workers=4,
pin_memory=True
val_loader = DataLoader(
val_dataset,
shuffle=False,
num_workers=4,
pin_memory=True
test_loader = DataLoader(
test_dataset,
shuffle=False,
num_workers=4,
pin_memory=True
return train_loader, val_loader, test_loader, train_dataset.classes
if name == "main":
data_dir = "custom_dataset"
train_loader, val_loader, test_loader, classes = create_data_loaders(data_dir)
print(f"类别: {classes}")
print(f"训练集大小: {len(train_loader.dataset)}")
print(f"验证集大小: {len(val_loader.dataset)}")
print(f"测试集大小: {len(test_loader.dataset)}")
模型训练脚本
import torch
import torch.nn as nn
import torch.optim as optim
from torch.optim import lr_scheduler
import torchvision.models as models
from torch.utils.tensorboard import SummaryWriter
import time
import copy
import os
def train_model(model, dataloaders, criterion, optimizer, scheduler, num_epochs=25, device='cuda'):
since = time.time()
best_model_wts = copy.deepcopy(model.state_dict())
best_acc = 0.0
writer = SummaryWriter()
for epoch in range(num_epochs):
print(f'Epoch {epoch}/{num_epochs - 1}')
print('-' * 10)
for phase in ['train', 'val']:
if phase == 'train':
model.train()
else:
model.eval()
running_loss = 0.0
running_corrects = 0
for inputs, labels in dataloaders[phase]:
inputs = inputs.to(device)
labels = labels.to(device)
optimizer.zero_grad()
with torch.set_grad_enabled(phase == 'train'):
outputs = model(inputs)
_, preds = torch.max(outputs, 1)
loss = criterion(outputs, labels)
loss.backward()
optimizer.step()
running_loss += loss.item() * inputs.size(0)
running_corrects += torch.sum(preds == labels.data)
scheduler.step()
epoch_loss = running_loss / len(dataloaders[phase].dataset)
epoch_acc = running_corrects.double() / len(dataloaders[phase].dataset)
print(f'{phase} Loss: {epoch_loss:.4f} Acc: {epoch_acc:.4f}')
writer.add_scalar(f'Loss/{phase}', epoch_loss, epoch)
writer.add_scalar(f'Accuracy/{phase}', epoch_acc, epoch)
if phase == 'val' and epoch_acc > best_acc:
best_acc = epoch_acc
print()
time_elapsed = time.time() - since
print(f'训练完成于 {time_elapsed // 60:.0f}分 {time_elapsed % 60:.0f}秒')
print(f'最佳验证准确率: {best_acc:.4f}')
model.load_state_dict(best_model_wts)
writer.close()
return model
def main():
device = torch.device("cuda:0" if torch.cuda.is_available() else "cpu")
print(f"使用设备: {device}")
train_loader, val_loader, _, classes = create_data_loaders(data_dir)
dataloaders = {'train': train_loader, 'val': val_loader}
model = models.mobilenet_v2(pretrained=True)
num_features = model.classifier[1].in_features
model.classifier[1] = nn.Linear(num_features, len(classes))
model = model.to(device)
criterion = nn.CrossEntropyLoss()
optimizer = optim.SGD(model.parameters(), lr=0.001, momentum=0.9)
scheduler = lr_scheduler.StepLR(optimizer, step_size=7, gamma=0.1)
model = train_model(model, dataloaders, criterion, optimizer, scheduler, num_epochs=25)
torch.save(model.state_dict(), 'custom_model.pth')
print("模型已保存为 custom_model.pth")
with open('class_names.txt', 'w') as f:
f.write(f"{class_name}\n")
print("类别信息已保存为 class_names.txt")
if name == "main":
main()
转换 ONNX 格式
import torch
def convert_to_onnx(model_path, class_names_path, onnx_path, input_size=224):
with open(class_names_path, 'r') as f:
classes = [line.strip() for line in f.readlines()]
model = models.mobilenet_v2(pretrained=False)
model.load_state_dict(torch.load(model_path))
model.eval()
dummy_input = torch.randn(1, 3, input_size, input_size)
torch.onnx.export(
model,
dummy_input,
onnx_path,
export_params=True,
opset_version=11,
do_constant_folding=True,
input_names=['input'],
output_names=['output'],
dynamic_axes={'input': {0: 'batch_size'}, 'output': {0: 'batch_size'}}
print(f"模型已成功转换为ONNX格式: {onnx_path}"
if name == "main":
convert_to_onnx(
model_path="custom_model.pth",
class_names_path="class_names.txt",
onnx_path="custom_model.onnx",
input_size=224
数据校准脚本
import os
import shutil
import random
from PIL import Image
import torchvision.transforms as transforms
def prepare_calibration_data(dataset_path, output_path, num_images=100):
os.makedirs(output_path, exist_ok=True)
all_images = []
for split in ['train', 'val']:
split_path = os.path.join(dataset_path, split)
for class_name in os.listdir(split_path):
if os.path.isdir(class_path):
for img_name in os.listdir(class_path):
if img_name.lower().endswith(('.png', '.jpg', '.jpeg')):
all_images.append(os.path.join(class_path, img_name))
selected_images = random.sample(all_images, min(num_images, len(all_images)))
preprocess = transforms.Compose([
transforms.CenterCrop(224),
for i, img_path in enumerate(selected_images):
img = Image.open(img_path).convert('RGB')
img_tensor = preprocess(img)
output_file = os.path.join(output_path, f"calib_{i:04d}.bin")
with open(output_file, 'wb') as f:
f.write(img_tensor.numpy().tobytes())
print(f"已准备 {len(selected_images)} 张校准图像到 {output_path}")
if name == "main":
dataset_path="custom_dataset",
output_path="calibration_data",
num_images=100
使用 HHB进行编译和量化
#!/bin/bash
docker run -it --rm
-v $(pwd):/home/alientek/k230_sdk-v1.9
cannane/hhb:2.4.1
/bin/bash -c "
cd /home/alientek/k230_sdk-v1.9
hhb --model-file custom_model.onnx
--data-scale 0.003921568627451 \ # 1/255
--data-mean '124 116 104' \ # 均值 (0.485 * 255, 0.456 * 255, 0.406 * 255)
--board k230
--input-shape '1 3 224 224'
--quantization-scheme 'int8_sym'
--calibrate-dataset calibration_data
--output custom_model_quantized
echo 'HHB量化完成'
参照官方文档运行 demo
根据官方的 demo 来修改
更多回帖
