void IMUupdate(float gx, float gy, float gz, float ax, float ay, float az, float mx, float my, float mz)
float norm;
float hx, hy, hz, bx, bz;
float wx, wy, wz;
float vx, vy, vz;
float ex, ey, ez;
float q0q0 = q0*q0;
float q0q1 = q0*q1;
float q0q2 = q0*q2;
float q0q3 = q0*q3;
float q1q1 = q1*q1;
float q1q2 = q1*q2;
float q1q3 = q1*q3;
float q2q2 = q2*q2;
float q2q3 = q2*q3;
float q3q3 = q3*q3;
gx = gx*tog;
gy = gy*tog;
gz = gz*tog;
ax = ax*toa;
ay = ay*toa;
az = az*toa;
mx = mx*gua;
my = my*gua;
mz = mz*gua;
if(ax*ay*az==0)
return;
if(cc==255&&dd==255&&ee==255)
imuupdate(val[0],val[1],val[2], val[3],val[4],val[5]);
return;
norm = sqrt(ax*ax + ay*ay + az*az); //acc¹éÒ»»¯
ax = ax / norm;
ay = ay / norm;
az = az / norm;
norm = sqrt(mx*mx + my*my + mz*mz); //mag¹éÒ»»¯
mx = mx / norm;
my = my / norm;
mz = mz / norm;
hx = 2 * mx * (0.5 - q2q2 - q3q3) + 2 * my * (q1q2 - q0q3) + 2 * mz * (q1q3 + q0q2);
hy = 2 * mx * (q1q2 + q0q3) + 2 * my * (0.5 - q1q1 - q3q3) + 2 * mz * (q2q3 - q0q1);
hz = 2 * mx * (q1q3 - q0q2) + 2 * my * (q2q3 + q0q1) + 2 * mz * (0.5 - q1q1 -q2q2);
bx = sqrt((hx*hx) + (hy*hy));
bz = hz;
vx = 2*(q1q3 - q0q2);
vy = 2*(q0q1 + q2q3);
vz = q0q0 - q1q1 - q2q2 + q3q3 ;
wx = 2 * bx * (0.5 - q2q2 - q3q3) + 2 * bz * (q1q3 - q0q2);
wy = 2 * bx * (q1q2 - q0q3) + 2 * bz * (q0q1 + q2q3);
wz = 2 * bx * (q0q2 + q1q3) + 2 * bz * (0.5 - q1q1 - q2q2);
ex = (ay*vz - az*vy) + (my*wz - mz*wy);
ey = (az*vx - ax*vz) + (mz*wx - mx*wz);
ez = (ax*vy - ay*vx) + (mx*wy - my*wx);
exInt = exInt + ex * Ki;
eyInt = eyInt + ey * Ki;
ezInt = ezInt + ez * Ki;
gx = gx + Kp*ex + exInt;
gy = gy + Kp*ey + eyInt;
gz = gz + Kp*ez + ezInt;
q0 = q0 + (-q1*gx - q2*gy - q3*gz)*halfT;
q1 = q1 + (q0*gx + q2*gz - q3*gy)*halfT;
q2 = q2 + (q0*gy - q1*gz + q3*gx)*halfT;
q3 = q3 + (q0*gz + q1*gy - q2*gx)*halfT;
norm = sqrt(q0*q0 + q1*q1 + q2*q2 + q3*q3);
q0 = q0 / norm;
q1 = q1 / norm;
q2 = q2 / norm;
q3 = q3 / norm;
Yaww = atan2(2 * q1 * q2 + 2 * q0 * q3, -2 * q2*q2 - 2 * q3* q3 + 1)* 57.3;
Pitchw = asin(-2 * q1 * q3 + 2 * q0* q2)* 57.3;
Rollw = atan2(2 * q2 * q3 + 2 * q0 * q1, -2 * q1 * q1 - 2 * q2* q2 + 1)* 57.3;
六轴拟合算法程序,拟合后的数据yaw不偏移,但是上电以后初始角度不为0,为0的角度总是偏向于一个固定方位。这种现象正常吗?如果想为0,可以如何修改。
2019-7-31 07:12:33
不好意思,发错了,上面这个是 九轴算法,不是六轴算法。九轴数据出来以后偏航角不会偏移,但是初始位置不是0,我该如何调整。
举报
