另外,
有LOCKED信号和CLOCK_LOST信号(状态位)。
如果LOCKED丢失(变为假)或CLOCK LOST变为true,则应重置DCM。
通常,如果时钟在同一块板上(晶体ocsillator封装)并且它是如此可靠,并且检查LOCKED和CLOCK LOST是不必要的(因为它永远不会失锁,永远不会丢失时钟)。
但是,如果所有时钟都有可能出现故障或丢失,则需要在这些事件上重置DCM才能使DCM运行并再次锁定。
Austin Lesea主要工程师Xilinx San Jose
以上来自于谷歌翻译
以下为原文
Additionally,
There is the LOCKED signal, and CLOCK_LOST signal (status bits). If LOCKED is lost (becomes false), or CLOCK LOST becomes true, you should reset the DCM.
Often if the clock is on the same board (crystal ocsillator package) and it is so reliable, and checking LOCKED and CLOCK LOST is not necessary (as it never loses lock, and never loses the clock).
But, if there is any chance at all the clock could glitch, or be lost, then reseting the DCM on those events is required to get the DCM running and locked again.
Austin Lesea
Principal Engineer
Xilinx San Jose
另外,
以上来自于谷歌翻译
以下为原文
Additionally,
Austin Lesea
Principal Engineer
Xilinx San Jose
举报
