我在sp601板上使用tri-ethernet-mac示例。
gmii接收器接口使用IODELAY2原语来延迟接收器侧的输入信号。
vhdl代码提到应该根据设计在ucf中更改IDELAY_VALUE。
我阅读了i / o延迟概述,但无法了解如何为设计计算IDELAY_VALUE的值?
根据ug 138的193页,所需的最小设置时间为2ns,保持时间为0 ns。
如果有人能提供帮助,我将不胜
以上来自于谷歌翻译
以下为原文
I am using tri-ethernet-mac example for sp601 board.
The gmii receiver interface uses IODELAY2 primi
tive to delay the input signal on the receiver side.
The vhdl code mentions that IDELAY_VALUE should be changed in ucf as per the design.
I read the i/o delay overview but could not get an idea on how to calculate the value of IDELAY_VALUE for the design?
The minimum set up time required is 2ns and hold time 0 ns as per 193 page of ug 138.
Would appreciate if someone can help.
