你好
您应该使用spartan6的时钟向导来使用PLL和DCM,如下面的快照所示。
旧的PLL和DCM向导不适用于6和7系列设备。
问候,萨蒂什-----------------------------------------------
--- --------------------------------------------请注意
- 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用的帖子。感谢.--
以上来自于谷歌翻译
以下为原文
Hi
you should use the clocking wizard for spartan6 to use the PLL and DCM's as shown in the below snapshot.
THe old PLL and DCM wizard's are not applicable for 6 and 7 series devices.
Regards,
Satish
Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful.
Give Kudos to a post which you think is helpful.
你好
以上来自于谷歌翻译
以下为原文
Hi
Regards,
Satish
举报
